help with my component
Postby gearstack » 01 Feb 2015, 17:52
Im actually new in building guitar effects. And some circuits required the 1uf film capacitor and I only have the non polar 1uf in hand. Can I use the non polar as a replacement with the required film caps? Will it do the same job as the film?
Thanks,
Chris
gearstack
Re: help with my component
Postby D-Day » 01 Feb 2015, 18:03
Yes.
D-Day
Mojo Book Buster
Has thanked: 109 times
Have thanks: 23 times
Postby Nocentelli » 01 Feb 2015, 21:46
Post a schematic or layout of what you're working on in case the orientation of a polar replacement cap is important.
Nocentelli
Has thanked: 878 times
Have thanks: 844 times
Postby induction » 02 Feb 2015, 16:19
Nocentelli wrote:Post a schematic or layout of what you're working on in case the orientation of a polar replacement cap is important.
He specified that his replacement cap was non-polar.
induction
Has thanked: 63 times
Have thanks: 132 times
Postby Nocentelli » 02 Feb 2015, 16:44
doh
Nocentelli
Postby gearstack » 02 Feb 2015, 18:42
I have already replaced the film with a non polar into my circuit board. Well, its working but I didnt know if it sound the same with the film in place. Im building the guvnor with mods. And one mod here is to replace one component with a 1uf metal film. But no luck rather than placing a non polar instead. Will it have different output sound by replacing it with non polar or just the same?
Another question, Im using 1% tolerance resistor (blue ones) can I mixed it up with brown resistor under one circuit?
Thanks,
Chris
gearstack
Postby Nocentelli » 02 Feb 2015, 19:30
gearstack wrote:Will it have different output sound by replacing it with non polar or just the same?
There's a 35-page thread here "discussing" whether different cap types of the same capacitance value sound the same: viewtopic.php?f=43&t=8625
I'm fairly sure i wouldn't be able to tell the difference between a film or non-polar electrolytic 1uF cap in a blind test.
Yes, you can mix resistor tolerances and nothing will go wrong.
Nocentelli
Return to Capacitors
