Here are some guts of the DOD Boneshaker...grrrunge wrote:I'd like to see the DOD Boneshaker and Horizon Devices Precision Drive. The noise gate in the Precision Drive makes it particularly interesting to me
TL074 and a TL072 is used.
Sure, no problemgrrrunge wrote:Awesome! could you get some detailed pics of the standoff boards as well?kingmafw wrote:Here are some guts of the DOD Boneshaker...
Did you test it with a meter?fuzzfiend wrote:I verified the circuit trace. Nice job jrfox92! Just to nit pick, the FREQ pots are 500K log and I think all the pots may have pins 1 & 3 reversed.
That's why I did the cap mod on mine (though, I'd prefer balancing [where each cap is ~500nF rather than one is 1uF and one is 33nF] it as opposed to just switching out the caps). Here's the updated schem, also.fuzzfiend wrote: I don't hear any difference in sound for the first half of travel for the Distortion and all the EQ Level pots- only after 12 o'clock do they seem to effect the tone. In addition, I don't hear any differences no matter what position for the Depth knob. Maybe it only effects frequencies below the bass E string?
I didn't test with a meter. I just read the values from the side of the pots. Using other parametric EQ schematics for guidance (sabrotone, geofex, BYOC, etc), 10K just seemed too low.jrfox92 wrote: Did you test it with a meter?
It kinda makes sense since the codes are B103 56L2 and A504 56A1, so that's a good point.
Nice! I had no idea this was a known issue. Here's the link I found... https://www.talkbass.com/threads/npd-do ... 375/page-3jrfox92 wrote: That's why I did the cap mod on mine (though, I'd prefer balancing [where each cap is ~500nF rather than one is 1uF and one is 33nF] it as opposed to just switching out the caps).
I'd say it's unlikely to happen since that would require individual removal of the capacitors (the resistors could probably be figured out with the codes, but I'd bet they're about the same as any other normal drive and paraeq circuit).rocket8810 wrote:any word on when the values will be plugged into the schematic? i've been dying to draw up a layout for this monster.
