cabsims... and even more cabsims
Postby temol » 10 Sep 2017, 15:52
I have eight different* cabsims laying on my desk. All diy work. And I have just made very short recording - for fun and for a comparison. Equipment used - guitar, POD HD500x, audio interface, Reaper. HD500x settings - all the effects off, Engl preamp on, cabsim off, looper ON). I've recorded short sample using PODs looper, and then played the sample through each cabsim into an audio interface. No further processing.
Here is the recording.. soundlcoud
First sample - no cabsim, then cabsim1, cabsim2.. and cabsim8. I'll reveal the cabsim models/names later :)
Just listen to the samples and pick the one you like the most.
* two cabsims are quite similar, just different freq response
T.
For this message the author temol has received thanks: 2
bmxguitarsbmx (21 Oct 2017, 00:43), Cub (11 Sep 2017, 10:24)
temol
Have thanks: 51 times
Re: cabsims... and even more cabsims
Postby Intripped » 10 Sep 2017, 17:46
i think that cabsim 1,2,3,5,6 are all good sounding, just different flavours
cabsim 4 to me it's way too mid scooped, what cab is it supposed to emulate?
cabsim 7 has a lot of ...glitching(?) rumor in background, seems to me that something is not working properly; maybe a cold joint somewhere.
cabsim 8 has a bit of glitching rumor as well
my favourites are 2 and 5
Intripped
Has thanked: 568 times
Have thanks: 212 times
Postby bmxguitarsbmx » 11 Sep 2017, 07:19
Nice! These are all respectable Cabsims. DIY? Did you include the Line6 cab too? I swear I would have recognized it, but no...
I'd use 2 and 7.
The first clip sounds like it has a cab on it, no?
bmxguitarsbmx
Has thanked: 236 times
Have thanks: 71 times
Postby Cub » 11 Sep 2017, 10:23
Great idea! Thank you for taking the time to do this, the most useful comparisons are always done on a level playing field.
Personally, I like sims 2, 3 and 7 sound best. I'll be looking forward to find out what the 8 sims all are.
Cub
Has thanked: 67 times
Have thanks: 72 times
Postby FiveseveN » 11 Sep 2017, 15:16
I'd say #2 and #3 have the most "accurate" treble roll-off. Tweaking the mid scoop would yield a range of usable tones.
I am curious to find out what they all are.
FiveseveN
Has thanked: 125 times
Have thanks: 47 times
Postby temol » 12 Sep 2017, 07:25
There is no cabsim in first sample. Just Engl preamp from POD HD500x with cab, mic, and other simulations turned off.
bmxguitarsbmx - all DIY. No Line6, sorry :)
Intripped - I agree, cabsim #7 has some hiss or crackle but I doubt it's a cold solder joint.
T.
bmxguitarsbmx (12 Sep 2017, 21:56)
temol
Postby Dirk_Hendrik » 12 Sep 2017, 12:47
Soundcloud recording gone??
Has thanked: 250 times
Have thanks: 1004 times
Postby temol » 12 Sep 2017, 13:07
No, it's still available. Try this link
T.
temol
Postby temol » 12 Sep 2017, 18:38
Time to unveil the mysterious devices... :)
Quick reminder... eight DIY cabinet simulators, one riff. First sample - no cabsim, then #1....
So.. drumroll... tada..
#1 - Multicab SIM by dschwartz. Four knobs (bottom, gain, flatness, top response). Bottom knob - 3 o'clock, flatness and top response 12 o'clock.
And a frequency response taken with RMAA with the same settings as recorded sample (this applies for all tested 8 cabsims). This one on a PCB and is boxed.
#2 - Simple CabSim by Lart. No knobs. PCB, no box.
#3 - Simple CabSim by Lart with bajaman mods (to emulate Celestion Blue speakers). No knobs. Vero, no box.
#4 - Distorque by Distorque Audio. I quote the author of the circuit - "I focused on emulating were the Jensen P12Q and the Celestion G12M "Greenback"." Four knobs, not sure about exact settings, just tried to find acceptable settings :)
This one is on a breadboard, pots witout knobs and I forgot to memorize exact settings.
#5 - Hot Line 2 Speaker Simulator by Sybirak. Two pots - sand cut and accent. Accent on/of switch and "cabinet" switch (3 cabs) Not 100% sure about settings, this one is also on a breadboard - probably cab 3, accent ON.
#6 - THE GUITAR SPEAKER SIMULATOR BY VICTOR KAMPF/AMT. Two potentiometers -cutoff and notch. Breadborded version.
#7 - LS14 cabsim by Lionsound. This cabsim is taken from the Lionsound Dark Angel Engl preamp emulator. No knobs, PCB. Frankly, I am a little bit dissapointed.. there is too much craclking sound, quite annoying for me. Not sure it it's because of my error (switched parts, wrong values) or it's just a feature of the design. I'll have to take a closer look.
#8 - Condor Cab Sim by runoffgroove . Two pots - gain, vol, Notch Depth switch. Vero, no box.
And all the frequency responses on one graph (amt, hotline and distorque on red, but I do not know how to change colour of the plot line).
