My Pitch Pirate is pirating my pitch
Postby ElSpeakoDelSpanisho » 05 Sep 2014, 21:51
I've double, triple checked for solder/flux bridges between the traces. Still no sound when engaged, only my clean tone when bypassed. The 5mm LED on the board doesn't light up at all when turned on, but the PT2399 gets a bit hot to the touch. That's it. I have no IC voltage ratings since I don't really care about this pedal a lot, but if someone wants them I can go measure it.
Here's a link to the photo album. The voltage regulator in the pictures is NOT the one in there currently; it's now a 78L05, with the traditional transistor shape to it.
https://imgur.com/a/ajkX4
ElSpeakoDelSpanisho
Re: My Pitch Pirate is pirating my pitch
Postby DrNomis » 06 Sep 2014, 06:55
Have you tried using an audio probe to trace out the signal path to see where you're losing signal?...... :hmmm:
DrNomis
Has thanked: 123 times
Have thanks: 396 times
Postby ElSpeakoDelSpanisho » 20 Sep 2014, 20:07
Wow, I totally forgot I even made this thread. I just remembered five minutes ago.
I haven't probed it yet, I'll try when I have time.
ElSpeakoDelSpanisho
Return to Debugging
cron
