Nutube: Korg e Noritake
Toobs
Postby Pruttelherrie » 30 Jan 2015, 09:52
Cool stuff: http://www.synthtopia.com/content/2015/ ... uum-tubes/
I wonder if they will be 12AX7-ish so we can build compact tube pedals.
Pruttelherrie
Has thanked: 48 times
Have thanks: 111 times
Re: Toobs
Postby bajaman » 30 Jan 2015, 10:28
yes :applause:
Has thanked: 413 times
Have thanks: 1406 times
Re: Toobs
Postby sinner » 30 Jan 2015, 10:37
Yep. I've seen that one discussed on the AmpGarage
Can't wait to get my hands on it
Has thanked: 1240 times
Have thanks: 1099 times
Re: Toobs
Postby deltafred » 30 Jan 2015, 22:14
Looks very interesting, I'd like to see the spec sheet and transfer curves.
deltafred
Has thanked: 370 times
Have thanks: 257 times
Re: Toobs
Postby Duckman » 30 Jan 2015, 22:33
Brilliant!! :applause:
Now the vintage tube market will be rocketed to brand new arguments :mrgreen:
Duckman
Has thanked: 368 times
Have thanks: 125 times
Re: Toobs
Postby krome_magnon » 31 Jan 2015, 00:35
Buy as many as you can when they hit the open market.
By the middle of 2016 the first ones out of the factory will have MOJO all over them. The early ones will be "better" and you will be a FOOL if you don't hear the difference!
The noise from the tape deck was only drowned out by the buzz from the wine.
krome_magnon
Has thanked: 65 times
Have thanks: 18 times
Postby Mbas974 » 12 Feb 2015, 19:00
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Vacuum FETs
Postby D-Day » 13 Feb 2015, 09:06
I find this highly interesting. Will these see the light of day? Will they be made available in packages 'normal folks' can use?
http://www.extremetech.com/extreme/1850 ... licon-fets
D-Day
Mojo Book Buster
Has thanked: 109 times
Have thanks: 23 times
Re: Vacuum FETs
Postby bajaman » 13 Feb 2015, 10:14
:hmmm:
Re: Vacuum FETs
Postby apollomusicservice » 13 Feb 2015, 10:46
What's next? Maybe steam powered guitar amp.
apollomusicservice
Have thanks: 764 times
Re: Nutube: Korg+Noritake+VacuumFETS
Postby toneman » 14 Feb 2015, 01:49
Thanks Mbas & dday for those fantastic articles!!
Apollo,
How about an Elio powered amp/pedalboard/stage lighting)?
http://www.eliomotors.com/
:lol:
Tone-to-the-Bone
toneman
Has thanked: 89 times
Have thanks: 19 times
Re: Nutube: Korg e Noritake
Postby Dirk_Hendrik » 14 Feb 2015, 08:20
Mbas974 wrote:http://www.synthtopia.com/content/2015/01/29/korg-noritake-introduce-futuristic-nutube-vacuum-tubes/
what do you think ?
I thinkt it's a brilliant combination of making something that was considered obsolete and expensive using technology that is still used a lot. :thumbsup
Has thanked: 251 times
Have thanks: 1010 times
Re: Vacuum FETs
Postby ppluis0 » 16 Feb 2015, 18:10
apollomusicservice wrote:What's next? Maybe steam powered guitar amp.
Alex Lifeson already have those steampunk amps:
ppluis0
Has thanked: 34 times
Have thanks: 72 times
Postby gtrguy » 23 Feb 2015, 20:16
Those amps are hilarious! Pretty curious about this nutube thing...
gtrguy
Postby astrobass » 23 Feb 2015, 20:23
Mostly just curious whether they'll be available at reasonable prices at retail or if they're just going to use these in their own products and get some of that tube gear premium into their margins.
I expect they'll try the latter and then MAYBE the former. They'll probably take a run at selling to select OEMs for a while before you can order them off of Mouser.
astrobass
Has thanked: 50 times
Have thanks: 73 times
Postby JiM » 15 Mar 2015, 23:32
Using VFD for audio is a pretty good idea, those are low-voltage triodes after all.
I'm thinking of doing some experiments with that display i salvaged from an old VCR.
Does anyone have a datasheet for a NEC FIP12FM8 or similar ?
JiM
Has thanked: 29 times
Have thanks: 37 times
Re: Toobs
Postby JiM » 16 Mar 2015, 18:20
Same topic, different thread : viewtopic.php?f=20&t=25799
It looks interesting indeed.
:secret: But VFD from old VCRs have more mojo. Vintage, you know, and most important it lights up !
For this message the author JiM has received thanks:
modman (23 Mar 2015, 22:26)
JiM
Re: Toobs
Postby DrNomis » 17 Mar 2015, 18:52
Really interesting article, I'd love to get a few of these new valves so I can experiment with them, what's even more interesting is that Mr Fumio Mieda san is mentioned in the article, and we all know who he is, he's the guy responsible for designing the Univibe...... :thumbsup
I'm wondering if these new valves will have characteristics similar to the Russian 6N17B, or will they be more like the venerable ECC83/12AX7...... :hmmm:
Great to see that Vacuum-State technology is still alive and kicking..... :thumbsup
DrNomis
Has thanked: 123 times
Have thanks: 397 times
Postby rezzonics » 19 May 2017, 20:08
Just received in the post 2 samples of KORG NuTube 6P1 triode for a DIY guitar preamp project:
rezzonics
Have thanks: 10 times
Postby rezzonics » 19 May 2017, 22:20
According to the Application Notes the gain is 14dB at 12V and 17dB at 30V, I would like to make a boost channel guitar preamp with some cranked distorted output. I plan to cascade two of them at 24V, should I add additional gain? Opamp or JFET amplifier? Where to place the additional amplification, before, after?
rezzonics
Next
Return to Freestomp Café!
