JHS Prestige
- POTL
Hi
Let's try to trace this
This pedal came on a mini mini bomb, which was based on a single JFET transistor
The mini bomb schemaешс is presented below Inside the pedal there are 3 transistors, one in conjunction with a diode (similar to SHO)
As well 2 transistors in a pair (something similar to mu-amp)
In the Ruby Red & Kilt pedals, a new booster is also being used (which is similar to the components with the Prestige stuffing).
JHS describes this as a 2-stage booster.
Guts
Maybe someone has a Prestige and he will share photos of guts in HD
Link to JHS Kilt, there is HD photo and booster inside
Guts
- POTL
Perhaps you are confusing this with the previous version of the booster, which was called Mini Bombplush wrote:Nah. Prestige is a clone of Tim Escobedo's Duende jfet boost (not a mosfet version).
More Tim's stuff here: http://www.diale.org/escobedo.html
In the upper left corner are in the element one this is exactly a transistor, and the second is similar to a diode (although this can also be a transistor).
In the middle of the pedal, the diode resistor and the transistor are responsible for turning on the LED.
But thanks for the link, maybe I'll find something interesting.
- Nocentelli
- Has thanked: 1155 times
- Been thanked: 954 times
What's this? I don't think it would pass any signal.POTL wrote: But thanks for the link, maybe I'll find something interesting.
- mirosol
It won't. You'll end up with a FET that's not working at all and you'll have something like 7,5V DC at the output.Nocentelli wrote:What's this? I don't think it would pass any signal.POTL wrote: But thanks for the link, maybe I'll find something interesting.
It needs to be like this: On the other hand, i'd draw this circuit like this: ...but that's just me.
http://mirosol.kapsi.fi/
- Ben N
I've done something similar, but with a round solder lug on the end of the wire and a tiny bit of aluminum milled away from the top of the screw hole, so when the enclosure is closed the lug is securely sandwiched between the enclosure and the lid and secured by the screw. Works just fine, especially when the jacks are insulated from the enclosure.
