Bogner - La Grange  [traced]
maoriente
Post by maoriente »
Frank_NH, question:
Any idea how much gain is eaten up in the presence section, if at all?
With the gain switch set at highest, source resistance to ground for the gain switch stage is about 97R.
Looking at the spreadsheet provided (thank you!) I think that indicates with an 18v supply, that stage would have a gain of 37, then passes through the presence "filter" and then if using a 510R source resistor in the next stage, followed by a 330R source resistor in the next stage, the signal would then be increased by an additional gain of about 120 ( 9 x 13.5).
And if all that's true, [gain 37 > presence filter > gain 120] how could it not be squealing :0)
Frank_NH
Has thanked: 114 times
Been thanked: 152 times
Post by Frank_NH »
I'm not sure how much signal is lost in the presence section, but if the current La Grange schematic is to be believed, this section is nothing more than the Box of Rock (see below). Note how the B.O.R. also has two gain stages in a row, followed by the tone stack and output. Also notice that the boost function is placed at the end. I've built a version of the B.O.R. on vero so I know it works well. With the La Grange, you essentially have all of this boost/gain/tone shaping/clipping being fed into a B.O.R., so no surprise this becomes over the top gainy and subject to feedback/squealing. Thus, it's likely there are still some issues with the current La Grange schematic.
maoriente
Post by maoriente »
Yeah, and I'm not so sure it even sounds like a plexi as it stands.
I boxed it up, maybe the squealing is a bit better.
The high gain switch is a bit over the top for me, I still need to check the high gain setting with lower gain knob settings and/or other clipping positions. Maybe there is some use for it, but way to much gain with the gain knob mid way.
I also need to pay attention to the actual tone, so far it's been all about eliminating the squeal, oh, and it still squeals fairly easily in the high gain mode. But still, the 5k value seems to give the most flexibility with the gain switch and gain control.
With a 50k gain pot, and 5k source resister (rather than 53R), the low and mid gain settings seemed ok, with more than enough gain/distortion.
Check out the last 30 seconds of this video, sounds familiar...
maoriente
Post by maoriente »
I just found this video this morning.
So it seems the high gain flabbiness and squeal are built in to the original pedal after all.
The high gain mode demo starts around 23 minutes and the squealing about 24:35.
Looks like high gain on, variac off, presence on, gain knob about noon, structure any position and the squeal is heard, just like my build.
I have to say, mine does sound a lot like this video.
I am re-inspired to get it dialed in. Going to spend some more time with the 53R - 5k source resistor value to try and match this video.
Has thanked: 1671 times
Been thanked: 1344 times
Post by Manfred »
Thanks for exploring the circuit. :thumbsup
Tjarko
Post by Tjarko »
Hello for all those guys who had the noise problem with from the voltage converter.
I just made the layout for the la grange on tripboard. I used the lay out from tagboard effext.
First I had also the noise/wissle from the from the 7660 chips. When I looked at the photo's from the original PCB, I see a lot of caps and big elco's around the max1044 and TL1054. That is why I did the following:
I put on te 18volt and the negative convertor small 100nf caramic caps on the in and output(to the ground) I soldered them close to the IC's, just on top of the taggboard to one of the ground jumpers.
I also replaced the elco for the 18V for 100uf and the 47uf I used for the negative output. In the 18 volt part I put a LT1054.
After this mods the cirquit is rather sillens...............
maoriente
Post by maoriente »
"After this mods the cirquit is rather sillens..............."
Thanks for the power supply tips.
Question, does your pedal squeal with feedback when the gain switch is set on high, presence on, and gain knob past noon?
Tjarko
Post by Tjarko »
Yes, on the high gain position it can stik squeal. Tomorow I will put the board in a metal box. I will see what that will do.
There is a few more thing that are still not right in the schematic. The vallue of the pot in the booster shoot be lower, in the other fet boosters they use 5K. I have order a 5k reverse log, I hope that wil give a better result.
