Cleaning up the schematic now and will post shortly.
PCBs will be available here: http://www.pedalpcb.com/product/dirtysanchez/
andlord wrote:Hope you have them in stock. Gonna need a few of those.
Any chance you also gonna do the Buxom Boost?
bucksears wrote:Anybody know if the DS-OD mid control can be applied to the BE-OD?
HamishR wrote:I'm no expert on this stuff, but I assume that one BAV99 replaces a pair of 1N4148s?
HamishR wrote:Oh wow - my BAV99s arrived. They're TINY! I knew they would be I guess but was shocked at just how tiny they are. Luckily I ordered a few boards - I think I'll use 1N4148s on the first build. I wonder how different 1N4148s will sound? I have used various diodes in builds before just to hear the difference and yes, they can make quite a difference to the sound/feel of an overdrive. I guess the BAV99 is still silicon? So it should sound close to a 4148?
Branimir wrote:HamishR wrote:Oh wow - my BAV99s arrived. They're TINY! I knew they would be I guess but was shocked at just how tiny they are. Luckily I ordered a few boards - I think I'll use 1N4148s on the first build. I wonder how different 1N4148s will sound? I have used various diodes in builds before just to hear the difference and yes, they can make quite a difference to the sound/feel of an overdrive. I guess the BAV99 is still silicon? So it should sound close to a 4148?
Try to solder them on a perfobard and have them switchable via small dpdt and you can have a direct comparison, I'm also interested in sound difference!
And then comes BIGSMITTY with the 1N5819... Now I have to try that one also! heh
HamishR wrote:I really don't understand why there are so many different kinds of diodes - and I don't even know what a Schottky diode is, and I suspect a 1N5819 is a Schottky. But I have been to Zagreb a few times.I really like Zagreb.
Branimir wrote:That shows the voltage dependant cut off or?
Can you please explain the plots.
Users browsing this forum: alexradium, luix, theehman, Willypp and 16 guests
