Amptweaker - Tight Metal  [traced]
Re: Amptweaker - Tight Metal
Postby J0K3RX » 11 Jul 2016, 11:52
Stupid question... How did Crumbchildz become the "Author" of this topic thread? :scratch:
J0K3RX
Has thanked: 319 times
Have thanks: 489 times
Postby Ice-9 » 11 Jul 2016, 16:30
J0K3RX wrote:Stupid question... How did Crumbchildz become the "Author" of this topic thread? :scratch:
Hmm, rather strange me thinks. :hmmm:
Ice-9
Has thanked: 141 times
Have thanks: 358 times
Postby grrrunge » 14 Jul 2016, 14:39
Probably a database burp ;) Sometimes stuff like that happens during maintenance. The weird thing is that your user ID's aren't even close :scratch:
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby Blitz Krieg » 18 Jul 2016, 07:55
threads merged?
Blitz Krieg
Has thanked: 577 times
Have thanks: 4 times
Postby J0K3RX » 21 Jul 2016, 02:59
Blitz Krieg wrote:threads merged?
Yeah, looks that way :hmmm: maybe they should be added to the ass end or better yet a sub-thread..
J0K3RX
Postby jmpj45 » 20 Sep 2016, 00:16
I need some help does anybody know what kind of switch is the gate and thrash switch. Are they on/off or on/off/on
jmpj45
Postby J0K3RX » 20 Sep 2016, 04:06
jmpj45 wrote:I need some help does anybody know what kind of switch is the gate and thrash switch. Are they on/off or on/off/on
on/off
J0K3RX
Postby modman » 20 Sep 2016, 20:38
Dude, please... yeah I merged the threads, and you are absolutely right, that first batch of post contained no info.
Wish I had time to go through the other 23 pages of replies...
Has thanked: 3108 times
Have thanks: 549 times
Postby MoonWatcher » 24 Sep 2016, 15:54
richard44 wrote:I have not yet tried running this at 18V, but James Brown in his demo showed it gave the pedal a more expansive, less compressed sound. Apropos to that, if I had to build this pedal again, I might add a 18V/9V switch with a voltage double in the circuit.
I finally got around to building one a little while back. I prefer having the gain lower than what I imagine the average (metal playing) user might go for, and I built this to the Tight Rock specs.
When used in this way, I think the higher voltage is almost a necessity, because it seems to eliminate unpleasant higher order harmonics (that seem to be coming from the op amps themselves). For super heavy distortion, I don't think there's an obvious advantage to anything higher than 9V - you'd really only need it for playing stuff that had a big dynamic range.
It really does seem to be a cool pedal. My only complaint is that when I roll down my guitar's volume, it sounds like a sitar, or like there is a biasing issue. I wouldn't be surprised if I had a minor error in my build, but it would have to be minor, because the pedal sounds great otherwise, and I only run it at 18V with the gain low. And since the gain is never set high, I was able to remove the gate altogether.
MoonWatcher
Has thanked: 42 times
Have thanks: 63 times
Postby EmmG » 28 Sep 2016, 19:04
What about this on a 4 position rotary switch? I don't want any of the lower gain modifications of the TR version, just more mid range.
For this message the author EmmG has received thanks:
Belanger88 (23 Feb 2017, 04:20)
EmmG
Has thanked: 16 times
Have thanks: 30 times
Postby dave_b » 01 Dec 2016, 06:21
Hi everyone. I've read through this thread and while I saw plenty of artwork, I was hoping there would be an Eagle layout to share. Anyone? I'd like to send this sucker to Oshpark since my PCB efforts tend to rust everything around me. Since they have a 3-board minimum, I would most likely have a spare board if someone needed it.
"I think being funny is not anyone's first choice" - Woody Allen
dave_b
Postby mwelch55 » 02 Dec 2016, 20:07
I have heard it mentioned in this forum that you can build the Tight Metal and Tight Rock from the same layout, but with different component values. Does anyone have the component values of the tight rock (or a schematic with values)?