And than wiring round the gain pot........... First I had connected the 100nf/33uf to te top op the pot. The middel/sleeve is connected to the 470nf and the 2m2 resistor. That dint not gave a smoot regulation of the gain. Looking at the schematic, there is something strange. A 2m2 resistor paralel over a 22k pot makes no differrend. So I touhgt, maybe the value is not right and I swapped is for a 22k resistor, that will change the pot curve a lot. My fist impression is that it gives a good controle for the gain.
When my build is boxed ands the knobs are on I can give a review of this mod.
Post by Manfred »
That mod has only a little effect, the start gain is about one now and will increased about two using the 5kOhms Pot.
I drew your gain pot mod, is this circuit correct:
Tjarko
Post by Tjarko »
Hi Manfred: The gain pot cirquit you drew is rihgt, that's how I did it. I only changed the 2m2 resistor in 22k to give a better range. A 2m2 resistor make no sense in the cirquit becuase the pot gives always a lower resistense.
The 5 k pot...I ment the booster pot. I am still srugling with that one. I have the booster behind the main cirquit. I have the pot from the 4u7 to ground
A 20k lin pot gives does not give a smooth range, only a quarter of the pot gives effect on the gain. I cannot find a 20K reverse log.
The exepriment with the 5 k pot gives a smooth regulation. The only thing, lowest gain is still to high.
Do you haven suggestions to get the booster well working
diafebus
Been thanked: 12 times
Post by diafebus »
How is the project doing? :horsey:
jaimebcn
Post by jaimebcn »
Hi all!
I read a lot on freestompboxes through years, awesome community!
I came from ... Probably Youtube or another forums feeding my GAS , LOL! I can't remember! Anyways I'm interested in this post. What happened at last?
I'm trying to read and understand all of the info explained.
Lithium_Grim
Has thanked: 39 times
Been thanked: 72 times
Post by Lithium_Grim »
If I look at the Eagle trace and the different schematics I see some differences to both the first schematic of Saruman and the updated one of Manfred.
Bogner La Grange Boost only.JPG (17.56 KiB) Viewed 3572 times
The difference is that compared to Manfred's schematic there is an additional pulldown resistor R13 and C2 is reversed. Offcourse the Eagle trace could be wrong, but let's say it's right, than this should be the corresponding boost schematic.
I only give negativ feedback and y'all love it!
PCB shop
Post by Manfred »
Lithium_Grim wrote:If I look at the Eagle trace and the different schematics I see some differences to both the first schematic of Saruman and the updated one of Manfred.
Thanks for the hint.
On the schematics above the gate-source protection diodes are shown with different values, which is right value?
Is there anything else to make changes, before I redrawing the schematic?
Lithium_Grim
Manfred wrote: On the schematics above the gate-source protection diodes are shown with different values, which is right value?
No, no other real changes. You could consider adding more of the DC filter caps as in the original (100uF/47uF electrolyte and 100nF MKT/WIMA) just after the LT1054/ICL7660s +18V and -9V.
All zeners can be 10V with exception of the zener at the beginning of the power section. I'd take a 12V there.
PCB shop
Post by Manfred »
Please, make a sketch to me.
Lithium_Grim
This is a way to make the powersection (componentnumbers are not the same as in the eagle trace of the la grange!)
PCB shop
Post by Manfred »
Thanks,
as I see it you using the SPlan software too.
I attache the zipped SPlan drawing file, then you can make the changes yourself.
BognerLaGrange.zip
(15.64 KiB) Downloaded 191 times
Post by Manfred »
Lithium_Grim wrote:This is a way to make the powersection (componentnumbers are not the same as in the eagle trace of the la grange!)
The attachment Powersection.JPG is no longer available
I made the changes according your sketch and your annotations.
Post by Manfred »
I have another question regarding the "J1" switch, by means of which the connection between pin1 and pin8 can be opened and closed.
Is the switch applied in the circuit?
