when to braid wires and when not to?
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
Postby zilla » 28 Jan 2015, 00:12
In an effort to try and clean up the wiring in my builds i'd like to try and start to braid the wires going to the pots.
i'm guessing/assuming that tone controls shouldn't add noise, but gain and volumes controls make me nervous, especially with high gain pedals like the dr. boogie.
can i safely braid the wires going to the gain and volume pots without adding noise or oscillation?
thanks
zilla
Re: when to braid wires and when not to?
Postby FiveseveN » 28 Jan 2015, 13:20
Wires in proximity form a tiny parasitic capacitor. Depending on what signals flow through those wires, it might actually reduce noise or HF oscillation (e.g. in a negative feedback loop) or horribly aggravate it (e.g. coupling input and in phase output).
FiveseveN
Has thanked: 132 times
Have thanks: 52 times
Postby grrrunge » 28 Jan 2015, 13:58
Twisting the wires introduces inductance as well, providing higher resistance for higher frequency AC signals. That could probably eliminate some HF-noise, if used carefully.
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Return to Switching & Wiring
