VOX (JEN) Tone Bender - circa 1966 - 197(?)  [schematic]
Re: VOX (JEN) Tone Bender - circa 1966 - 197(?)
Postby modman » 23 Nov 2014, 21:58
LucifersTrip wrote:
sinner wrote:Nice, I see nothing (cheep shit screen I have here).
It's low gain transistor 10-40hfe... and NPN indeed
according to this, it's a power transistor....which is doubtful
http://transistor-spravochnik.ru/descri ... n5580/5047
I built the ge version a while back with this schematic:
[ Image ]
It's a smooth, thin & very trebly (look at in/out caps!) fuzz with very good sustain. If you don't like the mushy-ness or darkness that you can get with some ge FF's, this is for you!
At the time, I had no idea what Q2C voltage was supposed to be, so I have an external pot. I believe Solidhex noted that it should be a bit higher than a Fuzz Face...but how high? Were there voltage measurements from an original in any threads here....
For this message the author modman has received thanks:
sinner (23 Nov 2014, 22:45)
Has thanked: 3172 times
Have thanks: 589 times
Postby modman » 23 Nov 2014, 22:08
More 60s Vox SFT transistor Tone Bender guts
Postby modman » 23 Nov 2014, 22:14
And here's a third one with still other caps
Postby sinner » 23 Nov 2014, 22:44
Yep. They comes in all sorts of different flavours cap-wise
I got it covered and documented here
The ones ain't know shit about are the ones with silicon transistors. You know, the same board's layout but with silicons. Not the later ones with clipping diodes
Has thanked: 1240 times
Have thanks: 1100 times
Postby ringworm » 24 Nov 2014, 11:51
Regarding the silicon transistors, does someone know 'The Captain', to ask him? If the silicon gut-shot is indeed his... http://stompboxes.co.uk/forum/viewtopic.php?f=6&t=171&hilit=sound+like+dog+shit&sid=8a36b8a141b7fd174ebbde86d62cc9b5&start=10#p12741
I definitely think one is 2N5550 but I can't read the other.
ringworm
Has thanked: 26 times
Have thanks: 78 times
Postby sinner » 24 Nov 2014, 12:07
I have RE to many DAM and EFE pedals to be brave enough to ask him ;)
Postby ringworm » 24 Nov 2014, 14:39
I'm sure he appreciates your attention to detail :wink:
ringworm
Postby polifemo » 26 Apr 2015, 06:47
Got one of these at home right now.
6.1v on Q2's collector.
polifemo
Have thanks: 2 times
Postby polifemo » 26 Apr 2015, 07:04
Here are some pics
Great sounding unit!
polifemo
Postby The Rotagilla » 08 Mar 2016, 19:07
Question for you guys. RG Keen’s schematic shows a 47k resistor in parallel with the 500k volume pot which (and correct me if I’m wrong) drops the value of the volume pot to 42.96k. Fuzz Central’s schematic omits the 47k resistor and shows a 50k volume pot. My question is this…is there any particular need for the 47k resistor?
The Rotagilla
Have thanks: 57 times
Postby ljn » 08 Mar 2016, 22:22
Using the 47k resistor in parallel with the 500k volume pot cuts bass. If you use a 50k pot for volume, it isn't necessary.
For this message the author ljn has received thanks:
The Rotagilla (09 Mar 2016, 00:07)
ljn
Have thanks: 8 times
Postby The Rotagilla » 09 Mar 2016, 00:07
ljn wrote:Using the 47k resistor in parallel with the 500k volume pot cuts bass. If you use a 50k pot for volume, it isn't necessary.
That's what I thought, just wanted to check. Thanks!
The Rotagilla
Postby ljn » 10 Mar 2016, 04:22
Glad to help. Just remember that in these fuzz circuits, a smaller value on the volume control will always cut bass.
ljn
Postby The Rotagilla » 10 Mar 2016, 15:43
Also wondering about the resistor that goes from lug one to ground on the fuzz pot. I've seen schematics with a value of 820r and 8k2, has anyone verified that an 8k2 was ever used or is it a color band reading error?
The Rotagilla
Postby ljn » 11 Mar 2016, 03:48
Every schematic and gutshot I've seen of this circuit has a 820 between lug 1 of the attack control and ground. If you tried a 8k2, it would be so distorted that it would barely pass signal (if at all ).
ljn
Postby LaloFP » 04 Aug 2017, 12:57
Hi!
So.. is there any news about the Si transistors? Gains?
Some mension 2n5550 or 2n5551 for one, but dont know about the other.
:horsey:
LaloFP
