Sola Sound - Tonebender Mark II Professional  [schematic]
Re: Sola Sound - Tonebender Mark II Professional
Postby Electric Warrior » 12 Aug 2014, 12:50
Gotta hate the lack of edit function in this part of the forum
Link
Electric Warrior
Has thanked: 20 times
Have thanks: 87 times
Postby boblob » 12 Aug 2014, 15:19
Electric Warrior wrote:
boblob wrote:The Sola Sound OC84 reissue that I have has 15nF caps in place of the 10s to compensate for drift. That's pretty important - sounds much more like a vintage unit if you do that (more mids, a little smoother up top, and just generally better). Up to 22nF on the output cap still sounds good with the Tungsrams.
I don't think that Dave uses the 15nFs to compensate for anything. Many vintage units had 15nFs, his own Vox included. He likes that sound a lot!
[ Image ]
[youtube]ohT4Chsa8hs[/youtube]
Read the whole story here: http://www.stompboxes.co.uk/Wifey.html
Ah yeah. Cool. Gotta love Wifey.
Mine had 10nF and all the schematics I'd seen had 10s, so I assumed wrong. A-B-ing with a set on Tungsram AC125s on the breadboard, 15nF got me much closer to the sound of the original. I had assumed drift/wide tolerance to be the reason (although differences in the way the transistors clip will come into it too).
boblob
Have thanks: 10 times
Postby Electric Warrior » 12 Aug 2014, 16:57
Right, different transistors do sound slightly different. My Valvo AC125s sound quite a bit brighter than my Philips OC75s.
Your Philips AC125s should work great for a MKII, btw. Make sure you use the OC75 variant of the schematic with 10k on Q1's base and 47k on Q2's collector.
Electric Warrior
Postby rosetta » 12 Aug 2014, 23:03
I built mine a few months ago, the trannies I used were from a smallbear kit oc75, I use some carbon comp resistor and a mustard cap, it sound great, but I got some of issues.
first; the 470ohm resistor used to control volume I had to rise it value, but I had to rise alot y mean on my built is 33K and it gives me a good range of volume to play with.
second: the attack pot doesn't make much difference at max or min.
third: whan I set a Micro POG before it the sound turns weak, duno maybe a impedance problem.
forth: the pedal is a little trebly, is there something i could mod to get more bass or les treble??.
so can any of you guys tell me how to fix the last three issues?Image
rosetta
Have thanks: 2 times
Postby Electric Warrior » 12 Aug 2014, 23:53
Did you use the schematic that came with the transistors? That tends to cause most of your issues. Small Bear biases Q3 at 4.5V, which makes it sound trebly and brings down the level. They use a 100k at Q1's base which takes a lot of range from the attack pot when used with OC75s.
Impedance problems with pedals/buffers in front of a MKII are quite common..
Electric Warrior
Postby rosetta » 13 Aug 2014, 03:43
yes I did, I followed their scheme, so what bias value you recomend? something higher or lower?.
on the base of Q1 I've got 10K, but the attack pot is connected to Q2 and it base has a 100k.
anyway I will make some probes.
THanks
rosetta
Postby Masuto » 13 Aug 2014, 09:26
rosetta wrote:I built mine
Where did you get that hot enclosure?
Masuto
Has thanked: 42 times
Have thanks: 5 times
Postby Electric Warrior » 13 Aug 2014, 10:28
rosetta wrote:yes I did, I followed their scheme, so what bias value you recomend? something higher or lower?.
THanks
With stock values and OC75s it usually ends up somewhere between 7.5 and 9V.
I can see an 8k2 resistor. If that's Q3's collector resistor things should be alright.
With that board you probably followed a later Supa Fuzz schematic. It's pretty much identical to the Sola Sound made version except for the 10µF electrolytics.
Electric Warrior
Postby rosetta » 14 Aug 2014, 04:22
they used to sale them on pedalenclousure.com, but the webpage doesn't work.
[ Image ]
yeap I followed a supafuzz schematic with the smalbear changes.
rosetta
Postby Masuto » 14 Aug 2014, 04:29
rosetta wrote:they used to sale them on pedalenclousure.com
Cheers. So they are basically unavailable as of now! Shame, shame, shameee.
