CBS Arbiter - Doubler  [schematic]
Been thanked: 909 times
Any known schematic of one?
I'm just asking before I break my dick trying to draw one from pictures
tube-exorcist
Has thanked: 173 times
Been thanked: 67 times
Post by tube-exorcist »
Gary Hurst never invented anything on his own - therefore simply take a (correct) Foxx Tone Machine schematic and you´ve got it.
Alright, with that in mind I shouldn't have a need for willy physiotherapy
Okay, I got all I need
Over 200 mb of pictures. Two slightly different units
Big thanks to DAM forum member Rafmax and my bud BeeDot for hook me up with him
Full project later this week, quality shit takes time
Less differences than I thought
Exhibit one
BC549 transistors, compared to Foxx it have changed value of emitter resistor on Q1 + added bypass cap on there. Also sustain pot value is different and limiting resistor on sustain's pot wiper is insensibly larger and C11 cap in tonestack is 5nF (3nF in Foxx). No other differences. Oh, maybe the diodes, little blue ones, look silicon to me - Ba111 (?) unless 1n111 then germanium. Hard to say
My bad - R14 is actually 100k in the version above
It's 150k in other exhibit ;)
Other differences - all pots 100k Log, BC109 transistors all the way and 3n3 cap in tonestack
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
The diodes sound like they may be schottky mate, do they look like this:
tube-exorcist
Electronic Sounds Doubler uses 4 x BC173B.
Foxx Tone Machine Ver. II has also a bypass cap on emitter-resistor of Q1.
Normally there are 3 x 50kA Mitsubishi pots inside - maybe that sustain pot has been changed.
C11 tonestack cap is 3n9 on Electronic Sounds Doubler - on some Foxx Tone Machines you can find 4n.
Diodes are 1N4148 (red in other units) - yes, there have been made also blue ones (by ITT) - todays schottkys didn´t exist.
R14 is 150k in Electronic Sounds Doubler.
IvIark
Post by IvIark »
Ivlark thanks for vero
Tube exorcist thanks for ES info. Do you have any pictures of that one?
Any info about Moreschi Octafuzz?
In both units I had access to pots look stock, the same inprint on the body of the pot
tube-exorcist
I was actually hoping for bigger resolution picts ;-)
drewl
Been thanked: 11 times
Post by drewl »
So, octave up or down?
How does it sound?
Another one I've never heard of.
Foxx tone machine. The same crap, different package
Tones of clips on u tube
jalmonsalmon
Has thanked: 97 times
Been thanked: 30 times
Post by jalmonsalmon »
sinner wrote:Foxx tone machine. The same crap, different package
Was the Foxx Tone Machine the 1st incarnation of this upper octave circuit?
Never heard of the CBS Arbiter!
But thanks all for the schemo
bassetrox
Post by bassetrox »
The schematic has got losts in the mists of the internet since 2014. Could anyone repost it please? I've got one to repair.
Thanks,
sinner wrote: 26 Aug 2014, 20:06 Less differences than I thought
Exhibit one
