A completely different etching technique
Frequent question about boxes and accessories: painting, etching, clearcoating, lettering, glueing, and so on.
astrobass
Has thanked: 42 times
Been thanked: 74 times
Post by astrobass »
Has anyone tried the technique shown here? http://makezine.com/projects/make-40/etch-a-kettle/
Basically you combine vinegar and salt, attach the item to be etched to the + of a 9V battery, attach a q-tip to the - pole (exposed wire wrapped tight around the cotton part), dab the cotton in your salt/vinegar mix and then paint on.
Seems like a bit neater than masking and immersing in diluted FeCl.
Duckman
Has thanked: 320 times
Been thanked: 134 times
Post by Duckman »
Seems to be an interesting option for enclosure finishing :hmmm:
tabbycat
Post by tabbycat »
interesting. might be worth an experiment. i wonder if aluminium works better or worse that stainless steel?
btw have you seen the andy warhol 'oxidisation series' (aka 'piss paintings'). might some be potential in that (perhaps not for the faint of heart)?
on a tangent, i've done a lot of wet-process b&w film developing and printing in my time and have been wondering lately whether any of those techniques, even really low-fi early techniques (the daguerreotype and albumen prints) could be manipulated for the purposes of box decoration.
'liquid light' is modern option.
and am (slowly) getting back into screenprinting after a long break. will post results here if i get them onto any pedal enclosures.
allesz
Has thanked: 41 times
Been thanked: 97 times
Post by allesz »
Hey.
I used that etching method (a guy, maybe codemonk, posted it on diysb some time ago) for my small 1590LB pedalboard. I only added some black ink lines to the etches.
If you like simple graphics (like jhs fx) it's good and very easy/fast.
I used an old 12V power supply and a solution of salt and vinegar (then made a tasty salad :lol: ).
astrobass
Post by astrobass »
How easy is it to get a deep etch with that technique? It looks like it etches pretty cleanly, which is always a challenge with FeCl - it can be tricky to get it diluted just right so that it doesn't boil and make a huge dangerous mess with large pieces of aluminum. But is it quick? And can you get a nice deep etch?
allesz
Post by allesz »
Well, I never tried a different way, so I can't comment; I like etches, but I don't like using acids and tone transfer techniques... I use perfboad for my builds too.
I just put some white electrical tape on the pedal, draw what I like, then use a cutter to remove the inside of the figure.
Once the mask it's done, it takes two/three minutes to etch. It does not get so deep, but it gets quite clean.
Try it on a piece of aluminum and see if you like it, but forget such professional results you see on the picture tread of diysb.
tabbycat
Post by tabbycat »
i found this website last night looking for ideas for mini-amps and thought the design element of what this maker was doing was quite interesting, so posted this link in the amp section yesterday because i thought it might inspire like-minded souls here.
but as he appears to use the approach demonstrated above (about a sixth of the page down: battery, wires, acid in hypos... am assuming they're not recreational) in a context that directly relates to our purposes, i thought i might post it here too.
http://www.mylkstuff.com/USERIMAGES/AMP ... -386-4.JPG
definitely worth checking out his design process notes and experimentation for his mini-amp builds. lavishly documented and well-researched. reads like a coffee-table book for the aspiring diy builder. impressive i think.
more here:
http://mylkstuff.com/page70.htm
(links to his 'amp notes', 'research', 'inspiration' and 'design ideas' can be found on this page).
