MIDI Switcher for ZOOM MultiStomp(MS 50g and MS70-CDR,MS60B)
Postby m10065 » 22 Jun 2015, 18:04
Hi I'm GSMCustomEffects
Japanese Circuit Engineer!
I made MIDI Switcher for ZOOM MultiStomp(MS 50g and MS70-CDR,MS60B)
myVine
https://vine.co/v/Od7Pnp0AaqV
using Arduino and USBHostShield
Schematic and SourceCode Here!!
this is my Blog in Japanese
SourceCode
http://garagestylemsc.blog.jp/archives/20654052.html
Schematic(Layout)
http://garagestylemsc.blog.jp/archives/20767328.html
this Switcher presetnumber10 is bypass
you can programchange 1~8!
enjoy!
For this message the author m10065 has received thanks: 5
allesz (24 Jun 2015, 17:21), andershenrik (02 Sep 2015, 11:16), bajaman (02 Sep 2015, 11:29), edy_wheazel (24 Jun 2015, 20:38), pamaz (16 Jul 2015, 10:42)
m10065
Have thanks: 9 times
Re: MIDI Switcher for ZOOM MultiStomp(MS 50g and MS70-CDR,MS
Postby tangalanga » 10 Jul 2015, 14:16
Excellent! Thanks for your work and generosity!
tangalanga
Postby m10065 » 14 Jul 2015, 17:48
Reply Thank you.
It is the current case of the design.
Once you have completed drawings will also be published.
Function is as Vine
Thank you in the future!
m10065
Postby m10065 » 14 Jul 2015, 17:50
cross section
2mm!
m10065
Postby m10065 » 14 Jul 2015, 17:52
side view
Scheduled to take power and USBMIDI connector on this surface
Position of MIDI connector undecided
Exploring the current position
m10065
Postby pamaz » 16 Jul 2015, 15:15
I'm trying to understand and dowload the code form your website, but I'm having a few difficulties due to the japanese language ( and google translator is not helping that much!) .
Can you please point me to the correct link for downloading the code pls?
Paolo
pamaz
Has thanked: 29 times
Have thanks: 10 times
Postby apollomusicservice » 16 Jul 2015, 15:49
pamaz wrote:I'm trying to understand and dowload the code form your website, but I'm having a few difficulties due to the japanese language ( and google translator is not helping that much!) .
Paolo
Try this
For this message the author apollomusicservice has received thanks:
pamaz (16 Jul 2015, 18:03)
apollomusicservice
Has thanked: 65 times
Have thanks: 760 times
Postby m10065 » 18 Jul 2015, 10:58
Thanks for Uploading!
m10065
Postby m10065 » 02 Sep 2015, 06:33
Long time no see
This time more of MIDI switcher I will introduce so was completed.
A mode
1,2,3,4
B mode
5,6,7,8
send ProgramChangeMIDI messege
left switch is mode change Switch!
The case is our original design
We were outsourced to sheet metal forming
https://twitter.com/GarageStyleMsc/stat ... 64/video/1
tangalanga (17 Apr 2016, 19:25)
m10065
Postby andershenrik » 02 Sep 2015, 11:15
:applause: Thank you ,this is interesting . I was not aware that the MS50 can be controlled by midi . Anybody know a link to the commands ?
andershenrik
Postby m10065 » 03 Sep 2015, 19:03
andershenrik wrote::applause: Thank you ,this is interesting . I was not aware that the MS50 can be controlled by midi . Anybody know a link to the commands ?
Thank you for questions
I think that it is not perhaps know
m10065
Postby kaya112 » 22 Sep 2015, 06:53
In file included from E:\arduino-1.6.5\libraries\USB_Host_Shield_2.0-master/Usb.h:27:0,
from sketch_sep22d.ino:2:
E:\arduino-1.6.5\libraries\USB_Host_Shield_2.0-master/settings.h:139:176: fatal error: SPI.h: No such file or directory
#include <SPI.h> // Use the Arduino SPI library for the Arduino Due, RedBearLab nRF51822, Intel Galileo 1 & 2, Intel Edison or if the SPI library with transaction is available
compilation terminated
:scratch: :scratch:
kaya112
Have thanks: 8 times
Postby divabanana » 04 Nov 2015, 17:02
I have a question regarding the powering of the Zoom MS-50G.
It looks like you are powering it via the USB bus from the USB host shield.
(In the MS-50G specs it says you can power it from USB so that's all good).
What I don't understand is the power adapter they recommend is 9v but USB bus power is only 5v.
I asked Zoom about this and they said that the required power is 9v and the device does not adjust voltage...
So how is the 5v from the USB bus enough when it requires 9v?
Can anybody shed any light?
divabanana
Postby 56335130 » 11 Jan 2016, 10:05
divabanana wrote:I have a question regarding the powering of the Zoom MS-50G.
same as g3.when use usb power ,the inside bump the 5v to 9v and let the analog chip works.
56335130
Postby m10065 » 16 Mar 2016, 06:34
Long time no see.
Since I was able new site thank you
http://diystompbox.html.xdomain.jp/index.html
For this message the author m10065 has received thanks: 2
roseblood11 (30 Aug 2016, 14:51), tangalanga (17 Apr 2016, 19:25)
m10065
Postby m10065 » 26 Aug 2016, 13:49
Long time no see.
I tried to control of the GT100
https://vine.co/v/inq2bwnAueQ
m10065
Postby m10065 » 16 May 2017, 15:40
m10065
Postby Ben N » 06 Jun 2018, 13:18
Hey, m10065, sorry I'm late to the party--just got my MS-70CDR, and it's really my first digital pedal. Can you provide updated links for the code and schematic?
BTW, just around the same time as you, a fellow named Lawrence Doss came out with an Arduino based controller for MS. Are you familiar with it? Are there any important differences?
Ben N
Have thanks: 6 times
Users browsing this forum: FunkyBeast and 3 guests
