Arbiter - Treble & Bass Fuzz Face  [schematic]
Chugs
Has thanked: 63 times
Been thanked: 47 times
Post by Chugs »
I have a couple of Fuzz face enclosures and the distance between the centres of screw holes is 51mm.
rustyg
Post by rustyg »
Thanlks but been there, done that...
I have this beast so I don't need the schematic or values; I can just look at my board.
It's the OFF BOARD wiring I'm interested in. I've done a fairly thorough web search & have come up dry. Any one have any other resources to the OFF BOARD WIRING? from the pictures on the web, it looks typically 'British'.
phatt
Been thanked: 343 times
Post by phatt »
Never seen one in the flesh but I was under the understanding that these unit where *positive ground*?? If so the then the pictures make sense as the red positive goes to ground.
Check the electros for clues as they will also be polar reversed.
Phil.
Been thanked: 909 times
phatt wrote:Never seen one in the flesh but I was under the understanding that these unit where *positive ground*?? If so the then the pictures make sense as the red positive goes to ground.
Phil.
Yeah, that sets me off. I did the wiring layout but stopped at battery connection. The schemo I have is for BC109, all we know thats NPN trannies....
phibes
my favorite amplifier: HIWATT motherfucker!
Has thanked: 75 times
Been thanked: 189 times
Post by phibes »
What's confusing about the off-board wiring? It should be pretty straight forward to figure out from the schematic regardless if it's it neg or pos ground.
Image Ken
phibes wrote:What's confusing about the off-board wiring? It should be pretty straight forward to figure out from the schematic regardless if it's it neg or pos ground.
Not quite. Schemo screams for NPN silicons, and wiring picts shows positive (red wire) going to ground.
phibes
Post by phibes »
Ah I see. Well all wire coloring in the OP unit match all the old photos I got of other units so the off board wiring looks right. Two red wires look replaced but they we're hooked back up right, same with color. I never really looked closely at this one but yeah, the jacks are grounding to positive and the battery is being disconnected from the circuit off the positive wire so good catch there! I'm surprised that wasn't noted in the schematic in the other thread.......
Does the unit work?
Image Ken
Want some more confusion?
E-caps on the same picts I was referring to are pointed negative to ground!
I say WTF?
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
Topics merged.
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
DrNomis
Has thanked: 98 times
Been thanked: 279 times
Post by DrNomis »
Just wondering if anyone's finished building one of these and if so, how much bass/treble boost do you get with it?..... :hmmm:
phibes
Post by phibes »
sinner wrote:Want some more confusion?
I say WTF?
Yeah I can see the confusion now after eyeballing it. It looks wired for positive ground. It'll work either way as the electros are facing where they gotta go. I wonder why they did it that way? Did they do the same on the silicon Fuzz Faces?
Image Ken
Electric Warrior
Has thanked: 23 times
Been thanked: 104 times
Post by Electric Warrior »
No, they're usually wired up correctly.
gigelmargel
Has thanked: 111 times
Been thanked: 23 times
Post by gigelmargel »
Hello all,
I want to build an Arbiter Bass/Treble Face, but I didn't find a layout of the parts. I've tried to retrace it using the photos from this topic, but I don't have enough skills to do that.
Can anyone help me?
Best regards,
Radu
LucifersTrip
my favorite amplifier: Companion Psychedelic Machine
Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
Has thanked: 19 times
Been thanked: 71 times
Post by LucifersTrip »
shouldn't the schematic be cool enough?
viewtopic.php?f=19&t=10359#p109284
gigelmargel
LucifersTrip wrote:shouldn't the schematic be cool enough?
Thank you LucifersTrip!
I've seen the schematic, but in the photos I saw some capacitors that I couldn't identify. I will try again, using both the schematic and the photos.
Best regards!
LucifersTrip
Cool...if you find something different, let us know
Has thanked: 4410 times
Been thanked: 2139 times
Arbiter - Treble'N Bass Face (1966)
Arbiter - Treble'N Bass Face gut shot 3
Arbiter - Treble'N Bass Face gut shot 2
Arbiter - Treble'N Bass Face gut shot 1
Arbiter - Treble'N Bass Face  case
The Rotagilla
Post by The Rotagilla »
If anyone saved the schematic could they re-post it? Thanks.
bluesbreaker62
Been thanked: 31 times
Post by bluesbreaker62 »
Here you go :thumbsup
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
