first time using metal film resistors
Postby jimiguitar » 12 Jun 2014, 23:45
first time using metal film resistors is there a size different between carbon 1/4 watt and metal metal film 1/4 watt i justt received my order from amazon and they look somewhat small than 1/4 watt carbons
jimiguitar
Re: first time using metal film resistors
Postby DrNomis » 13 Jun 2014, 09:23
jimiguitar wrote:first time using metal film resistors is there a size different between carbon 1/4 watt and metal metal film 1/4 watt i justt received my order from amazon and they look somewhat small than 1/4 watt carbons
Probably not, I buy 1/2 Watt metal film resistors from my local Jaycar Electronics store and they're about the same size as 1/4 Watt carbon film resistors....... :thumbsup
DrNomis
Has thanked: 123 times
Have thanks: 399 times
Postby grrrunge » 13 Jun 2014, 12:02
I buy the 1/4W metal films from tayda. they're also in a 0703 package
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby Frank_NH » 13 Jun 2014, 15:26
I purchased some 1/4 W metal film resistors on eBay, and while the body of the resistor is the same as the common carbon film types, the wire lead diameter appears somewhat smaller/thinner. I can check this difference with my micrometer tonight. I don't think it's a problem for vero or pcb builds - just something I noticed. I was speculating that a thinner wire was necessary to ensure 1% tolerance on the indicated values for low value resistors? (maybe not...)
Frank_NH
Has thanked: 18 times
Have thanks: 67 times
Postby Tall Steve » 13 Jun 2014, 16:41
Frank_NH wrote:I was speculating that a thinner wire was necessary to ensure 1% tolerance on the indicated values for low value resistors? (maybe not...)
Nah. The Tayda metal films have thinner leads than the Xicon metal films you get from Mouser for example, and they're both 1% tolerance. The thicker leads are easier to work with IMHO. They hold their shape better. If you're in the states, bulk pricing on the Xicons is competitive with Tayda. Two hundred Xicons can be had for $4 USD.
Free your mind...and your ass will follow. - George Clinton
Tall Steve
Has thanked: 15 times
Have thanks: 10 times
Postby Nocentelli » 13 Jun 2014, 18:22
I think thinner leads just means cheaper. I've only bought carbon film from tayda, but they're also thinner than from other sources. I've also got some RS labelled carbon film from years ago and they are way thicker and last much longer for repeated breadboard use than any modrn resistors i've bought.
Nocentelli
Has thanked: 871 times
Have thanks: 839 times
Return to Resistors
