Top Tone - Light Drive  [traced]
Re: Top Tone Light Drive
Postby Krinkle » 13 Jan 2013, 21:09
MWichni wrote:Nice one JOHNO! :) I really like the graphics on the box.
Krinkle, could you post pictures of the SS-2 that you have?
Here;
viewtopic.php?f=7&t=10096&hilit=+ss+2+ebay
Ones I downloaded from an eBay auction. I've been looking all over the internet but can't find any others.
Krinkle
Have thanks: 4 times
Postby MWichni » 13 Jan 2013, 21:25
Here is the only 2 other pictures that I have. One is a SS-2 G-2 duplex pedal, on the right side there is SS-2. Second shows one of the effects boards and there is a SS-3 next to green double potentiometer.
MWichni
Have thanks: 56 times
Postby monkeyxx » 13 Jan 2013, 22:23
man I never get tired of those Cornish gut shots, such clean work.
monkeyxx
Has thanked: 46 times
Have thanks: 47 times
Postby Clonedreams » 14 Jan 2013, 00:02
mipo wrote:Looks great, JOHNO; gut shot, maybe?
Sure here ya go. Not too pretty though. I used a different layout than the one i posted. Well it's the same but i made it larger.
For this message the author Clonedreams has received thanks:
Tinkerman (30 Jan 2013, 13:12)
Clonedreams
Postby Tinkerman » 30 Jan 2013, 13:09
Thanks for sorting this one out MWichni and Johnno. Finished this one using IvIarks buffer and Sabro's layout. Would like to ask a question--Does anyone know the difference between the 1n270's that are clear glass and the all black ones with the grey band? Cheers, Benno
Tinkerman
Has thanked: 10 times
Postby MWichni » 30 Jan 2013, 14:11
Hi, nice work Tinkerman. Have you compared the tone to the ss-2 samples on youtube? How it sounds for you?
Regards.
MWichni
Postby Tinkerman » 31 Jan 2013, 04:08
It sounds great to me, pretty much spot on. I've tried both 1n34's and 1n270's, which I think I prefer. Have some different types on the way, hope they have a low Forward voltage. Thanks again.
Tinkerman
Postby JOHNO » 31 Jan 2013, 09:35
Tinkerman wrote:Thanks for sorting this one out MWichni and Johnno.
Thanks for the kudos but I had no part in this at all, it is all Mwichni's hard work.
JOHNO
Has thanked: 52 times
Have thanks: 62 times
Postby Tinkerman » 09 Feb 2013, 12:34
Would be interested to know if yours has enough bottom end ?, mine seems a bit lacking now after using it live, could be the buffer do you think? Thanks :hmmm:
Tinkerman
Postby JOHNO » 09 Feb 2013, 14:27
It has enough for me but in not into huge bottom end. Try raising the values of C1 and C6 that should help you get what you are looking for.
Johno
For this message the author JOHNO has received thanks:
Tinkerman (10 Feb 2013, 08:40)
JOHNO
Postby MWichni » 10 Feb 2013, 11:27
You can also try to replace 470nF capacitor with some higher one 680nF or even 1uF.
For this message the author MWichni has received thanks:
Tinkerman (12 Feb 2013, 06:17)
MWichni
Postby Tinkerman » 22 Feb 2013, 05:12
Thanks guys. Ended up making another pedal true bypass, using 1n695 Ge diodes. Sounds the goods now, really happy with it. Thanks for tracing MWichni. Curious to know what C5 does as it is not present in Skrydstrup schem.
Tinkerman
Postby MWichni » 22 Feb 2013, 09:48
Tinkerman wrote:Thanks guys. Ended up making another pedal true bypass, using 1n695 Ge diodes. Sounds the goods now, really happy with it. Thanks for tracing MWichni. Curious to know what C5 does as it is not present in Skrydstrup schem.
No problem, I just always wanted to build and play that SS-2 pedal. About the capacitor, do you mean the one which shortens the potetniometer to ground (4.7nF)? If yes then it adds high frequencies in highest drive settings.
Tinkerman (22 Feb 2013, 11:42)
MWichni
Postby ohmy » 06 Oct 2014, 13:48
HI,
Can someone repost the schenatic? The one on the end of page three is no longer there.
ohmy
Postby bradberry00 » 08 Jan 2015, 17:18
I would love to see this schematic too if someone still has it.
thanks
-david
bradberry00
Postby Ripdivot » 08 Jan 2015, 23:56
There is a schematic on page 2
Ripdivot
Have thanks: 65 times
Postby bradberry00 » 11 Jan 2015, 01:30
Is that the final version?
bradberry00
Postby Ripdivot » 11 Jan 2015, 03:57
bradberry00 wrote:Is that the final version?
Not sure but it's plenty to make it sound the way you want with your rig.
Ripdivot
Postby soulsonic » 26 May 2015, 20:01
Everyone keeps saying this is the same thing as a Cornish SS-2...
where is the verified schematic of an actual SS-2 to compare this to?
For this message the author soulsonic has received thanks:
modman (16 Dec 2015, 21:00)
Has thanked: 53 times
Have thanks: 263 times
Re: Top Tone - Light Drive
Postby friedtransistor » 27 May 2015, 00:32
I agree. I would like to see a verified schematic as well.
For all you starwars fans...
http://lolsnaps.com/upload_pic/TheDarthFader-19337.jpg
Sorry, downsized by request.
Did I mention I love bass?
For this message the author friedtransistor has received thanks:
soulsonic (27 May 2015, 02:58)
friedtransistor
Has thanked: 16 times
Have thanks: 28 times
PreviousNext
Users browsing this forum: Alexa [Bot], ferryarliansyah, inq, laion, treptlikus, vot and 11 guests
