*best* LDR for Mutron III / Neutron circuit
digi2t
Has thanked: 54 times
Been thanked: 385 times
Post by digi2t »
Here is my tutorial for rolling your own Vactrol for the Mutron. I used a clear bright white LED, and two Waitrony KE-10720 LDR's.
https://www.diystompboxes.com/smfforum/ ... ic=95269.0
The only thing I recommend is that you match the LDR's. I took a piece of wood, drilled two holes at the lead spacing of the LDR, and set it in a vice, underneath a light source that I could control the intensity. Pop an LDR into the jig, ensuring that it's sitting flat against the wood, and pointing directly at your light source. Connect you DMM to the LDR leads. Set your light source to an intensity where you get somewhere in the neighbourhood of a 10K reading from the LDR, it doesn't have to be exact. Write the reading down. Now, pull that LDR out, and insert another one in it's place. Connect the DMM, and take a reading. Compare the reading to the first one.
Keep going, until you get two LDR's that are within 100, to 200 ohms of each other. The Waitrony's are dirt cheap, so buying 10 or 20 of them won't break your bank. Definitely cheaper than VTL's. You'll be able to match up several sets.
No matter how many times I cut it, it`s STILL too short!
https://www.deadendfx.com/
rrroo
Post by rrroo »
I built the madbean version of this pedal. made my own LED/LDR. everything seemed to work in UP mode but not in DOWN mode. I found out that the bias voltage at op amp, defined by R18 and R19 is not optimal. if you replace these with a trimmer working as a voltage divider, you can dial in just the right filter sounds and the choise of LED/LDR is not that crucial.
吉田ほにお
Post by 吉田ほにお »
Hello rrroo.
I also made Mutron, but I have a problem. down mode works, but up mode doesn't. There seems to be no change even when listening to the sound. You said you adjusted the bias, do you need to adjust it to a value suitable for up and down each time?
Did you make the capacitor of the filter part with 1n8 2n2?
bmxguitarsbmx
Has thanked: 705 times
Been thanked: 216 times
Post by bmxguitarsbmx »
Up/Down requires a SPDT switch to operate properly in up and down mode.
The first section of the SPDT switch increases gain to the envelope circuit. The second section of the switch switches the LED driver from Non-inverting in "Up" mode to Inverting in "down" mode. Notice that when in Inverting mode, a separate bias is also switched in via voltage divider resistors.
If a schematic was posted, further clarity could come from using part numbers.
吉田ほにお
Post by 吉田ほにお »
dear bmxguitarsbmx
thank you for your reply. I'm flipping the switch in two places, but I'm having problems. It works with down, but up doesn't. Does the capacitor in the filter section operate at 1n8f and 2n2f?
It seems that there is a slight change in the sound when listening carefully in the up mode, but it is not as clear as in the down mode. The time for change is very long.
I recently tested another wah, but the up mode didn't work at that time either. The optocoupler wah is very difficult to adjust.
I would appreciate any hints.
吉田ほにお
Post by 吉田ほにお »
bmxguitarsbmx
The second section is to switch the LED driver from non-inversion in "up" mode to inversion in "down" mode, but since down is a + input, isn't it non-inversion?
Is it necessary to switch the range switch when switching down and up?
I tested it again and it feels like the up doesn't work. There is no change in sound quality.
bmxguitarsbmx
吉田ほにお,
The schematic I have has "Down" with the + input to the LED drive connected to the resistor divider that sets the static frequency. The envelope is connected to the LED drive through standard inverting setup.
You do have to change the range when switching between down and up. Let's take and example of setting the static frequency at 40Hz. 40Hz is a great starting point for UP mode and you are sweeping the filter up into the audible range. 40Hz would not work in DOWN mode because you are essentially below all frequencies you can hear, and sweeping, down, below 40Hz is also inaudible.
I think what I might do is measure the voltages at the output of the LED drive and determine what the useful range of voltages are. Then monitor those voltages while playing to get an idea of where you are.
Also, what modes do you have hooked up? If the filter is way above hearing range in low pass mode, it will appear to do nothing. Same with the filter operating below hearing range in high-pass mode. Likely, very low Q settings will also seem to not be working.
bumblebee
my favorite amplifier: ‘65 Twin Reverb
Completed builds: Fuzz & Preamps mostly.
Has thanked: 231 times
Been thanked: 58 times
Post by bumblebee »
I’ll just upload this here for those who don’t have it.
MuTron III neutron Project - R.G. Keen.pdf
(1.28 MiB) Downloaded 199 times
I so dislike the modern digital world that I need to use semi-digital effects to emulate the analog world of cassette, VHS, and vinyl.
吉田ほにお
Post by 吉田ほにお »
Bumblebee
Thank you for the article.
bmxguitarsbmx
The current of the output of the LED drive was measured.
In the up mode, the silence state is 0.27ma at the maximum when playing at 0.04ma. When you stop playing, it will drop from 0.27ma, but it will take a long time to change the sound quality due to the long release or decay. Nothing has changed for a while. If you can adjust this changing time, it will be easier to feel the change in sound quality. When I tried the condenser of the filter part and set it to 4.7n, the change became noticeable a little.
In down mode, the silence state is 0.00ma at maximum when played at 0.27ma. When you stop playing, it will increase from 0.00ma. You can clearly see the change in sound quality here. There is a filter effect even if the current change does not change. The condenser seems to be fine with 1n8.
The down mode is effective because it can be heard with 3 types of filters.
