Friedman BE-OD Pedal [traced]
- HamishR
I just built one of these with one of Buggs' PCB - it was a lot easier than building it on Vero! It works perfectly and was a breeze to build. Thanks Buggs!
I did use a 470p instead of the 120p, but forgot to test it at full gain yet. It has all the gain I need at noon! I've been playing it with a Strat and a Homebrew Tele and it sounds pretty amazing. Well it sounds just like my vero version but it's more compact which is nice. I played it first with the stock TL072s and with those it's a little harsh in the high end. Some guys like that but I don't. So I swapped them out for NE5532s and while the sound isn't radically different it is definitely smoother and rounder - I like it. I have a healthy scepticism of the benefits of op-amp swapping but can actually really hear it this time. I seem to like the NE5532 in every pedal I've swapped out the TL072 for it.
So it's a great dirt pedal but I'm not sure if I like it any better than the Rockett Dude I got recently. I'm not a metal player and for me the two pedals cover similar ground but the Dude is more touch responsive. Now THAT would be a great pedal to build. I looked inside and it's like a little SMD city! Way too hard for me to trace.
This sounds promesing. Have my second build loaded with ne5532 chips almost done. Next week I'll A/B both variants. Kind of hope for the ne5532 to sound better. I have a theory on op amps and sound charackteristics and i hope this build wond wreck itHamishR wrote:I played it first with the stock TL072s and with those it's a little harsh in the high end. Some guys like that but I don't. So I swapped them out for NE5532s and while the sound isn't radically different it is definitely smoother and rounder - I like it. I have a healthy scepticism of the benefits of op-amp swapping but can actually really hear it this time. I seem to like the NE5532 in every pedal I've swapped out the TL072 for it.
- bmxguitarsbmx
You are pre-loading yourself for confirmation biasandlord wrote:.... Kind of hope for the ne5532 to sound better. I have a theory on op amps and sound charackteristics and i hope this build wond wreck it
I tried tlo72, lf353,tlc2272cp, ka4558. The tlo72 was the best, lf353 good, tlc2272cp was the worst and I would even say it sounds bad.
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Why not go the whole hog - OPA2604, LM4562, OPA2134 etc
- jalmonsalmon
And in a band situation... you would never really notice any differences in opamps imobajaman wrote:Why not go the whole hog - OPA2604, LM4562, OPA2134 etc
As FZ use to say...
Shut up n play yer guitar!
- bmxguitarsbmx
I respectfully disagree with this philosophy. If you are inclined to strive for every last bit of tone possible, I am inclined to buy a pedal from you. (whoever you may be )jalmonsalmon wrote:And in a band situation... you would never really notice any differences in opamps imobajaman wrote:Why not go the whole hog - OPA2604, LM4562, OPA2134 etc
As FZ use to say...
- HamishR
The whole reason I say I have a healthy scepticism re the differences op-amps can make is because in previous builds I have tried many different op-amps, from the JRC4558 to TL072, TL082, TL062, TL272CP, OP275GP, OPA2134PA, and probably some others I can't remember. To be frank I rarely hear a difference so have stuck with the TL072 or OP275GP, because I have read that they are good chips.
I only tried the NE5532 because lVlark at Guitar FX layouts said it was a good one to try. So I tried one in a pedal of mine that I am very familiar with which I normally use a TL072 in and was surprised that yes, I could hear a difference. Wow. The difference is small but worthwhile going to the trouble of swapping a chip for. In the OD-BE there are 3 chips, so maybe the differences are magnified? I don't know. But I definitely hear enough of a difference to make it very worthwhile for me. The difference is difficult to describe, but I would say that the highs are less harsh/confused. Maybe the chips attenuates the highs a little? Again, I don't know, but the highs sound smoother and more connected to the note to me. The midrange is a little fuller which is a good thing because to me the TL072 version lacks a little there. Maybe it's just that the highs are soother. These differences are something I heard in the original pedal I tried the NE5532 in, so seem to be consistent with the chip. I know that everyone hears things differently, so what sounds different or better to me may not to you.
