JHS - Charlie Brown
bucksears
Has thanked: 16 times
Been thanked: 41 times
Post by bucksears »
Saw this on PGS last night and was just curious if anyone's traced it yet. Sounds like it MIGHT have a little flab to the low-end, but wouldn't mind building one.
coldcraft
Has thanked: 38 times
Been thanked: 85 times
Post by coldcraft »
the angry charlie is a crunch box, so this is probably some variation on that.
bucksears
Post by bucksears »
coldcraft wrote:the angry charlie is a crunch box, so this is probably some variation on that.
And from what I've read, that's a Marshall Guv'nor with a single tone control.
Not sure with the Charlie Brown - saw a gut shot in the video on PGS and didn't see an IC, but will have to look again.
Barcode
Been thanked: 32 times
Post by Barcode »
It's definitely a crunch box. The Sweet Tea is listed on his website as an 808 and an Angry Charlie in one enclosure. In another thread, it looks like it has been proven that the Angry Charlie side is a Crunch Box (built on one of madbean's layouts, no less):
https://www.freestompboxes.org/viewtopic.php?f=7&t=14496
coldcraft
Post by coldcraft »
actually, I think I mis-spoke. I believe I had deduced previously that the Charlie Brown was a BSIAB, and the Angry Charlie is a Crunchbox as previously said. All-American is a 4 knob Rat and the Morning Glory is a KOT/Bluesbreaker clone.
all clones.
Barcode
Post by Barcode »
Ah, good call, I misspoke too. I glanced too quickly and didn't realize we were talking about two different pedals (Angry Charlie and Charlie Brown). To echo Coldcraft, I believe it has been deduced (but not verified but gutshot or schematic publicly that I know of) that the Charlie Brown is a BSIAB. Angry Charlie has been CONFIRMED to be the Crunch Box though.
culturejam
Has thanked: 433 times
Been thanked: 563 times
Post by culturejam »
bucksears wrote:And from what I've read, that's a Marshall Guv'nor with a single tone control.
Guv'nor with a single tone control? Now where I have heard that before? :hmmm:
viewtopic.php?f=7&t=12699
Ripdivot
Been thanked: 78 times
Post by Ripdivot »
Barcode wrote:To echo Coldcraft, I believe it has been deduced (but not verified but gutshot or schematic publicly that I know of) that the Charlie Brown is a BSIAB.
I know this is an old thread but I believe the Charlie Brown is not a BSIAB clone. There are only three fets in the CB if they are even fets. Looks like it may be more along the lines of the Wampler Plexu Drive.
Barcode
Post by Barcode »
It is 100% confirmed to be a BSIAB clone. Up until around 2010 Josh was even using the circuit board layouts from BSIAB DIY projects in his builds.
Ripdivot
Post by Ripdivot »
Barcode wrote:It is 100% confirmed to be a BSIAB clone. Up until around 2010 Josh was even using the circuit board layouts from BSIAB DIY projects in his builds.
I am aware of that but he has more recently claimed it is not a BSIAB. Looking at the gut shotI don't think it is.
2lane
Post by 2lane »
it's use BS170 not a J201
vulcandrive
Post by vulcandrive »
Hi everybody,
I'm looking for Charlie Brown/BSIAB schematic for study it and try to build.
could anybody help me
thanks in advance for info
vulcandrive
Güero 2.0
Been thanked: 24 times
Post by Güero 2.0 »
3 BS170
some 22nF caps
one diode near to the 1st BS170
47K and 10nF near to the TONE pot
2 2n2 in the end
That's a Box of Rock without the booster and some minor changes
"Come squeeze and suck the day.Come Carpe Diem baby!"
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
Here is the BSIAB schematic, do not have one for Charlie Brown.
MoonWatcher
Has thanked: 40 times
Been thanked: 52 times
Post by MoonWatcher »
Güero 2.0 wrote:3 BS170
some 22nF caps
2 2n2 in the end
That means it's mostly a Distortron then, right?
Does the gain control crackle? That should be another dead giveaway.
Güero 2.0
Post by Güero 2.0 »
Only if you want
https://www.freestompboxes.org/viewtopic.php?t=3971
MoonWatcher
Güero 2.0 wrote:
MoonWatcher wrote:Does the gain control crackle?
Only if you want https://www.freestompboxes.org/viewtopic.php?t=3971
No - I meant if the Charlie Brown specifically crackles as the gain is adjusted. I know all of those Vex pedals do.
If not, there are other options to not having that noise, like using something more like the AMZ Mosfet Booster. Put a big cap in series with the gain pot (cap connects to mosfet's source), and put a 5k1 resistor parallel to it. This assumes there's a 5k1 on the drain.
Güero 2.0
Post by Güero 2.0 »
Please, click here =====> https://www.freestompboxes.org/viewtopic.php?t=3971
MoonWatcher
Güero 2.0 wrote:Please, click here =====> https://www.freestompboxes.org/viewtopic.php?t=3971
I'd already read up on Martin's CNO, shortly after he started the thread on it (when it was only like 2 pages!). But thanks.
I like that he included the CNO in the version 1 Four Banger. I guess it was in the version 2, but there wasn't as much discussion of that one.
Boba7
Has thanked: 25 times
Been thanked: 13 times
Post by Boba7 »
Reviving an old thread (as the Charlie Brown is still NOT traced!)
So I took a close look at a pcb shot (picture with values attached), and it does look extremely similar to the dirt section of a Box of Rock, with a couple modified values and an added contour pot.
I don't know much so I might be wrong.
82k, 47k, .1uf and .022uf show the contour pot is probably done like this
And the only other differences seem to be a few resistor values in the first SHO section:
- 2k7 instead of the usual 5k1 at the drain (that would mean less gain right?)
- An electro might connect the first BS170 source to the gain pot, and there's another 2k7 close, so that could be a way to get rid of the noise (crackle) (like Guero said) (I dont really know what I'm talking about, just guessing here)
What I cant figure out at the moment:
- 2x 100ks at the bottom
- 62k by the blue electro
- 150r below the 2x 22nf
- the blue electro
- the yellow cap at the top
Charlie Brown pcb
Charlie Brown pcb
Box of Rock schematic
