Jennings Electronic Industries (JEI) - Phaser
Postby Bernardduur » 09 Jul 2015, 08:39
Yesterday this pedal came in the mail. I was fascinated by the origin (from the hands of the AC30 designers) but also wanted to hear it in action.
Fired up the unit has a HUGE volume boost with the phaser engaged or in bypass mode. It is not true bypass I suppose. The phaser has no LFO and can be used by rocking the pedal forwards and backwards. It can be activated the same way as a crybaby wah.
The sound is surprisingly nice. A very complex phaser sound that I was not expecting from it. Looking at the circuit it only has transistors, no IC can be found. (if I recall, I've never seen a pure transistor based phaser).
More pics will follow; I'll trace it when I got some spare time!
http://www.hendrixguitars.com/Ef230.htm
http://www.effectsdatabase.com/model/je
For this message the author Bernardduur has received thanks: 2
Fender3D (09 Jul 2015, 12:07), modman (09 Jul 2015, 11:05)
Bernardduur
Has thanked: 87 times
Have thanks: 482 times
Re: Jennings Electronic Industries (JEI) - Phaser
Postby Fender3D » 09 Jul 2015, 12:14
The very first issue of Elektor in Italy, back in the late '70-early '80, featured a phaser circuit, it had two 1-transistor-phase stages (outputs on E and C) ala ***vibe, a dual gang pot instead of LDRs, I'm sorry but I don't recall what the input and input stages were...
Fender3D
Has thanked: 96 times
Have thanks: 128 times
Postby Bernardduur » 09 Jul 2015, 12:18
Oops, forgot the univibe :)
That one is a pure transistor phaser
Bernardduur
Postby Bernardduur » 10 Jul 2015, 07:19
Blitz Krieg (15 Jul 2015, 09:46), TrashPedals (24 Jan 2017, 09:43)
Bernardduur
Postby Bernardduur » 10 Jul 2015, 07:21
Bernardduur
Postby Bernardduur » 10 Jul 2015, 07:25
And the schematic!!
For this message the author Bernardduur has received thanks: 10
apollomusicservice (10 Jul 2015, 07:36), blackbunny (21 Jul 2015, 03:31), Blitz Krieg (15 Jul 2015, 09:36), brejna (12 Jul 2015, 21:34), Fender3D (10 Jul 2015, 09:16), garygad (04 Jan 2017, 06:54), Intripped (12 Jul 2015, 15:48), kaycee (10 Jul 2015, 15:31), Manfred (12 Jul 2015, 18:03), Nocentelli (07 Jan 2017, 15:26)
Bernardduur
Postby tube-exorcist » 10 Jul 2015, 12:50
The original circuit can be found in Practical Electronics October 1973. The potentiometer should be alogarithmic type.
For this message the author tube-exorcist has received thanks: 3
Bernardduur (10 Jul 2015, 16:16), Blitz Krieg (15 Jul 2015, 09:37), Dirk_Hendrik (11 Jul 2015, 08:45)
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby Bernardduur » 12 Jul 2015, 15:39
tube-exorcist wrote:The original circuit can be found in Practical Electronics October 1973. The potentiometer should be alogarithmic type.
Nice! I can't find that issue online; would you have one? I'm interested in the article....
Bernardduur
Postby tube-exorcist » 12 Jul 2015, 16:17
Sorry, but I don´t have an original one - I found the article on Mar 24, 2001.... ONLINE. And yes, it is still there waiting for interested ones:
http://www.synthdiy.com/show/?id=1118
(Download link at the the right bottom "pha.pdf".)
Bernardduur (12 Jul 2015, 21:36), Blitz Krieg (15 Jul 2015, 09:43), garygad (04 Jan 2017, 06:51)
tube-exorcist
Postby Manfred » 12 Jul 2015, 18:37
Hi Bernardduur,
thanks for dissectioning, great!
How is the size of the PCB?
Do you made a shot of the component side of the PCB too,
there are some components hidden by the plug sockets on the device shot?
I intend to create a replica PCB.
Has thanked: 941 times
Have thanks: 490 times
Postby Fender3D » 12 Jul 2015, 19:13
lol
:mrgreen:
looking at the several magazines publishing(ed) this...
it may be a good argument for the "The Big Catfight: ethics/cloning/copying/stealing/personal" thread... :horsey:
Fender3D
Postby Manfred » 12 Jul 2015, 23:13
Fender3D wrote:lol
:mrgreen:
I guess there is no argument, because it is a discontinued product since more than 40 years. 8)
Of course for noncommercial use only. :wink:
Postby Bernardduur » 13 Jul 2015, 21:03
@ tube exorcist: Thanks for the link!!
@ Manfred: here ya go
Size: 7cm x 5.5cm
Manfred (13 Jul 2015, 21:42)
Bernardduur
Postby Manfred » 13 Jul 2015, 21:51
Hi Bernardduur,
thanks for the shot and the board size.
Postby Manfred » 04 Jan 2017, 00:03
I create the PCB layout clone according to the the shots.
Bernardduur (20 Jan 2017, 11:52), ThiagoFaraday (05 Jan 2017, 00:28), TrashPedals (24 Jan 2017, 09:40)
