Confused with capacitor color bands
Re: Confused with capacitor color bands
Postby dai h. » 09 Apr 2015, 22:39
sounds about right.
re: the tolerances, (if you look to the right of the above pic at the caps with some silver bands (C7&C10--330pF and 470pF, respectively), at least one must be a tolerance band (i.e. silver = 10%), but there are two of them and I'm not sure which is which.
edit:
IIRC Mouser used to have some of these (tried looking for a datasheet but no luck). Unfortunately, I don't remember the maker, which makes it more difficult to look for a datasheet. Tech 21 Sansamp (the original) also had (one? two?) of those (47nF) I think around the same time as well (early 90s or so).
dai h.
Has thanked: 42 times
Have thanks: 11 times
Postby Lucifer » 09 Apr 2015, 23:16
As per my previous post, black in the fourth band signifies 20% tolerance.
The fifth band is maximum working voltage: Red = 250v; Yellow = 400v, therefore, a GREY band would suggest 800v (grey = 8 in the normal colour scheme, therefore 8 x 100v = 800v).
Hope this helps.
Lucifer
Has thanked: 104 times
Have thanks: 95 times
Postby dai h. » 10 Apr 2015, 23:06
I seriously doubt those are 800V rating.
dai h.
Postby Duckman » 12 Apr 2015, 01:32
Sorry, but I insist in my option... those are old design caps so, the first band -yellow in this case- is NOT the first digit value: is just a temperature coefficient... then you have the first and second digit, then you have the multiplier factor and then you have the tolerance.
Duckman
Has thanked: 364 times
Have thanks: 125 times
Postby Intripped » 12 Apr 2015, 04:52
In the Guv'nor
viewtopic.php?uid=12425&f=1&t=25590&start=0#p246578
There are some 5 bands caps like those and, if the schem is correct (does it come directly from the factory?) then the first 3 bands indicate the value.
Really confusing anyway.
For this message the author Intripped has received thanks:
Duckman (12 Apr 2015, 05:49)
Intripped
Has thanked: 557 times
Have thanks: 210 times
Postby sinner » 12 Apr 2015, 13:38
Duckman wrote:Sorry, but I insist in my option... those are old design caps so, the first band -yellow in this case- is NOT the first digit value: is just a temperature coefficient... then you have the first and second digit, then you have the multiplier factor and then you have the tolerance.
Yeah, I've seen that method too but look
Example
Brown/black/red/silver/silver. If you take 3 first band as a value and another two for cap spec it will give you 1nF (as per factory schematic). Method described by you in this case isn't relevant
For this message the author sinner has received thanks:
Duckman (13 Apr 2015, 03:45)
Has thanked: 1239 times
Have thanks: 1099 times
Postby dai h. » 12 Apr 2015, 23:48
(I will repeat what I said previously)
for *old* caps, yes the chart can make sense, but for those (relatively) newer ones, no.
I mean look at the schematics:
(go down to around the middle, where you see "The 25th Anniversaries") :
http://www.drtube.com/en/library/schema ... ll-schemas
the values and temp. coefficient, voltage ratings you would get going by the old chart wouldn't make sense.
For this message the author dai h. has received thanks:
Duckman (13 Apr 2015, 03:46)
dai h.
Postby Duckman » 13 Apr 2015, 03:52
Then no :blackeye
Duckman
Postby alex28m » 19 Jun 2016, 09:03
The capacitors used by Marshall in their PCBs up until the late 90's were predecessors to CTC's CA-Series axial ceramic. They were used because they were mounted by insertion machines and were relatively cheap. The dielectric used was Ceramic NPO (Black-band) or Y5P (Silver-band) - light green body. The CA-Series example here is only a 50V DC rated part (this was the only electronic datasheet I could find on the Internet), there was a higher voltage rated part used that was about the size of a 1/4W metal film resistor like the old Philips MFR25; I can't recall that part number or details of.
I understand that the last supplier in the UK was Anglia Components Limited in Cambridgeshire - I don''t know if you can still get them.
Attached is an excerpt from the CTC CA-Series Datasheet that will help you decode the colour code used on the body.
Panasonic and Taiyo Yuden made similar products and were also used.
If you need to replace these capacitors, replace them with another good quality NPO ceramic (Y5P was used because it was cheaper and readily available), I can suggest AVX. If use an alternate capacitor dielectric, like MKP or MKT, you'll change the sound characteristics of the circuit. Quite some testing and listening went into the prototypes to get the "Marshall Sound" from the circuit.
Regards,
Alex.
For this message the author alex28m has received thanks: 2
dai h. (22 Jun 2016, 00:27), Intripped (19 Jun 2016, 22:02)
alex28m
Have thanks: 4 times
Postby alex28m » 19 Jun 2016, 09:24
Here's the Panasonic ECB Series part, also a 50V DC part too.
alex28m
Postby alex28m » 19 Jun 2016, 11:05
Following is the Panasonic datasheet for their leaded axial ceramic capacitors. You'll notice the dielectric varies depending on the capacitance - keep that in mind if you're wanting to keep your repairs true to the original sound of the amplifier's circuit.
The NPO types weren't always available in the larger values and you ended using one of the Y5* dielectric variants that were temperature dependent and became significantly microphonic as the capacitance got larger. Nonetheless, the ac transfer characteristics, and their non-linearity at small signal levels was often something you wanted to give a "characteristic sound" to a circuit.
(If you want to know more about capacitor sound, read Cyril Bateman's Capacitor Sound articles that appeared in Wireless World: I saw these have been published here:
https://linearaudio.nl/cyril-batemans-capacitor-sound-articles
A lot of the film capacitor types give a "clean" sound or in the words of my old boss, "...those capacitors sound too bloody Hi-Fi and were not making any of that..." - the ceramics were used for good reason in most cases
Alex.
Intripped (19 Jun 2016, 22:01)
alex28m
Return to Capacitors
cron