In the up mode, you can hear the low pass, but it is difficult to hear the band pass and high pass.
Is it possible to improve the way the sound quality changes are heard by adjusting the release or decay in up mode?
bmxguitarsbmx
Thank your the numbers. I think that gets us somewhere. 0mA - 0.27mA is barely turning on a LED. Let's increase the current through the LED by decreasing the value of the current sensing resistor (Rx in the scheme posted by Bumblebee). I'm just guessing but, I think you may want to shoot for current values between 5mA and 20mA for your static value in the DOWN mode.
吉田ほにお
Post by 吉田ほにお »
bmxguitarsbmx
I adjusted the LED current, but I can't adjust it to the range of 5mA to 20mA.
Currently, I am referring to Mad Bean's Naughty Fish.
Adjusted with a combination of 5kpot and 330Ω. The photocoupler used is lcr-0202. When down, 5kpot is the minimum (330Ω only) and 1.74ma in silence. You said that the current changes in the range of 5ma to 20ma when down.
Is that a thing?
In Mad Bean's Naughty Fish, the bias voltage due to voltage division is around 3.61v when down, but if you adjust to this voltage, the wah effect will disappear.
voltage
voltage
bmxguitarsbmx
吉田ほにお wrote: 04 Mar 2022, 12:20 bmxguitarsbmx
...You said that the current changes in the range of 5ma to 20ma when down.
Is that a thing?
In down mode, current through he LED will be high current when not playing and low current when playing. The higher the current, the brighter the LED, the lower the resistance value of. the LDR, and the higher the frequency of the filter. I dont know the sensitivity of your LDR's, but LED's are not very bright at less than 1mA. It seems to me that you will want to adjust it to a higher current value 5mA to 20mA with no input signal present. Then when you hit a note, the current will drop, giving yo the sweep. The current values you listed are so low, I don't see much of a sweep happening. Hopefully that makes sense.
吉田ほにお
Post by 吉田ほにお »
Thank you for your reply. Thank you for your advice.
For the time being, I made it according to the circuit diagram and layout, but it does not work well. I am thinking of reviewing the specifications of the parts again. First of all, I would like to improve the accuracy by changing the resistance to a metal film resistance.
Should I also replace the optocoupler lcr-0202?
Photocoupler specifications
Has thanked: 1675 times
Been thanked: 1360 times
Post by Manfred »
I have a Mutron on the workbench and the first thing I did was check to see if the O805 optocoupler was still working.
Yes, it works so I plotted its P-N junction curve of the LED with my Peak Atlas DCA Pro, as well as the LDR curve as a function of LED current.
The dark resistance of LDRs are 221 Kiloohms. Both LDRs have identical values and seem to have been selected.
This Kingbright WP2523SURC/E T-1 3/4 (5mm) Round LED could be a good candidate for a DIY O805 replacement.
WP2523SURC-E.pdf
(303.69 KiB) Downloaded 102 times
kiltro
Post by kiltro »
I'm thinking about using VTL5C3 or the double one VTL5C3/2.
If I use two single ones should I connect them in series (like in the RG keen project) or in parallel like here viewtopic.php?p=289680#p289680
Schermata 2023-01-30 alle 11.03.00.png (23.14 KiB) Viewed 8171 times
Post by Manfred »
I created this Mutron III PCB clone for troubleshooting.
I took the component identifiers and the values from the factory circuit diagram.
It was an unexpected fault, part of a trace under A5&A5 was oxidized away.
Probably battery acid from a leaking battery, there was also a small oxidized area inside the housing.
There were small differences in the Mutron III on the bench.
The value of C10 is 10uF instead of 15uF, the value of C8 is 3.3uF instead of 4.7uF.
The value of C23 is the factory setting and is 2.2k here.
Ready-to-print PDF-files:
Mutron III component side.pdf
(34.6 KiB) Downloaded 51 times
Mutron III solder side.pdf
(15.26 KiB) Downloaded 55 times
Gerber and drill files:
Mutron3_Gerber&Drill.zip
(32.02 KiB) Downloaded 54 times
Sprint-Layout 6.0 file:
Mutron3.zip
(41.94 KiB) Downloaded 49 times
Mutron III on the bench:
twotees
Been thanked: 7 times
Post by twotees »
Manfred, With the Component side PDF of yours on the Mutron III you have the op amps listed as 1558, Which op amps are these?
As I see elsewhere on original schematics that they are listed as 4558 rc. So which were the op amps used in the original Mutron III ?
Also see some substitute with NE5532, would these perhaps give a better result?? Thanks
Post by Manfred »
In the factory schematic, all OP amps are specified as 1558.
The Mutron on my bench shows two RC4558BP and one RC4558BN.
Since the device works, I leave this in its original state so as not to reduce the value.
Yes, in some modifications the lower noise NE5532 are recommended for the signal path to achieve less noise, which would be recommended for a replica.
twotees
Post by twotees »
What then is a 1558 op amp? is that like a LM1558 ??
And are you sure that's what the factory original schem has noted on it?
because I have checked a few examples of the factory schem online , and it looks very much like it is a 4558 with r.c written after it. The 4 looks subtly a little like a 1, However I feel it was more intended as a 4. just badly written and printed. Making the factory schem. more likely representative of RC4558 op amps being used.
mauman
Has thanked: 436 times
Been thanked: 184 times
Post by mauman »
The datasheet specs for the TI LM1558 and the JRC NJM4558 are nearly identical, so they should work equally well.
