Infrared Potentiometer in PT2399 delay
Collection of answers to the basic questions of stompbox building.
Postby pecfor » 17 Jan 2015, 20:49
Hi Guys,
this is the first time I put a new topic on. I've a simple idea but I don't know how to get started with it.
I'd like to modify a PT2399 delay swapping the time and feedback pot with infrared sensors. I've noticed that normally the IR sensor give a variable voltage in output. How can I substitute a standard pot (with is a variable resistance) with a IR sensor without messing up the circuit?
In the PT2399 for example, pin 6 is normally connected to a 20K pot in order to vary the time repetitions. If I'd want to remove the pot and put an IR sensor there, how should I change the circuit?
Thanks a lot!
pecfor
Re: Infrared Potentiometer in PT2399 delay
Postby pecfor » 17 Jan 2015, 23:39
Anyone?!?!?!
pecfor
Postby Nocentelli » 18 Jan 2015, 11:46
I imagine you would need to send the voltage output from the IR sensor to an op amp or transistor, using the voltage to control the output of the amplifier to drive an LED, and use the LED's brightness to control the resistance to ground of the delay pin via an LDR. You might need to invert the response of the amplifier if you wanted more IR~>longer delay.
I typed "IR sensor to resistance" into Google, and the second result:
https://www.google.co.uk/url?sa=t&sourc ... -ZBr_MzVeg
Shows how an IR sensor can be set up to output a scale-able voltage (presumably could act as a sensitivity pot).
I'm interested in how you plan to use this - Perhaps you could use an LDR instead, and control the delay directly with visible light rather than use IR and a string of associated circuitry?
For this message the author Nocentelli has received thanks: 2
pecfor (19 Jan 2015, 02:30), rocklander (22 Jan 2015, 04:48)
Nocentelli
Has thanked: 850 times
Have thanks: 831 times
Postby ~arph » 18 Jan 2015, 11:48
Why IR? I believe IR sensors are usually photo diodes/transistors and therefore are more suited to act as a logic switch rather than a variable resistance. I'm not saying it can't be done, but it would require additional circuitry to get it to replace a pot. also note that if the pot is not wired as a variable resistor (only two lugs used ) you need a more complicated circuit.
Edit: nocentelli posted at the same time as me, here is my comment anyway
For this message the author ~arph has received thanks: 3
Nocentelli (18 Jan 2015, 11:58), pecfor (19 Jan 2015, 02:30), rocklander (22 Jan 2015, 04:48)
~arph
Has thanked: 63 times
Have thanks: 166 times
Postby grrrunge » 18 Jan 2015, 17:10
I've recently built a line sensor for use with robotics, that utilizes IR LED's and IR photodiodes. It's simple and less prone to pick up noise from the ambient light around the sensor circuit than solutions using LED's and LDR's.
IR photodiodes put out small currents, so you'll want to build a transimpedance amplifier, that'll convert the current from your photodiode to a DC voltage. With that DC voltage, you can then control some sort of voltage controlled resistor circuit.
It should be possible to build the entire circuit around two MOSFET's ;)
For this message the author grrrunge has received thanks: 2
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby grrrunge » 18 Jan 2015, 17:16
grrrunge
Postby pecfor » 19 Jan 2015, 02:58
Nocentelli wrote:I
Hi! thanks for your precious advice! I think using only the LDR would be a problem because it could be affected by the different lightning conditions in the room? with the IR calibrated for a short range I might be able to control precisely the variation of the time with my hand.
I found this: http://revolutiondeux.blogspot.co.uk/20 ... oller.html
I think I could use the same circuit with a IR instead of the antenna?
pecfor
Postby pecfor » 19 Jan 2015, 03:02
~arph wrote: also note that if the pot is not wired as a variable resistor (only two lugs used ) you need a more complicated circuit.
Hi! interesting... Yeah I didn't considered the other option... Could you give me an advice in case of the pot is not a variable resistor? I guess I should play with the circuit before the optocoupler... Thanks a lot guys!
pecfor
Postby Nocentelli » 19 Jan 2015, 06:41
Most PT2399 delays I've seen just need a single variable resistance between pin 6 and ground.
Nocentelli
Postby pecfor » 19 Jan 2015, 10:14
Nocentelli wrote:Most PT2399 delays I've seen just need a single variable resistance between pin 6 and ground.
Ues you're right but I was planning to modify also the feedback pot (repeats)... And that one looks like a problem to me!
pecfor
Postby ~arph » 19 Jan 2015, 12:35
Well it totally deplends on how you intend to make the IR sensor output into a variable resistance. But the simple generic solution is to use two IR sensors and invert the output of one, so they both go in different directions. One causes a decrease of resistance then light enters it while the other causes an increase. This way you have both sides of the pot.
pecfor (19 Jan 2015, 13:16)
~arph
Postby pecfor » 19 Jan 2015, 13:14
~arph wrote:Well it totally deplends on how you intend to make the IR sensor output into a variable resistance. But the simple generic solution is to use two IR sensors and invert the output of one, so they both go in different directions. One causes a decrease of resistance then light enters it while the other causes an increase. This way you have both sides of the pot.
totally right! thanks a lot!
pecfor
Postby Dirk_Hendrik » 20 Jan 2015, 12:20
What's needed in essence is a current control between 6 and ground. So what's needed is a IR to current controller.
The Yerasov schems seem lika an axcellent starting point again.
Has thanked: 250 times
Have thanks: 1007 times
Return to Stompbox Builder's FAQs & How To's
