Rockett Flexdrive dissected
Has thanked: 1672 times
Been thanked: 1344 times
Post by Manfred »
I traced each diode in the circuit and compared the read traces with reference diode traces.
So I found out as follows.
Ge-diodes are 1N34A green band.
Big Si-diodes are 1N4005.
Small Si-diodes are 1N4148
287m
Has thanked: 481 times
Been thanked: 74 times
Post by 287m »
hello manfred :thumbsup
the switch :
fat = spst
clip = on-on or on-off-on?
treble = on-on or on-off-on?
and the 1n4001 look backward for me
Post by Manfred »
Hello 287m,
thanks for finding the fault.
You are right, the 1N4001 is drawn in wrong orientation, here the corrected schematic.
fat = spst
Fat: off on.
Clip: on off on.
Treble on off on
I read the datas of the built-in J201:
Vgs(off)=-0,72V at Id=5,2µA
Vgs(on)=0,38V at Id=1,26mA
gfs=1,9mA/V at Id=0,8mA to 1,3mA
Idss=0,58mA at Vds=3,01V
Rds(on)=549,1O at Id=1,3mA and Vgs=0,0V
tube-exorcist
Has thanked: 173 times
Been thanked: 67 times
Post by tube-exorcist »
I bet the tone control is drawn wrong too and should look like one from a tube-screamer - please verify.
Post by Manfred »
tube-exorcist wrote:I bet the tone control is drawn wrong too and should look like one from a tube-screamer - please verify.
Sorry, I cannot verify the pedal again, because I gave it already away.
It was very hard to trace, but I used the tube screamer circuit as pattern and it was not in accordance with the screamer tone control, that amazed me.
The Flexdrive tone control affects nut much in my opinion, it acts rather as treble lift when the knob is turned clockwise.
have a look at
Tone knob variations at the playing time from 3:38 to 3:45.
I think that explains the different tone circuity.
I'm not without fail, maybe a owner of the Flecdrive would be so kind to recheck the tone circuit.
Post by Manfred »
hi,
I thougt about the circuit differences and made a circuit simulation.
The shown tone circuity has indeed no effect.
You are right regardíng the screamer tone circuity.
Thanks that you took a closer look at the schematic. :thumbsup
tube-exorcist
Now there is only missing a 22k resistor (maybe 2k2) between pin 6 and 7 of the second opamp (instead of the short).
Post by Manfred »
tube-exorcist wrote:Now there is only missing a 22k resistor (maybe 2k2) between pin 6 and 7 of the second opamp (instead of the short).
The short is ok, there is no resistor in between.
himers
Post by himers »
Where are the two Capacitors 22n(223) connected?
I understand that one is treble, but one after the other?
Those who know, please tell me
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
hi,
No, actually it isn't the TS tone control. you had it right the first time I think. 5k pot across pins 6/7, middle lug goes to a 100r and .022uf IIRC.
It's been about 10 years since I drew that though so.....
