AMT - Legend Amp Series 2  [traced]
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
ggedamed wrote:You're not talking about the thing that Burgs does with his left hand index, are you?
Hope you don't mind me insisting on this :cheers, the sound artifacts are really difficult to explain or even point to.
Well spotted, the little vibrato hammer type of thing he does, also at the 5.05 mark toggling of the pickup switch and it also looks like just before that he may just catch the vol knob.
phatt
Been thanked: 343 times
Post by phatt »
I don't mind if you insist,,, all good. :thumbsup
Between 5:03 and 5:04 there is a fast flurry of notes and there is a lot of mud (maybe the term is inter-modulation)
The P2 is even more pronounced
At 0:43 it spits for a split second on a bend up and again at 0:47 another fast riff,, spatters badly.
Just sayin,,That would bug me. :x
Phil.
Nicht Bernd
Has thanked: 98 times
Been thanked: 7 times
Post by Nicht Bernd »
The pcb is far too big for a 1590BB. What kind of box do I need?
DimebuGG
Been thanked: 198 times
Post by DimebuGG »
I made a through hole pcb of this for 1590BB type enclosure. Although it's already done, I need to take a look at it again before posting. 8)
What will be the necessary adjustments if 18-24V will be used to power this circuit?.
phatt
Post by phatt »
DimebuGG wrote: What will be the necessary adjustments if 18-24V will be used to power this circuit?.
I'd guess,,,,,,,,,a complete redesign. :blackeye Which will likely achieve very little benefit.
If it ain't broke don't fix or frigg with it. [smilie=a_whyme.gif]
Phil.
Has thanked: 596 times
Been thanked: 2061 times
they were designed for 9v dc - phatt is spot on with his comment - use the correct voltage for the correct response
J0K3RX
Has thanked: 316 times
Been thanked: 556 times
Post by J0K3RX »
I think they can use up to 12V... I wouldn't go a hair over +300VDC but, it might be fun to watch somebody else try! :twisted:
DimebuGG
Post by DimebuGG »
J0K3RX wrote: I wouldn't go a hair over +300VDC but, it might be fun to watch somebody else try! :twisted:
Oh yeah, will definitely try that.. :wink:
Ice-9
Post by Ice-9 »
Yeah.. I says 9-12v on the tin, and they sound bloody good so no point I changing the voltage.
DimebuGG
Post by DimebuGG »
Here it is..
Thanks to bajaman for allowing me to attach his schematic. :applause:
AMT LegAmp2 PCB.pdf
(488.38 KiB) Downloaded 1608 times
J0K3RX
Post by J0K3RX »
DimebuGG wrote:Here it is..
Damn!! That is some crazy trace work!! Nice job!
J0K3RX
Post by J0K3RX »
Found these in the "guitar-gear.ru" forum.. posted by forum member mrubanoff :wink:
P2pot_1B-circuit.PDF
(421.96 KiB) Downloaded 846 times
P2pot_1B-assembly.PDF
(402.84 KiB) Downloaded 566 times
P2-base_1B-circuit.PDF
(396.01 KiB) Downloaded 637 times
P2-base_1B-assy.PDF
(359.86 KiB) Downloaded 524 times
Ice-9
Post by Ice-9 »
J0K3RX wrote:Found these in the "guitar-gear.ru" forum.. posted by forum member mrubanoff :wink:
I haven't had time to compare these against the traces me and Bajaman made, have you spotted any differences ? :popcorn:
J0K3RX
Post by J0K3RX »
Nope, just stumbled across them while looking at other stuff and though :hmmm: better grab these before they disappear into the abyss.. Funny though because I think mrubanoff was explaining a problem with the P1 and asking for help to find a resolution but, I could be wrong..? The translation was horrible at best.. Klingon language would probably have made more sense :scratch:
orcl2
Post by orcl2 »
Hi folks! Someone had tested this schem?
masramdhani
Post by masramdhani »
Thanks bajaman for your schematic.
I made a E2 clone based on your schematic. I use it as a preamp pedal, so i'm not building the drive and the cabsim out. In my country, 2sk208 and 2sk30R is quite rare, so i'm using only 2N5458, J201, and J177. By changing the JFET,re-adjustment of the resistor value for the amplifier stage is needed. I use 1 10k multiturn trimpot to solve those problem especially on the drain resistor. So far the sounds is acceptable. But, i hear a slight of "fart" when the sounds fade out. Still working on it.
Anyway thanks guys :thumbsup :thumbsup :thumbsup
Statzern
Post by Statzern »
Has anyone built this yet? I have the AMT E2 which I love and would love to build just the high gain sections for preamps, but this PCB is big! Would even fit in a 1590BB? Looks like barely from the measurements.
POTL
Has thanked: 58 times
Been thanked: 67 times
Post by POTL »
I correctly understand that the p-channel Jfet(T5/T7/T9) for the offset of the n-channel Jfet(T4/T6/T8) but does not affect the sound?
mnemonic
Post by mnemonic »
bajaman wrote:they were designed for 9v dc - phatt is spot on with his comment - use the correct voltage for the correct response
I was wondering this also, I like to experiment with different voltages, and often pedals will function differently at higher voltage. I can understand how some wouldn't like that change in response and would consider it 'sterile', but a lot of stuff tends to sound punchier to me at 18 volts.
There was mention earlier in the thread of some of the electrolytics being 25 volts, so if all of them were atleast 25 volts I would think the pedal would be fine at 18 volts, right? I googled the data sheets of the transistors and that is still well within their ratings.
I'll have to open up my R2 soon and check the cap voltages. It sounds great at 12 volts but now I'm curious.
RockKenny
Post by RockKenny »
