Do-It-Yourself Layout Creator [open-source]  [link]
rocklander
Has thanked: 1406 times
Been thanked: 231 times
Post by rocklander »
is roku on windows or mac?
if it's windows, you could just RDP to the client (there are *cough* patches *cough* available which will let you RDP to a windows box in a separate session, the same way that you can on windows server, and leave the main console unaffected) from your android...
Been thanked: 909 times
Bancika, is it possible to have more control over tube schematic symbols?
Like rotate 90/180/270 degrees, and horizontal flip? Must have for triode
I also just downloaded new version. Funny things happen with ground symbols when copy and paste. All ground symbols are grouped into one point. Try to copy schematic, select it all, copy, and paste below, you'll see what I mean :)
Cheers and huge thanks, great job!
doctortropico
Post by doctortropico »
Dr Tony Balls wrote:dang, nevermind. it appears to be a mountain lion bug. If I select allow apps from anywhere then it opens fine!
Cheers!
xaxxop
my favorite amplifier: Gallien Krueger 400RB
Completed builds: DIY: Boss ce-2, EH big muff, MXR microamp, DOD FX25, Stingray Preamp
Post by xaxxop »
good afternoon people, anyone have diy-layout-creator for OS X 10.4?
thanks for your time :thumbsup
Leandro
Dr Tony Balls
Been thanked: 172 times
Post by Dr Tony Balls »
The most recent version (3.28.0) doesnt work with 10.9.2, i know that for sure. If you try to open it you get: "DIYLC is damaged and can't be opened. You should move it to the Trash."
As a workaround ive been using the multi-platform version here: https://code.google.com/p/diy-layout-cr ... p&can=2&q=
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 207 times
Post by grrrunge »
xaxxop wrote:good afternoon people, anyone have diy-layout-creator for OS X 10.4?
Which mac are you on? If it's a newer model, 10.9 is free of charge from app store, and app store should be included in the latest update of your system version. I'd recommend that over running an old version of DIYLC ;)
xaxxop
Post by xaxxop »
thanks grrrunge. the problem is that my mac is old.
Leandro
grrrunge
Post by grrrunge »
xaxxop wrote:thanks grrrunge. the problem is that my mac is old.
Fair enough. Can't you upgrade to the latest version of Java anyway? That way you should be able to run the universal build.
xaxxop
Post by xaxxop »
thanks for reply, I did all the Java upgrade but I don't know what to do :scratch:
Leandro
Mento
Post by Mento »
Hi everybody,
hope, this is the right place for my post.
I just started to work with diylc version 3.22.0 The tool is awesome!
I run it on a Mac with osx 10.8.5
But there is following issue. When creating templates, they are not saved when I do so.
I choose an item, edit it, go to Save as Template but then there is nothing in the template menu in
the corresponding item.
What could be the matter?
Best regards
Philipp
Mento
Post by Mento »
Just found out: When creating a template with the setting i posted before, if you hold the
right mouse tab and scroll down while holding the mousetab, it creates the desired template.
Thought i'd be fine. safed the project, reopened it times and times after to be safe.
But then i got a phonecall, closed the programm.
Now all the templates are gone :-((( Whole afternoon of work wasted.
What the hell is the thing?
Mento
Post by Mento »
Maybe my computer doestn safe in the correct folder.
Where has to be which file?
Mento
Post by Mento »
Also, if i close the programm by "quit diylc", everytime it says "it appears that aplication was not closed normally in the previous session".
ilcaccillo
Been thanked: 18 times
Post by ilcaccillo »
DIYLC V3 doesnt work in my OSX 10.7.5 (Lion),
I have the latest Java version installed,
when I click the DIYLC icon nothing happens!
I can open the DIYLC V3 (any version 3) multiplataform DIYLC.JAR file,
although I receive message saying it's not recommended to use the JAR file, thats really the only way to open this software
deltafred
Has thanked: 813 times
Been thanked: 306 times
Post by deltafred »
Old guy here who needs a bit of help.
I installed DIYLC onto my Ubuntu Linux 14.04 (LTS) PC. When I try and draw a (perf) board the components are huge, e.g. resistors are plain blue with no bands, they look like 1/4 or 1/2 watt.
I am assuming that to get the nice little 1/8th watt resistors with bands (and other suitable components) I need a library. Can anyone suggest where I could get a suitable one and how do I install it?
Thanks in advance. :hug:
bancika
Has thanked: 16 times
Been thanked: 89 times
Post by bancika »
you need to set resistor values for bands to show up (double click and input value in the box).
Btw, I just released version 3.29.0 with a few new features and fixes. You can find it on github https://github.com/bancika/diy-layout-creator/releases
deltafred
Post by deltafred »
bancika wrote:you need to set resistor values for bands to show up (double click and input value in the box).
Thanks Bancika, I discovered that after posting.
I will load the new version but doubt I will get much done with it over the summer, winter is when I hibernate in my workshop.
bancika
Post by bancika »
I have published the first beta version to https://github.com/bancika/diy-layout-c ... _3_32_Beta
The main new feature is "Project Cloud" that allows project sharing between users. You can upload your projects, search for and download other people's projects and post public comments on any project.
Feel free to give it a go. The new feature can be accessed from the main menu. You'll need to create an account (takes only few seconds) to publish projects and post comments.
Please note that at the end of the testing period, the cloud storage will be cleared to remove rubbish test data and we will start from scratch.
Stuff that's not yet ready:
"Manage My Projects" feature doesn't do anything. I plan to make it possible to update and delete projects.
Categories need some refinement (please suggest new categories)
Keywords will be auto-generated when the project is selected to contain key project information, this doesn't work at the moment
Thank you for testing and please make sure to report any feedback to bancika@gmail.com
bancika
Post by bancika »
Just deployed a new version. Below is the change log and you can grab it from here https://github.com/bancika/diy-layout-creator/releases
[New Feature] Terminal strip component added
[New Feature] Battery schematic symbol added
[New Feature] Glass diode component added
[New Feature] SMD capacitor and resistor added
[Improvement] Tube, transistor and potentiometer symbols can be rotated
[Improvement] Added percent text box next to the slider for editors like Alpha or Scale
[Improvement] Better object line representation when zoomed in
[Improvement] Increased maximum zoom range from 200% to 300%
[Improvement] Improved pentode symbol without the suppressor grid
bancika
Post by bancika »
Hot off the press, the last release in 2016. You can find it here https://github.com/bancika/diy-layout-c ... ag/v3.34.0
[New Feature] Searchable component tree instead of the old toolbar (can be changed back from "Config" menu)
[New Feature] Open 1/4" Switchcraft-style jack added
[New Feature] LP-style switch added
[New Feature] P-90 pickup in both "dog ear" and "soap bar" variations added
[New Feature] Telecaster bridge pickup added as a variation of single coil pickup
[New Feature] Mini humbucker pickup added as a variation of Humbucker pickup
[Improvement] X-axis coordinates for all perfboards are now numberical
[Improvement] Improved trace cut rendering to look more realistic
[Improvement] Improved guitar pickup rendering to look more realistic
[Bug Fix] Using unicode characters (like micro character) in template names breaks the whole config file
[Bug Fix] Fixed broken links in the Help menu
[Bug Fix] TriPad board didn't show coordinate labels even when configured to do so
