Prescription Electronics - COB ( Clean Octave Blend ) [traced]
- analogguru
pf fan found this pictures of the COB:
http://www.digimart.net/images/64/DS00252872.jpg
http://www.digimart.net/images/64/DS00252872_1.jpg
http://www.digimart.net/images/64/DS00252872_2.jpg
http://www.digimart.net/images/64/DS00252872_3.jpg
- puppiesonacid
you think maybe this is a green ringer with volume and clean blend functions added? hmmm...
- analogguru
It´s more a mix of a Fender blender input stage (similar can be found in the foxx Tone-Machine and Univox Uni-Fuzz) followed by a foxx Tone-Machine Octave/Distortion-engine. Have a look at these schematics.
- puppiesonacid
where are the schematics? I've been digging around for them for a while and can't find them anywhere...
- analogguru
Learn how to use the search function - if you type in "Fender" and "Blender" you will get this:puppiesonacid wrote:where are the schematics? I've been digging around for them for a while and can't find them anywhere...
viewtopic.php?f=19&t=141&p=768&hilit=fe ... ender#p768
- puppiesonacid
analoguru you have a PM, also if anyone knows where I can find an prescription electroincs schematic for the COB let me know. I'd like to compare them with the blender.
Thanks.
Thanks.
- noelgrassy
- my favorite amplifier: MOTS Magnatone & Trainwreck
- Completed builds: Tonebender Mk II w/ 3 OC75's, Burns BuzzAround w/NKT 275,Rangemaster w/ OC44, Fuzz Face w/ SKS363's, CJOD, Harmonic Percolator w/2N404A & 2N3635(vintage correct box,sliding pots, 1%glass resistors),Stack-O-Dimes & Whipple Wahs,
- Has thanked: 11 times
- Been thanked: 3 times
I'd like to add pictures of mine. It's an earlier version but appears identical to the model submitted by AG.
Those of you with an art program capable of creating "layer" images of varying opacity should be able to convert these two into a
usable schematic diagram.
I drew up a schematic years ago that I'll submit for reference to parts values at best.
The picture host has lopped off the right hand side of these pics. At least on these included pics. Bummer. Here's the links to the
picture files. I hope it helps.
https://i145.photobucket.com/albums/r22 ... 12-952.jpg
https://i145.photobucket.com/albums/r22 ... 12-951.jpg
- puppiesonacid
awesome! thanks, but the pic of the tracks is still lopped off. can you take another and post?
puppiesonacid
puppiesonacid
- MoreCowbell
- Transistor Tuner
puppiesonacid wrote:awesome! thanks, but the pic of the tracks is still lopped off. can you take another and post?
puppiesonacid
Just "right click" on your mouse and select "view image"...you'll see the tracks.
- puppiesonacid
no, the bottom left corner of the pcb tracks is cut off in the picture.
- MoreCowbell
- Transistor Tuner
using this pic the AG linked you should be able to figure it out.puppiesonacid wrote:no, the bottom left corner of the pcb tracks is cut off in the picture.
it "looks" at a glance like the traces end there, so whats off the pic are just offboard connections...but i didnt look closely or analyze it.
- noelgrassy
That is where the board endeth. There's nothing on the other side of those 2 solder pads.
- noelgrassy
All xistors are 2N3904, all diodes are 1N4001, all the 'lytics are 10uf @ 16VDC, except the one located bottom/right
side of board.
That little fella's a 1uf @ 50VDC.
Blue Mylar caps are 100n.
Polyprop cap sez 1000 pf.
Pots are:
Blend=250k Log or "B" type
Octave= 1M Log
Volume= 100k Log
side of board.
Pots are:
Octave= 1M Log
Volume= 100k Log
- analogguru
And here comes the
Prescription Electronics - Clean Octave Blend schematic
enjoy and compare,
enjoy and compare,
- puppiesonacid
Thank you AG! :
- puppiesonacid
idk, but I want to find out
- puppiesonacid
torch, you rock. thanks man
- rousejeremy
I built this using what I assume is Torchys vero and can't get it to work. There is a direct guitar signal without power, but when power is hooked up, just noise.
Has anyone else built it?
