Top Tone - Light Drive  [traced]
Re: Top Tone - Light Drive
Postby soulsonic » 27 May 2015, 03:13
friedtransistor wrote:I agree. I would like to see a verified schematic as well.
Totally, man. All throughout this thread, I see people commenting, "oh yeah, totally an SS-2", with no links at all to where they are getting this information? Is there an SS-2 schematic floating around that no one has posted here? Or is this just some rumor that got started on a forum?
For this message the author soulsonic has received thanks:
navin1 (23 Sep 2015, 09:23)
Has thanked: 53 times
Have thanks: 263 times
Postby Intripped » 27 May 2015, 04:10
What i know is that there are strong similarities with this pedal
viewtopic.php?f=7&t=20717&hilit=skrydstrup#p210475
...that is supposed to be a Cornish SS2 clone
Intripped
Has thanked: 557 times
Have thanks: 210 times
Postby friedtransistor » 27 May 2015, 10:58
here's a shortcut to the schematic in that other post (thanks to Intripped for that link):
http://www.freestompboxes.org/download/ ... &mode=view
And the one posted earlier in this thread (thanks to MWichni for postihng that):
freestompboxes.org/download/file.php?id=16643
(Copy and paste to address bar. Dunno why no link appear...)
Very similar schematics, me thinks...
For all you starwars fans...
http://lolsnaps.com/upload_pic/TheDarthFader-19337.jpg
Sorry, downsized by request.
Did I mention I love bass?
friedtransistor
Has thanked: 16 times
Have thanks: 28 times
Postby MWichni » 27 May 2015, 11:42
It is not verified that it is direct copy of the Cornish ss-2 but it sounds very similar. Unfortunately I don't have tend opportunity to compare this pedals.
MWichni
Have thanks: 56 times
Postby fishfude » 16 Dec 2015, 17:11
So is this the most recent, reliable schem for the cornish: http://www.freestompboxes.org/download/ ... &mode=view
Whats with the Resistor values ending in ''E"? (R10, R11, R24, R22 etc...)?
ff
fishfude
Has thanked: 42 times
Postby MWichni » 16 Dec 2015, 18:58
This is one way to state the resistor value. For example R24 is 100E which means it is 100 ohm value. The same thing concerns other resistor values expressed in "E" manner.
Cheers.
MWichni
Re: Top Tone - Light Drive  [traced]
Postby modman » 16 Dec 2015, 21:27
For this message the author modman has received thanks: 3
allesz (17 Dec 2015, 21:46), Cannibal (20 Dec 2015, 20:38), Matty D (26 Dec 2015, 11:02)
Has thanked: 3051 times
Have thanks: 526 times
Postby Ghandi » 25 Apr 2016, 23:13
Anybody else thinks the biasing around the second opamp looks a bit odd?
Ghandi
Has thanked: 13 times
Postby MWichni » 24 May 2016, 17:49
I can't post the schematic. For some reason "upload attachment" doesn't work for me. I have the corrected schematic. If anyone want's it feel free to e-mail me or send me a pm with a request.
Best regards,
Mariusz.
MWichni
Postby Blend » 24 May 2016, 23:38
Assuming that the father of this pedal is the distortion mxr + and Randy Rhoads to make up for its flaws used immediately after a eq. and that gives his best on a tube amp, the improvement made SS-2 style and Light Drive is obvious. A month ago I did a bit of healthy experimentation likely missing values and found errors on published schemes so far. I used a MC1458 because it actually contains 2 741 quiet, everything works fine but I feel that it is not 99% mainly on hiking tone, perhaps a different second op-amp is the key? However, the volume and gain controls must be adjusted differently when used on clean channel or crunch, crunch you go with full volume and gain at 0 and has a great shot, on the clean channel volume of 11-12 hours and gain from 0 hours 15. Just as in the attached diagram I used in concert last Saturday with marshall jcm 900 and 4x12 cabinet in 1960 and has performed well flares up the amp beautifully.
Blend
Has thanked: 45 times
Have thanks: 53 times
Postby MWichni » 26 May 2016, 10:28
Hi guys, I uploaded the schematic to tinypic.
http://oi68.tinypic.com/8yc46x.jpg
For this message the author MWichni has received thanks:
Intripped (26 May 2016, 13:42)
MWichni
Postby karul » 26 May 2016, 13:37
MWichni wrote:I can't post the schematic. For some reason "upload attachment" doesn't work for me. I have the corrected schematic. If anyone want's it feel free to e-mail me or send me a pm with a request.
Best regards,
Mariusz.
1. Click on [Browse] button
2. Select the image you want to attach
3. Click on [Add the File] button
karul
Has thanked: 210 times
Have thanks: 143 times
Postby Blend » 26 May 2016, 14:35
In this discussion I keep seeing sent schematic of a puzzle made up of fragments from SS-2, Light Drive and Skrydstrup ODR2, in my scheme published yesterday I mistakenly reversed R3 with R5, but it would be really necessary to define what is missing in a Light correct drive, the last schematic published "Cornish SS-2 Light-drive", I see:
- Improper placement of C15 (from Skrydstrup ODR2?)
- R6, 100k is the value in Light drives
- C3 and C12 are Evox PFR having a minimum value on the market 100pf
- R9, 1M should be the impedance of the second phase input
- D2, is missing as in the photo published on page 1 as an element in series resistance or of another diode.
Blend
Postby MWichni » 26 May 2016, 14:57
Best regards,
Mariusz.
I know how it works. When I select the file and then click add the file I get blank site and cannot finish my post in any way...
Blend wrote:In this discussion I keep seeing sent schematic of a puzzle made up of fragments from SS-2, Light Drive and Skrydstrup ODR2, in my scheme published yesterday I mistakenly reversed R3 with R5, but it would be really necessary to define what is missing in a Light correct drive, the last schematic published "Cornish SS-2 Light-drive", I see:
I will revise that for you and report back during next days. Just too much to do currently.
MWichni
Postby The Rotagilla » 10 Nov 2017, 19:01
Hey guys,
I've been messing around with this circuit and have a quick question. The pedal has a bit of a mid hump I don't really care for, is there a part or parts I can mess with to reduce it?
Thanks.
The Rotagilla
Users browsing this forum: captain_tango, Cigla tel., Fael, juan_felt, Lani, rcustoms and 8 guests
