Sarno Earth Drive
sugarinthegourd
Post by sugarinthegourd »
moved to REQUESTS FOLDER.
sugarinthegourd
Here's a pic of the back of the board. 3 board-mounted pots, maybe an IC in the center. Looks like fairly low parts count. YATS?
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
Any updates on this?
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
Two IC's - maybe a TS with opamp buffers, aka vintage Maxon OD-808?
aegert
Has thanked: 39 times
Been thanked: 56 times
Post by aegert »
Bump to poster.. any pics of the front
Kitrae
Been thanked: 29 times
Post by Kitrae »
I did not photograph the other side when I reviewed it, but I can tell you is is TS based.
Kitrae - Muff junkie
Big Muff Page
http://bigmuffpage.com/
Tonbender Timeline
http://www.bigmuffpage.com/The_Tonebender_Timeline.html
Cub
Has thanked: 102 times
Been thanked: 118 times
Post by Cub »
Thanks, Kit ! I half expected it to be TS based. Brad Sarno did well on this one.
Normally, I really don't like the sound of a Big Muff going into a Tube Screamer, but the clip you posted with your review sounds great.
ozzy666
Has thanked: 75 times
Been thanked: 12 times
Post by ozzy666 »
Any update on this?
GratefulEight
Post by GratefulEight »
I might know someone that took some gut shots of an EarthDrive they bought years ago...this same person might have done a full trace after getting pissed off that the diodes were gooped and the IC sanded. I was able to find the pictures and some of the parts values for now.
I do know the IC was eventually determined to be a 4558; the sanded one was put in a test circuit and had voltages measured at the various pins under several sets of conditions that matched pretty much exactly with a labeled 4558.
Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image
GratefulEight
Also found one of the back:
And the schem from that trace I mentioned:
Has thanked: 1675 times
Been thanked: 1359 times
Post by Manfred »
I redrew the circuit diagram, so you can see the circuit structure better.
My guess for the IC are TL072 or CA3240 and for the germanium diodes 1N34A.
GratefulEight
Manfred wrote: 19 Sep 2022, 00:00 I redrew the circuit diagram, so you can see the circuit structure better.
I know a TL072 was tested and didn't measure in the same ballpark as the mystery IC; not sure about the CA3240. Also not sure about the exact testing methodology, whether it was a reliable way to make an informed guess, or anything else about that part really.
GratefulEight
The Ge diode (clear DO-7 with 2 black stripes--see picture) that survived de-goop measured Vf = 0.644V, with a test current of 4.294mA on a Peak DCA55 tester; a standard DMM said 0.241V on diode test mode. Not sure why the discrepancy...leakage? Low DMM battery? :scratch:
mauman
Has thanked: 435 times
Been thanked: 184 times
Post by mauman »
Your DMM probably uses around 1mA for testing diodes, while the Peak used 4.29 mA. Diode forward voltage drop varies with current, and makes a curve that increases with increasing current. A reading of 241 mV @ 1 mA and 644 mV @ 4.3 mA would be in the normal range for Ge diodes.
Intripped
Has thanked: 990 times
Been thanked: 305 times
Post by Intripped »
@Manfred
1N4001 diode not correctly oriented
C3 is 100pf in GE's schem
Post by Manfred »
Intripped wrote: 19 Sep 2022, 09:37 @Manfred
Thanks, I fixed the wiring diagram in the post above.
Post by Manfred »
GratefulEight wrote: 19 Sep 2022, 02:40 The Ge diode (clear DO-7 with 2 black stripes--see picture) that survived de-goop measured Vf = 0.644V, with a test current of 4.294mA on a Peak DCA55 tester; a standard DMM said 0.241V on diode test mode. Not sure why the discrepancy...leakage? Low DMM battery? :scratch:
I got a bunch of 1N60P Germanium diodes that look the same as the diode on your snapshot, also the readings are in the same range.
Reading: Vf=0,736V at 5,00mA
Nocentelli
Has thanked: 1154 times
Been thanked: 954 times
Post by Nocentelli »
So essentially Paul Cochrane's Timmy, minus the bass pot but with half ge diodes?
Post by Manfred »
Nocentelli wrote: 19 Sep 2022, 11:52 So essentially Paul Cochrane's Timmy, minus the bass pot but with half ge diodes?
In fact the same circuit structure, then what's the point of gooping components. :?: :o
The circuit copier fears nothing more than that his circuit is copied. :)
