by Ice-9 » 06 Aug 2014, 10:56
JudgeMingus - has explained exactly what I meant, but I also don't have any pictures to hand. Using the cut off lead from a resistor or some solid core wire you can rebuild the broken trace by soldering the wire/lead from one component solder pad to the other component pad. Using solid core wire or a resistor lead will allow you to bend the lead to suit the shape of the track. If you use normal multicore or kynar wire for the repair it is easy to make a repair that may stretch over a distance on a pcb but as your repair is two pads right next to each other then the solid wire/lead is the better fix.
