MEC WARWICK 3 BAND EQ RF ISSUE
Postby darmstat » 30 Jan 2016, 15:45
I have a MEC / WARWICK 3 band bass on board eq and it has an issue. when i plug in my bass guitar the active system has a lot of noise and RF interference. the signal sounds weak when compared to the passive sound? I replaced the battery and i do not see any wires disconnected from the circuit. Any help on this would be appreciated.
darmstat
Have thanks: 43 times
Re: MEC WARWICK 3 BAND EQ RF ISSUE
Postby bajaman » 30 Jan 2016, 20:29
first check the jack socket, before replacing op amps
Has thanked: 411 times
Have thanks: 1390 times
Postby darmstat » 30 Jan 2016, 22:32
here are the voltages arcoss the 2 op-amps
tl064
pin 1 4.52 v
pin 2 4.45 v
pin 3 3.78 v
pin 4 9.70 v
pin 5 4.48 v
pin 6 4.48 v
pin 7 4.47 v
pin 8 4.58v
pin 9 4.57 v
pin 10 4.54 v
pin 11 0
pin 12 4.30 v
pin 13 4.54 v
pin 14 4.54 v
tlo62
pin 1 .24 v
pin 2 .44 v
pin 3 .66v
pin 4 0
pin 5 4.30 v
pin 6 4.52 v
pin 7 4.52 v
pin 8 9.70 v
darmstat
Postby bajaman » 31 Jan 2016, 02:36
the voltages on the TL064 are good - the voltages on the TL062 do not look right to me but without seeing the schematic - hmmm. i would replace the TL062 and remeasure the voltages you should be getting approx 4.5 volts on pins 1,2, and 3.
Postby darmstat » 31 Jan 2016, 02:41
I did the best i could to trace the circuit. Here is a schematic that i came up with.
darmstat
Postby darmstat » 31 Jan 2016, 02:47
I replaced the tlo62 with another one and still the same voltage readings? I tried yet another op-amp and still the same readings?
darmstat
Postby bajaman » 31 Jan 2016, 06:36
ok maybe that side of the op amp is not being used in the circuit - can not see the schematic
Postby darmstat » 31 Jan 2016, 08:21
schematic
darmstat
Postby ggedamed » 31 Jan 2016, 09:52
You should double check the schematic for R1 - it doesn't make much sense to bias the + input through R3, then connect it to the ground.
Also, pins 10 and 5 of TL 064 should get some bias from somewhere.
Double also, you may have missed a resistor from pin 14 to pin 6 of TL064.
Other than that, nothing beats the old audio probe in debugging.
LATER EDIT: try to use easier to edit/view formats like png/gif/jpg, instead of pdf, when posting things not meant to be definitive.
ggedamed
Has thanked: 138 times
Have thanks: 145 times
Postby darmstat » 31 Jan 2016, 15:00
Maybe this one is a little better.
darmstat
Postby darmstat » 31 Jan 2016, 15:43
Better
darmstat
Postby ggedamed » 31 Jan 2016, 16:24
As Bajaman said, the first op amp has a problem. I would take out the TL062, then measure the voltage at pin 3 (in the op amp socket) and resistance from each of the pins 1 and 2 to ground. The voltage should be VR and pins 1 and 2 should have no connection to the ground. I'd also test the electrolytic caps around the op amp (C12 and the 1uF between R2 and ground).
ggedamed
Postby darmstat » 31 Jan 2016, 16:49
Thanks for the help. I bread boarded the last schematic and it works as it should.
darmstat
Postby darmstat » 31 Jan 2016, 18:19
I replaced C 2 and it works fine now?
darmstat
Postby Serge75 » 02 Feb 2016, 11:44
Hallo, could someone please, post the pots for the circuits, where they connect and what value they are? I m not finding anything on google at the moment for a 3band mec preamp. I play on a warwick fortress one 5 and have always liked the sound, but I play it passive. I'd like to give it a try a the active middle cut. Thank you,
Sergio
Serge75
Postby george giblet » 23 Oct 2017, 02:17
Looks like some updated schematics were deleted?
Anyone got those?
I've added fixes based on some pretty poor pictures.
It really needs a recheck on a real board or some better pictures.
For this message the author george giblet has received thanks: 2
blackbunny (13 Aug 2018, 06:01), modman (24 Oct 2017, 16:00)
george giblet
Has thanked: 18 times
Have thanks: 33 times
Postby darmstat » 08 Aug 2018, 19:10
Updated
For this message the author darmstat has received thanks: 3
blackbunny (13 Aug 2018, 06:01), george giblet (18 Aug 2018, 23:42), Manfred (08 Aug 2018, 20:22)
darmstat
Postby george giblet » 18 Aug 2018, 23:50
Good stuff. Thanks for the update.
I can see the following differences between my schematic your update:
- Where R4 and R12 connect, R12 on my schematic connects to the other side of R4 compared to yours.
* From a technical perspective on how the circuit works I'd go with my connection.
- C2 connects to the other other side of C1.
* Both will work, hard to know what is correct without a PCB.
- R11 value: Mine 20k, Yours 22k.
* Not much to worry about there. Again, would need to be checked against a PCB.
Maybe this part varied in production?
- C4, C8, C9 values. Mine 10pF, Yours 100pF.
* No idea what is correct. I'd have to go over my info and see how clearly I could read the values.
EDIT: I can confirm these caps are 10pF. It is also clear these caps are different to C2 on the PCB.
Personally I'd probably prefer the sound of 100pF.
- I've got a diode on the power.
* I believe this is correct as you can see it on the PCB pic I've posted.
george giblet
Postby george giblet » Yesterday, 00:19
I just realized I actually made a proper schematic and hadn't posted it!
george giblet
