Amptweaker - Tight Metal  [traced]
Locked
rcustoms
Has thanked: 363 times
Been thanked: 520 times
Post by rcustoms »
ggedamed wrote:
Darksid46 wrote:Нет это не связано с AMT L1 серии.Это новая разработка LIONSOUND14\0 \DarkAngel/ А СИМ я взял от 12версии.+добавил выход на наушники от HotLine2/
I think he said
Code: Select all
No, it is not associated with the AMT L1 series. It is a new development  - LIONSOUND14\0\DarkAngel/. And I took the cabsim from version 12 and added the headphone output from HotLine2.
Hmm, I remember DarkAngel modding the SansAmp GT2.
Seeing E530 written on the case and seeing Lionsound on guitar-gear.ru in the AMT stompboxes thread made me think this is related.
The "new development" part makes me think he just wanted to advertise his pedal.
uhhh i think that this pedal is from a russian guy, very clever in deep ,this is the link (in russian)
http://guitar-gear.ru/forum/topic/3724- ... _lionsound
and this is the schematcs from the ver 12
an the ver. 14 is a mod from darksid.very clever pedal and very clever mod too.
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Post by rcustoms »
Darksid46 wrote:на ver. 14 мод от darksid.Нет это не МОД.Это вер.14.0сновное ее название LIONSOUND 14.0 DarkAngel а смемотехника совсем другая ближе к ENGL530 в отличии от 12.0 .В 14.0 и SPSim тоже другой.
slap: :slap: sorry i dont speak ru. and the translation is not very accurate
rcustoms
Post by rcustoms »
Darksid46 wrote:
Darksid46 wrote:Вот новый СИМ
:D :D :D
and the pre amp schematic?
rcustoms
Post by rcustoms »
Darksid46 wrote:Да новый
if you could ? please share with us
thank anyway
J0K3RX
Has thanked: 316 times
Been thanked: 556 times
Post by J0K3RX »
Darksid46 - Где предусилитель?
J0K3RX
Post by J0K3RX »
He says that he would like to share but the actual project is not his.
I may have a go at the cab simulator... looks interesting and I have heard samples of the previous version with direct recording in a mix, sounded excellent! I am guessing this version is geared more towards being used with an ENGL type preamp.. more mids.
The G
Grease Monkey
Has thanked: 408 times
Been thanked: 284 times
Post by The G »
I got it! They're speaking only Russian so - after little time - Putin will come and conquer FSB to protect the right of Russians abroad :horsey: .
I've already applied for a diystompboxes passport :secret:.
sweeplikevai
Post by sweeplikevai »
Darksid46 wrote:Мой Жесткий Металл
awesome,. what are those pedals? care to share? :D
sweeplikevai
Darksid46 wrote:
awesome,. каковы эти педали? поделитесь? :D
Lionsund12.0 sound can be made as 5150 | OKKO Domimator-also very dense sound on OUT.Delo taste. :popcorn:
thanks bos..
any build instructions, schems, vero/pcb's,,? especially the lionsound(5150)... if you dont mind.. :D
GodSaveMetal
Has thanked: 138 times
Been thanked: 55 times
Post by GodSaveMetal »
you have the LIONSOUND 14?? please post all you have PCB; layout; external connetions!! thanks!
J0K3RX
Post by J0K3RX »
I regularly frequent the guitar-gear.ru forum.. I already had the LS12 layout but have not built due to the odd components, 1208 programmable opamp and 2SK163... I think the UA776 or LM4250 may be suitable substitutes for the 1208 but not sure? I may have a go at the cab sim portion of the circuit, if I get around to it..?
It sounds really good to me but not so much to inspire me to investigate further...
Would prefer to see the schem for the LS14 ENGL sim... I LOVE anything ENGL!
Darksid46 - Maybe you can direct us to the mysterious forum or secret laboratory where the "LionSound 14" that you speak of lives? Is it being guarded by the Russian Yeti in some forsaken part of Siberia? :twisted:
karul
Has thanked: 597 times
Been thanked: 259 times
Post by karul »
NTE888M - possible substitution for УД1208 (used in LIONSOUND)
http://modularsynthesis.com/kuzmin/poli ... ks_vcf.htm
sweeplikevai
Darksid46 wrote:Yes there is a circuit and PCB http://guitar-gear.ru/forum/topic/3724- ... _lionsound
thanks.. much appreciated.
back to topic.
pls post amptweakers ic1/ic2 voltages..
Levictus
Post by Levictus »
Hi fellas
Awesome work on the Tight Metal! :applause:
Does anyone have a pcb available for sale or would someone be interested in making one for me? Thought about doing OSHPark but don't think Eagle or Gerber files are available. Thanks in advance for your help, feel free to pm me if you want... :D
brejna
Has thanked: 68 times
Been thanked: 62 times
Post by brejna »
brejna wrote:If everything is ok with layout, here is the pdf.
REV1.1 There are errors on this layout :oops:
J0K3RX
Post by J0K3RX »
Does this layout work? I will build it if it does..
brejna
Post by brejna »
J0K3RX wrote:Does this layout work? I will build it if it does..
I think it should work, correction are for tonestack. I've put two wrong junctions and rev1.1 should cover that. I've seen there are differences in your schematics.. Also I did layout with chargepump..
brejna
Post by brejna »
Here are new files with corrections and onboard 18v charge pump..
Double Dragon 18v.pdf
(504.37 KiB) Downloaded 433 times
gogovoivoda
Post by gogovoivoda »
Wow ... what a thread. I read all 500 posts!!! Awesome work!!!
I just finished the TM and it sounds really GOOOOOD. Much better than all my commercial stomp boxes and anything I've ever diy-ed. It is brutal and yet natural both at lower volumes and cranked into a tube amp's return. There are a couple of things I wish to modify to my taste. Can anybody please help with advice and suggestions?
1. I don't like Noise Gate. Mine is wired to separate pot and seems to also lower the overall gain and distortion. It's audible even at low settings. The TM is actually quiet with a humbucker so I really don't need the gate that much. Just wondering if this is how it's supposed to work or is there something wrong with my parts or connections? Any links or suggestions for a mod that affects only the high frequencies?
2. Has anybody figured the exact purpose of the 1N4148 diode across V+ an V- of the first and third stages. Some posts suggest that they're for protection and others that they are for clipping. I'm asking because I generally do not like the way these sound as clippers and will consider getting rid of them.
3. The TM appears to distort more the lower frequencies and less the higher notes up the neck. This contributes to the more natural sound and to the fact that in open chords all notes are audible. I guess this is a result of the asymmetrical clipping of the zeners and the biasing of the clipping and the output stages. Is there a way to lessen this "effect" just a tiny bit so as to have more clipping at the higher notes . Should I try different zener values or experiment with the biasing of the clipping stages. What if I wired the output stage biasing with a trimmer. Will this enable me to "dial-in" different blends of the asymmetrically clipped negative and positive parts of the sine wave.
4. Has anybody tried a marshall type tone stack with the TM? Does it sound better? Any suggested values?
I will appreciate any advice and help! Thanks and cheers!
G.
Nicht Bernd
Has thanked: 98 times
Been thanked: 7 times
Post by Nicht Bernd »
Build it with the error-pcb, have to change it. And put 18v on it... :D
Thanks Brejna
Locked