Mike
mwelch55
Postby dave_b » 07 Dec 2016, 18:44
mwelch55 wrote:I have heard it mentioned in this forum that you can build the Tight Metal and Tight Rock from the same layout, but with different component values. Does anyone have the component values of the tight rock (or a schematic with values)?
Mike
Hey Mike, have a look at J0K3RX's post here:
viewtopic.php?f=7&p=235354#p236432
dave_b
Postby dave_b » 07 Dec 2016, 18:49
dave_b wrote:Hi everyone. I've read through this thread and while I saw plenty of artwork, I was hoping there would be an Eagle layout to share. Anyone? I'd like to send this sucker to Oshpark since my PCB efforts tend to rust everything around me. Since they have a 3-board minimum, I would most likely have a spare board if someone needed it.
Nevermind, I missed the fact that J0K3RX posted his DipTrace file. Thanks man! :-)
dave_b
Postby J0K3RX » 10 Dec 2016, 01:45
Mike
Look 2 posts above your post.. There you will find your answer :wink:
J0K3RX
Postby J0K3RX » 10 Dec 2016, 04:04
Yeah, sorry man.. I've been busy lately and didn't check fsb to see if there was any activity. Been kinda dry around here lately as far as any high gainers go so, I kinda shifted my attention elseware. I really wanted to get a (correct) schematic for the Friedman BE-OD pedal but, it kinda died off and went into guess/speculation mode.. Hopefully somebody will get hold of one of the pedals again so we can connect the dots/fill in the blanks..
J0K3RX
Postby ilshat » 09 Jan 2017, 18:49
J0K3R!
Great stuiff and great your work.
I've been doing on your circuit on layout brejna
And now I think how to fit into the housing DOD Death Metal. Sorry for my English :oops:
ilshat
Has thanked: 28 times
Postby Belanger88 » 23 Feb 2017, 22:10
which capacitor would you guys recommend putting on a rotary switch? I've got some 2p6t switches and some etched PCBs for them that fit 6 caps
I really want to get a bigger fat metal type tone. seeing how close the TR and TM are it makes me wonder what changes I could make to the tone stack to get a similar tone
thanks ahead of time for any advice!
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
Belanger88
Has thanked: 104 times
Have thanks: 32 times
Postby J0K3RX » 05 Mar 2017, 21:02
I was gonna get a BigRock Pro and bust that bad boy opened so we can dissect like Dr. G Medical Examiner :evil:
The reason I decided to get a BRP is because a forum member (who I will not name unless he says it's ok) sent me a bunch of excelent gut shots of the Tight Metal Pro. The pics are great but, even with all the great pics it's still gonna be damn near impossible to trace without the actual pedal in hand... So, I figured since the TMP and the BRP are both built using the same boards I would buy a BRP, trace it and use the pics from the TMP to find the differences and then we will have both! Be like killin 2 pedals with 1 BigRock! :twisted: I will start a new topic when I begin.. Who's up for it?
From looking at the pics this is one heavy duty no bull shit pedal! Very well layed out all crazy Amptweaker style with quality components and looks to be all hand soldered which is nuts if you're building thousands of them!! The enclosure is made of thick ass steel armor like all the rest... I think it's one of the best built pedals around man, these fukers ain't no joke!!
Link
For this message the author J0K3RX has received thanks: 2
Belanger88 (07 Mar 2017, 07:15), brejna (05 Mar 2017, 23:27)
J0K3RX
Postby J0K3RX » 06 Mar 2017, 06:14
Alright.. Got it, on it's way. :wink: Should be here middle of the week, latest maybe Thursday.
For this message the author J0K3RX has received thanks: 7
bmxguitarsbmx (06 Mar 2017, 17:30), brejna (06 Mar 2017, 15:32), EmmG (06 Mar 2017, 08:54), Ichabod_Crane (06 Mar 2017, 10:13), marmaliser (06 Mar 2017, 14:38), peterc (06 Mar 2017, 10:09), Zokk (06 Mar 2017, 10:40)
J0K3RX
PreviousNext
Users browsing this forum: abakuzam, BomBon, destro, Jeffology, paleojenn and 7 guests