Basically thats all I have for you at the moment :)
Maybe I'll take another round and measure freq responses with different potentiometers settings (amt, distorque, hotline) but it's "maybe", not sure about this.
There are another cabsims on my To Do & To Test List. I just run out of breadboard space :)
I do not post any links to schematics, they are easy to google.
T.
For this message the author temol has received thanks: 7
287m (13 Sep 2017, 09:01), bmxguitarsbmx (12 Sep 2017, 21:42), FiveseveN (12 Sep 2017, 22:19), Intripped (12 Sep 2017, 22:45), Manfred (13 Sep 2017, 04:51), poiureza (14 Sep 2017, 08:36), Pruttelherrie (23 Mar 2018, 23:57)
temol
Postby bmxguitarsbmx » 12 Sep 2017, 21:47
Great work Temol! Really helpful for helping to decide which one to build.
I got a very similar response from the Victor Kampf circuit. I'm curious if some of the parts values are wrong, as the stages don't match up with how they are aligned as described here:
http://media.amtelectronics.com/the-gui ... tor-kampf/
I know J0K3RX messed with this circuit a fair amount, maybe he has some insights.
Thanks again!
bmxguitarsbmx
Postby temol » 13 Sep 2017, 08:45
Here's the amt cabsim frequency response from ltspice model. It rather matches the one from AMT article.
It is possible that frequency response presented on AMT website was not taken from the working circuit, it's only theoretical response. Another possibility - wrong parts values, different transistors - different results.
T.
temol
Postby Cub » 13 Sep 2017, 12:39
Thanks again, :applause: that must have teken some time.
Very interesting, I didn't know about most of these.
Cub
Postby J0K3RX » 17 Sep 2017, 18:55
Messed with the AMT cab sim from the website and also the one traced from the pedals and didn't really like either.. There are a couple that I like and one is the Simple CabSim that temol used in his test (which is great!!) and a couple that I use that haven't been posted here.. I use the cabsim from the older Lionsound 10.2 or some version number that I am not sure of at the moment.. The DarkAngel 14 is a badass preamp!
These analog cab simulators are fine for a simple recording tool but they just don't cut it for professional recording and lack options etc.. I was messing around with using a compressor (Orange Squeezer) and some really tight reverb along with the Simple CabSim and was getting some really good sounding variations.. Was trying to simulate different mic positions, and room sounds etc.. But still not gonna cut it for pro recording..
Now this would be the way to go!!!
http://amtelectronics.com/new/new-2017- ... 16-module/
http://amtelectronics.com/new/amt-pangaea-cp-16m-eb/
J0K3RX
Has thanked: 310 times
Have thanks: 481 times
Postby temol » 18 Sep 2017, 14:45
This AMT module.. interesting... reasonably priced.
Going to build Dark Angel soon. I have Lionsound's sprint layout for version 14, unfortunately components names and values are missing. So I'm sitting with a schematic trying solve a puzzle.. 90% ready.
LS 10 cabsim - I've modeled this circuit with ltspice to see its frequency response. Quite similar to multicab sim.
T.
J0K3RX (18 Sep 2017, 16:34)
temol
Postby 287m » 18 Sep 2017, 18:55
Hi temol
ever try simulate trueVAL cabsim? sorry forgot link, not home now
287m
Has thanked: 285 times
Have thanks: 54 times
Postby J0K3RX » 18 Sep 2017, 21:54
287m wrote:Hi temol
Which one? He has created just a few.. :wink:
Have fun...
https://www.dropbox.com/s/qi2wn1boi4g2m ... s.zip?dl=0
So, when do you want to check out his tube preamp emulators? :twisted:
FiveseveN (18 Sep 2017, 22:06)
J0K3RX
Postby temol » 18 Sep 2017, 22:01
287m - I think that I have four or five cabsim schematics by trueVAL and three of them already with frequency resonse graph. I'd rather breadboard one of trueVAL's designs and measure frequency response from working circuit.
T.
287m (19 Sep 2017, 11:39)
temol
Postby temol » 18 Sep 2017, 23:08
Some of these schematics I see for the first time. Nice collection.
There is a Hyperbolic cabsim - what is the purpose of the part with MN3207 and MN3102 chips? Is this some kind of delay line that simulates reflections inside cabinet enclosure?
I have 4x12 Celestion V30 loaded cabsim schematic also with 3207 and 3102 (there is no signature of the circuit designer but looks similar to trueVAL designs).
T.
temol
Postby 287m » 19 Sep 2017, 11:47
J0K3RX wrote:
287m wrote:Hi temol
Have fun...
Woah, thanks Jim!
more than my save schematic from him.
my fav diy cabsim:
- trueVAL, 4x12 v7
- bajaman celestion mod
Hohoho, WIP for new MRM layout, my friend want onboard pots and vertical alignment component, he just hate my vertical pots layout.
also just populate 5150, waiting for 2n5458 jfet. fvckin rare here. :twisted:
temol wrote:287m - I think that I have four or five cabsim schematics by trueVAL and three of them already with frequency resonse graph. I'd rather breadboard one of trueVAL's designs and measure frequency response from working circuit.
T.
Yes, please. Big Thanks
287m
Postby temol » 23 Sep 2017, 08:26
5150 you say... still warm :)
T.
temol
Next
