Mbas974 wrote:Cool, seems something already seen on this forum... right Melinb ?
while whether you want to trace it... better heve picture of the other side as well.
lukatosh wrote:
3.- The blend circuit portion is a little bit tweaked; specially the last stage uses a fairchild 2n5484 (Image posted). I've read about using a 2n5457 as a replacement but:
[ Image ]
3.a) why do they used this design instead the proposed by BYOC?
3.b) how do the 2n5457 will work?... we can just replace it or the circuit needs to be tweaked! (of course after checking the 2n547 pinout).
3.c) Do you suggest maintain this JFET or go back to the design proposed by BYOC?
newly wrote:storyboardist...is the one that using BA6110 an actual Deep6? I open up one last night, it has JRC13700 instead.
Users browsing this forum: art7710, JBJ, Yosio and 14 guests
