Just want to say thanks to all you folks!
Postby mistermikev » 07 May 2017, 01:48
Really grateful for this site. Learned so many things lurking here.
Just finished a wet cat. Had a hard time tracing the audio path as I wasn't sure if it should match the dm2 schematic. Realized my 571 was backwards and things started to make more sense. traced a little further and found wrong orientation for q4 transistor in delay path on the mn3005 layout (picture)... but the pins were right and now that I think about it that might be mentioned somewhere in the thread.
Very thankful to baja and others who did the work for projects like this. You guys are really great for sharing.
I have all the parts on the board populated... so all the real work is done... now I just have to get it working.
mistermikev
Re: Just want to say thanks to all you folks!
Postby bajaman » 07 May 2017, 10:52
you are most welcome - glad you got it sorted :D
Has thanked: 374 times
Have thanks: 1100 times
Postby mistermikev » 07 May 2017, 19:17
your projects are like gold baja. guaranteed to work as long as you follow the bouncing ball.
I have a sabre2 in 3 guitars and a stingray in 3 basses.
been thinking about attempting the real tube project but it looks like you almost need welding skill to do that!
mistermikev
Return to Freestomp Café!
