Rubber feet just... fall off
Collection of answers to the basic questions of stompbox building.
Postby bishop vogue » 17 Nov 2014, 00:19
I've done dozens of builds now, but one thing I still can't do well at all is getting rubber feet to actually stick to the bottom of my enclosures. After I paint and clear coat, I usually attach the little transparent feet that are designed as bumpers, but they always fall off. What do you guys do for feet? :scratch:
bishop vogue
Re: Rubber feet just... fall off
Postby Crowella » 17 Nov 2014, 00:24
I've had no issue with using the 3M adhesive brand feet, even after finishing. I'd say add a tiny bit of epoxy and/or gently scuff up the area where you are putting the feet just to give the adhesive more to hold onto. Hmm... :hmmm:
Crowella
Have thanks: 9 times
Postby Duckman » 17 Nov 2014, 04:39
Same here... 3M is the thing and not a problem 'till today.
But -and at risk of being obvious- consider that if you or somebody else will use Velcro at the bottom, rubber feets are a waste.
Duckman
Has thanked: 367 times
Have thanks: 125 times
Postby tonyharker » 17 Nov 2014, 11:40
Super (Crazy) glue ?? :)
tonyharker
Postby FiveseveN » 17 Nov 2014, 12:51
There are rubber feet that are designed to be attached with screws, which can be the same screws that keep the lid on, though may need to be a bit longer than the ones that come with the box. For Velcro users and such they are easy to remove.
Kind of like these, but smaller: http://mouser.com/ProductDetail/Hammond ... x8wl25EjQD
FiveseveN
Has thanked: 125 times
Have thanks: 47 times
Postby ljn » 30 Nov 2014, 18:47
tonyharker wrote:Super (Crazy) glue ?? :)
If you really intend for them to stay on, the yes. Super glue works great. I used some for my fuzzrite clone. For the actual rubber feet, I cut four little square pieces of rubber that I found in an old radio. They haven't came loose yet.
Education is 10% knowledge and 90% brainwashing. We're only told what they want us to know. The rest is fabrication in it's purest form.
ljn
Have thanks: 8 times
Return to Stompbox Builder's FAQs & How To's
