DOD250: adding a tone control
I'm still really enjoying messing around with my DOD250.
I've been reading about tone stacks on pages like this:
http://amps.zugster.net/articles/tone-stacks
and
http://www.beavisaudio.com/techpages/Bi ... neControl/
But, being a noob, I can't really grasp how I would add a tone control to the 250 circuit. Building the separate housing like Beavis recommends looks pretty easy, but not exactly what I'm looking for.
Can anyone offer some help?
and
- jimbob_400
Choose your tone stack. Disconnect the wire going to the volume pot (coming from 2 diodes a 10k resistor and a 1nf cap) move this wire to the input of your chosen tone stack. From the output of your tone stack go back to the volume control. The next part is optional.jagermonster wrote:I'm still really enjoying messing around with my DOD250.
and
Technically a good thing to do next would be to buffer the output of the pedal. Take lug 2 of the volume pedal and disconnect it from the switch. Take this to a simple bipolar transistor buffer and then take the output of the buffer to the switch.
Thanks a lot for taking the time to make a thorough reply.
So, if I'm understanding correctly, the tone stack is the last thing in the circuit? Essentially, just place it between the output of the circuit board and the volume control?
- roseblood11
The DOD 250 doesn´t deliver very much volume, and the tonestack steals away some more decibels.
That´s why many similar pedals have another gain stage after the tonestack...
This makes total sense.roseblood11 wrote:The DOD 250 doesn´t deliver very much volume, and the tonestack steals away some more decibels.
If I use LEDs as clipping diodes, would this raise the volume level enough to compensate for a tone section?
- jimbob_400
or just use my output buffer suggestion but use the transistor to increase the gain of the signal a bit to compensate for the tone stack.
- Completed builds: Fuzz Face, Small Stone, Trem Lune, Fet Muff, Big Muff (green), Fuxx Face, Son of Screamer, Rat, Rebote 2.5, Opamp Big Muff, EA Tremolo, Easyvibe, Axis Face Si, Ross Compressor, Ross Distortion, DLS
- Has thanked: 2 times
- Been thanked: 2 times
- Contact:
For instance, Rat has a Fet stage after the tone control, you could use that trick.
If you scoop, it sounds like poop!
- roseblood11
