need help adding reverb to peavey windsor head
Postby Jayallen » 27 Dec 2016, 03:36
I need help with were i put the in and out signal for this one tube reverb on a peavey windsor head.
Jayallen
Re: need help adding reverb to peavey windsor head
Postby phatt » 28 Dec 2016, 09:03
I'd try inserting after *C13* which is the output of the preamp section. (post FX loop)
You will need to insert a series resistor,, same as the 100k on the Carolina schematic.
You will likely have to raise the value of the series resistor to get a convincing reverb.
There will likely be some signal loss but as the circuit has plenty of gain it may not be a problem.
Phil.
phatt
Have thanks: 264 times
Return to Amplifiers