I only posted my "findings" in the hope that maybe someone may enjoy the differences I did. If you don't hear it, no biggy, but that doesn't mean I can't hear it. If you socket the ICs like I do then it's easy to swap and compare. Indeed knock yourself out, go the whole hog and try as many chips as you like. Hey, I intend to try the ZTX951 transistor as diode thing. Why not? Isn't this why we build our own pedals? If I was only ever going to build a pedal dead stock I would simply buy it. The only point in me building pedals is to try something different, to try and make the pedal better for me. I can't see why anyone would poo-poo the chance to experiment here!
Maybe before you blank the comment, try it for yourself so that you actually KNOW what will happen. My initial thought was that a chip swap would make no difference, but how hard is it to try? And for me it turned out to be a good thing.
- bajaman
sorry
After a short A/B session I'm confident to say that the NE5532 sounds really close to the TL072. A bit different on the bottom end but similar enough. Gonna keep the chips where they are right now and test again later. Had to make a break because my son has to sleep now
I've just built this on Bugg's pcb and while it sounds great, it's pretty noisy. Sticking a klon buffer in front has made it much quieter. Any other suggestions for bringing the noise floor down? Someone said something about changing a cap to 2n2...
Oh yeah, I'm only getting one pair of the LEDs lighting up.
I'm going to do a two channel version for volume and gain, with another footswitch for changing the tight pot.
- HamishR
Haha no worries Bajaman! Can't be mad at a Kiwi.
FWIW I used a 470pF as someone else suggested instead of the 120pF and I tested it with gain on full. No oscillation or anything. But I do have the internal trimmer turned right down. This thing has plenty of gain.
See this is why I reckon it's good to try these things - andlord finds the bottom end a bit different - in mine the top end sounds different. So many variables of course - guitar, amp, other pedals, and we really do all hear things differently.
Anyway I am super impressed with Buggs' PCB. I don't use PCBs very often - I'm usually building amps on tagboard or turretboard, or pedals on vero. This PCB has been a piece of cake to build a pedal with. I bought two so that I could build one more or less stock and one using Bajaman's suggestions.
- Jan1966
Bit confused
This is a great pedal for sure. I have built it and it from Buggs pcb and it works perfectly. I have bought the original pedal and it is great. However the high gain distortion can be achieved with with simpler circuits.
For instance Dead Astronauts spitfire with the schematic readily available. I have built this and it sounds awesome.
Just my thoughts on this.
- Optical
Just got mine going on the thermonic distortion PCB. Built stock and it works great.
A little oscillation but mine is not in an enclosure yet. The 120pF feedback cap is currently 150pF, will try 470pF and swapping some opamps around next to see what happens to the tone. The noise floor on mine is also high which id like to improve - If the 470pF cap isnt a significant improvement I might try inserting a peavey noise gate like the VH4 pedal has.
Love the tone though, really great.
I removed and socketed the 120p and played around until I was happy. I went up through the pf values to 4n7, stuck a 47n in for poops and giggles, and ended up going with a 1n5. Much happier, seems like a good compromise.
- bajaman
perhaps bool is right - my simulations show that the 4KHz peak in response is reduced nearly 15dB as a consequence of increasing the 120p to 1200p or 1.2n
- Intripped
C12 could be a 1n capacitor,
as noted by Pakrat in his post:
https://www.freestompboxes.org/viewtopic ... 80#p264115
...even if, in the following post he says:C12: 12pf MLCC? (Marked "CDM 102 +/-5%")
Correction, C12 is indeed 120pf silver mica. Sorry about that.
- Groovenut
Here's a clear shot of C12 and it's valueIntripped wrote:C12 could be a 1n capacitor,
- C12 cap value.png (343.97 KiB) Viewed 2652 times
