I wanna put an OD and a Boost into one enclosure and then be able to use a a toggle switch to choose the order. In other words I want the option of having the OD go into the boost or vice versa.
Thanks in advance.
Barcode wrote:This may help, though I'm not sure. It is a switching pattern i came up with for switching a booster from the middle of the effects chain to being in the effects loop of an amp and vise versa. uses only a 3pdt
super velcroboy wrote:Barcode wrote:This may help, though I'm not sure. It is a switching pattern i came up with for switching a booster from the middle of the effects chain to being in the effects loop of an amp and vise versa. uses only a 3pdt
This won't work for what the op is asking for. This configuration only allows for 5 connections to be made.
He wants to switch the order of 2 pedals before hitting the front of the amp, and this requires 6 total connections.
Its actually pretty hard to achieve this with a single passive switch. You need multiple double throws to achieve this. The only switcher i know that does this is the switchblade, which is over a grand $$.
If anyone knows of a better way, tell me
Barcode wrote:super velcroboy wrote:Barcode wrote:This may help, though I'm not sure. It is a switching pattern i came up with for switching a booster from the middle of the effects chain to being in the effects loop of an amp and vise versa. uses only a 3pdt
um, the switchblade is like 50 bucks used, and the nano one is like 40 new.
super velcroboy wrote:Barcode wrote:super velcroboy wrote:Barcode wrote:This may help, though I'm not sure. It is a switching pattern i came up with for switching a booster from the middle of the effects chain to being in the effects loop of an amp and vise versa. uses only a 3pdt
i wish...
http://www.soundsculpture.com/products/switchblade.htm