PEDALENCLOSURE.COM PEOPLEGIVE US A BUZZ
Masuto
Postby Electric Warrior » 14 Aug 2014, 12:12
[ Image ]
Try it without any changes then. You may have to adjust Q2's collector resistor to bias it to the sweet spot between noisyness and gating, though.
Electric Warrior
Postby Nocentelli » 14 Aug 2014, 12:47
If it's a steel "Z wedge" enclosure, I have an unfinished one, undrilled (and unmarked apart from a couple of tiny tentative drill marks that would disappear under a finish). I bought without realising I didn't have the cojones (or drill bits) to drill steel, and you or anyone else is welcome to it for £10 + the cost of postage to wherever you are.
Nocentelli
Has thanked: 893 times
Have thanks: 855 times
Postby Masuto » 14 Aug 2014, 17:02
bajaman wrote:Of all the tonebenders, I really do like the MkII version - It nails the Hendrix Voodoo Child sound when you put a well tuned wah pedal in front of it too.
I don't think Hendrix ever used a Fuzz Face - If he did, I don't think he liked it from what I have heard from folks supposedly in the know - forget the other benders - build a MkII - you won't be sorry you did.
Call me sentimental, call me dumb.. But it's time to rehash the first post in this here thread.. And check this auction:
http://www.ebay.it/itm/JIMI-HENDRIX-EXP ... 697&_uhb=1
Masuto
Postby DrNomis » 14 Aug 2014, 17:19
Looks like I'm going to have to see if I can buy myself a trio of OC75s on eBay, since I've got a PCB kit for a Marshall Super Fuzz which I might build soon, I've already built a good sounding Mk II with some OC81Ds...... :thumbsup
DrNomis
Has thanked: 123 times
Have thanks: 403 times
Postby jalmonsalmon » 14 Aug 2014, 18:35
There it is... Marshall Super Fuzz justification to add to my pedal collection.
I am wondering if Jimi actually used that pedal on any recordings... :hmmm:
DrNomis wrote:Looks like I'm going to have to see if I can buy myself a trio of OC75s on eBay, since I've got a PCB kit for a Marshall Super Fuzz which I might build soon, I've already built a good sounding Mk II with some OC81Ds...... :thumbsup
Where did you get that PCB kit from? I was thinking about using a layout from Sinner but I like PCBs if I can get them :D
jalmonsalmon
Has thanked: 79 times
Have thanks: 23 times
Postby DrNomis » 14 Aug 2014, 19:01
I bought the Marshall Super Fuzz PCB kit online from Pigeon FX, the PCB is etched on Phenolic and comes with all the vintage style components you need minus the Transistors, I'd definitely recommend buying one of these kits, they're pretty good quality...... :thumbsup
http://www.pigeonfx.com/index.html
For this message the author DrNomis has received thanks:
jalmonsalmon (14 Aug 2014, 19:14)
DrNomis
Postby jalmonsalmon » 14 Aug 2014, 19:14
DrNomis wrote:I bought the Marshall Super Fuzz PCB kit online from Pigeon FX, the PCB is etched on Phenolic and comes with all the vintage style components you need minus the Transistors, I'd definitely recommend buying one of these kits, they're pretty good quality...... :thumbsup
Nice! That will save me time finding the mojo parts... Thanks! :applause:
jalmonsalmon
Postby DrNomis » 14 Aug 2014, 22:35
You're welcome, let me know how your build goes...... :thumbsup
DrNomis
Postby Masuto » 14 Aug 2014, 22:39
jalmonsalmon wrote:There it is... Marshall Super Fuzz justification to add to my pedal collection.
Are we hooked or whaaat :twisted:
DrNomis wrote:I've already built a good sounding Mk II with some OC81Ds...... :thumbsup
Follow you, follow me: i bought those very same dsi oc81d that you have like one year ago, never got around to make the build, the other day i fired the pro mk ii thread you posted, and right now i am building a mk ii with those dsi's into a WHITE PIgeon FX MK I enclosure. Good grief.
Party party, party party, party party :popcorn:
Masuto
Postby Masuto » 14 Aug 2014, 22:53
The vox tone bender vid that Electric Warrior has posted..
Now thats what i call oscillating, misbiased, porky mother of a pedal! Ahahah
Masuto
PreviousNext
cron
