Ramble FX - Marvel Drive 1.0  [traced]
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
I think this covers it
[updated below]
Frank_NH
Has thanked: 114 times
Been thanked: 154 times
Post by Frank_NH »
Excellent IvIark! I think I have all the parts for this - may have to build this one soon! Thanks everyone... :applause:
RambleFX
Been thanked: 11 times
Post by RambleFX »
jubal81 wrote:I redrew for clarity. Looks pretty reasonable. The only thing I see as weird are the parallel 220uF & 100uF caps on the source of the 'normal' j201 input.
Here's a link to the full image
[ Image ]
Much easier to read, but a couple mistakes. There is a 180pf cap to ground at the gate of Q2, and the 22n coupling cap after the 'normal' JFET should be before the 'normal' pot.
IvIark
Post by IvIark »
Yes someone just pointed out the 22n, this corrects it and shaves off a column.
[aarrgghh]
PedalBlotter
Been thanked: 8 times
Post by PedalBlotter »
HA :D
Mine is not easy to read, but it´s correctly :horsey:
jubal81
Has thanked: 50 times
Been thanked: 30 times
Post by jubal81 »
IvIark wrote:Yes someone just pointed out the 22n, this corrects it and shaves off a column.
I've got this thing working. One other thing: The Source of Q4 needs to be grounded - meaning another cut to separate the drain of q5 & source of q4.
It's a pretty good sounding effect.
IvIark
Post by IvIark »
Sassinfrassinrassin!! Cheers for the heads up
jubal81
Post by jubal81 »
Here the corrected schematic.
Cheers to Mr. Ramble for piping in. :applause:
Great job on this. I love the plexidrive and this really gives it a run.
Ramble FX Marvel Drive 1.0 schematic
jalmonsalmon
Has thanked: 97 times
Post by jalmonsalmon »
So as I see in IvIark's layout, there is only one 330uF cap on that j201's input and those other 2 electrolytic caps are not necessary? :hmmm:
Saves 2 rows of vero so that's cool :thumbsup
Thanks all for the schemo and layout! Cannot wait to make this one.
IvIark
Post by IvIark »
The original had a 220u and 100u in parallel giving you 320u. I've just opted for a single 330u cap instead to save space as it is in keeping with the 1987X input stage. All the other caps are there.
mmolteratx
Has thanked: 93 times
Been thanked: 619 times
Post by mmolteratx »
FWIW, you could substitute it with a cap as small as 10µ and have the exact same operation in the audio range, which extends pretty far below the guitar range. 330µ is crazy. Just means full gain extends down to .6Hz. 10µ means it goes down to 19.4Hz.
FuzzMonkey
Has thanked: 44 times
Been thanked: 27 times
Post by FuzzMonkey »
Many thanks for the schematic.
johnk
Has thanked: 36 times
Been thanked: 293 times
Post by johnk »
I built one using IvIark's vero and it sounds great. thanks guys for posting the schematic and the layout!
bucksears
Has thanked: 16 times
Been thanked: 41 times
Post by bucksears »
Bumping this one:
How imperative is the 220uF cap on the 9V supply? Can I get by with 100uF?
I've got a 35V 220uF cap, but that thing is pretty big to fit between two trimpots.
IvIark
Post by IvIark »
bucksears wrote:How imperative is the 220uF cap on the 9V supply? Can I get by with 100uF?
Yes no problem using 100u
ppluis0
Has thanked: 127 times
Been thanked: 299 times
Post by ppluis0 »
Hi there,
The J201 fet's can be replaced -say- with MPF102 adjusting adequately the trimpots at their drains ??
bucksears
Post by bucksears »
Thinking about whipping up a PCB based on the schematic for this one.
It's my first vero build (always used PCBs prior) and it WORKS (technically), but the sound is VERY thick/Big-Muff like. I've got it running on 9V and the trimmers at 4.5V on the drain of the JFETs (J201s). Seems like too much compression going on - too woofy, loose in the low-end. Not at all like I heard in Brett's demo.
I'll go through it again, but there are no solder bridges and the part values are correct.
bucksears
Post by bucksears »
Ok, made some headway.
I replaced the J201s with 2N5457s, which is my preference (most of the time) in my BSIAB II.
This made it a GOOD distortion/OD (better than it was), but there was still something missing. I pulled the last .0022uF cap (just before the master pot) and that made a LOT of difference. It brought in a lot more presence that was missing before; I could dial up the treble pot to a little over halfway and the normal pot to about half. There is now much more 'kerrang' going on, but a bit too much treble.
That cap position MIGHT be better with either a .001uF or 560pF, if anything.
The other thing is there is still too much loose low-end in the normal channel. Turning the gain up on that is still too fuzzy, not tight.
Caferacernoc
Post by Caferacernoc »
"The other thing is there is still too much loose low-end in the normal channel. Turning the gain up on that is still too fuzzy, not tight."
That is what a real SLP sounds like. A lot of those guys back in the day ran middle and treble dimed with the bass nearly off unless they were going for the "woman tone".
As for Brett's video he clearly likes a tighter high gain sound so he probably set the Laney amp's clean channel he plugged into accordingly.
bobo
Post by bobo »
How to add presence pot same as version 2
