Ground humming
Ground humming
Postby mingorius » 25 Mar 2017, 15:12
Hi, I am new in building DIY guitar pedals.
I own a project studio and started to build some pedals to experiment while mixing tracks with them.
I built a simple overdrive first. It works well, but there is a humming, which is kind of loud.
If I touch the output-cable it goes away.
Does anybody know a "trick" to kill the humming by wire the ground to the chassis or anything like that?
mingorius
Re: Ground humming
Postby phatt » 27 Mar 2017, 08:56
Yes Ground the chassis!!!
In some cases with a lot of interconnections you may need to do the opposite. Some DI boxes have a switch to lift the ground.
Jensen transformer site used to have a whole list of PDF files relating to grounding issues and how to solve them,,have a search of their site,,
it may still be there.
HTH,, Phil.
phatt
Have thanks: 266 times
Users browsing this forum: zoof and 3 guests
