Friedman - Dirty Shirley  [traced]
Postby bugg » 28 Oct 2017, 13:39
Just finished tracing the Dirty Shirley. This is basically a modified BE-OD with a few component value differences, an extra Vref buffer, and an active midrange control.
Cleaning up the schematic now and will post shortly.
PCBs will be available here: http://www.pedalpcb.com/product/dirtysanchez/
For this message the author bugg has received thanks: 11
alltrax (28 Oct 2017, 19:57), andlord (28 Oct 2017, 22:57), Frabbio (20 Nov 2017, 20:26), J0K3RX (30 Oct 2017, 14:28), jalmonsalmon (29 Oct 2017, 03:20), mac_2006 (06 Nov 2017, 03:02), nexion777 (29 Oct 2017, 11:52), roseblood11 (28 Oct 2017, 18:13), sprentiss (28 Oct 2017, 19:13), toneman (28 Oct 2017, 22:32) and one more user
bugg
Has thanked: 30 times
Have thanks: 205 times
Re: Friedman Dirty Shirley  [traced]
Postby bugg » 28 Oct 2017, 22:50
PCBs are on the way. :mrgreen:
For this message the author bugg has received thanks: 12
bajaman (29 Oct 2017, 10:41), deltafred (29 Oct 2017, 11:02), dv8r601 (30 Oct 2017, 01:21), floris (19 Jan 2018, 17:22), Intripped (29 Oct 2017, 14:56), J0K3RX (30 Oct 2017, 14:28), mac_2006 (06 Nov 2017, 03:02), modman (13 Nov 2017, 01:18), nexion777 (29 Oct 2017, 11:52), zamguitar (30 Oct 2017, 18:15) and 2 more users
bugg
Postby andlord » 28 Oct 2017, 22:51
Hope you have them in stock. Gonna need a few of those.
Any chance you also gonna do the Buxom Boost?
andlord
Have thanks: 4 times
Postby bugg » 29 Oct 2017, 00:30
andlord wrote:Hope you have them in stock. Gonna need a few of those.
Hopefully I won't run out of them like I did with the Thermionic Distortion...
I'll gladly do the Buxom Boost if i can get my hands on one. I have the Motor City Drive traced but haven't gotten a PCB layout worked up yet.
bugg
Postby sprentiss » 31 Oct 2017, 20:25
Could someone explain how the bass control works? I know it's the same layout as in the BE-OD but I'm having trouble understanding it conceptually. From simulating it it seems to be a variable bandpass filter, I just can't find anything to back up that idea and explain it on an obnoxiously detailed level.
sprentiss
Postby bucksears » 31 Oct 2017, 23:34
Anybody know if the DS-OD mid control can be applied to the BE-OD?
bucksears
Have thanks: 43 times
Postby bugg » 01 Nov 2017, 02:14
bucksears wrote:Anybody know if the DS-OD mid control can be applied to the BE-OD?
Yep, should be no problem.
bugg
Postby J0K3RX » 01 Nov 2017, 02:35
Said it in the BE post before I knew the was a DS topic started... You could do both on one board and there's your mid pot mod for the brown eye, if ya want it or leave it off if don't ... :thumbsup
J0K3RX
Has thanked: 306 times
Have thanks: 469 times
Postby HamishR » 02 Nov 2017, 11:54
I've already ordered a few boards - Can't wait to get them now! I even bought some BAV99s and will try to use them on one. I'm no expert on this stuff, but I assume that one BAV99 replaces a pair of 1N4148s? I was planning on wiring the single pin on one side to where the pair of 1N4148s are connected and the two pins on the other side to where the other ends of the 4148s would go. It could all go horribly wrong but I figure it's worth a try...
For this message the author HamishR has received thanks:
bugg (03 Nov 2017, 00:51)
HamishR
Have thanks: 8 times
Postby bugg » 03 Nov 2017, 00:56
HamishR wrote:I'm no expert on this stuff, but I assume that one BAV99 replaces a pair of 1N4148s?
That's correct. In the original pedal the pair of BAV99's are connected to the circuit at the junctions of pins 1 & 2, pin 3 of each device is not connected to anything.
There is no difference electrically if you choose to use pin 3 of each device as your connections. In either case, pins 1 and 2 should be connected together as shown.
For this message the author bugg has received thanks: 3
bajaman (03 Nov 2017, 08:55), HamishR (03 Nov 2017, 07:29), Manfred (03 Nov 2017, 10:36)
bugg
Postby HamishR » 04 Nov 2017, 04:14
Oh wow - my BAV99s arrived. They're TINY! I knew they would be I guess but was shocked at just how tiny they are. Luckily I ordered a few boards - I think I'll use 1N4148s on the first build. I wonder how different 1N4148s will sound? I have used various diodes in builds before just to hear the difference and yes, they can make quite a difference to the sound/feel of an overdrive. I guess the BAV99 is still silicon? So it should sound close to a 4148?
HamishR
Postby BIGSMITTY » 04 Nov 2017, 04:54
BIGSMITTY
Have thanks: 2 times
Postby Branimir » 04 Nov 2017, 10:17
HamishR wrote:Oh wow - my BAV99s arrived. They're TINY! I knew they would be I guess but was shocked at just how tiny they are. Luckily I ordered a few boards - I think I'll use 1N4148s on the first build. I wonder how different 1N4148s will sound? I have used various diodes in builds before just to hear the difference and yes, they can make quite a difference to the sound/feel of an overdrive. I guess the BAV99 is still silicon? So it should sound close to a 4148?
Try to solder them on a perfobard and have them switchable via small dpdt and you can have a direct comparison, I'm also interested in sound difference!
And then comes BIGSMITTY with the 1N5819... Now I have to try that one also! heh 8)
If you scoop, it sounds like poop!
Branimir
Postby J0K3RX » 05 Nov 2017, 17:50
Look here.. don't know if anybody tried them?
viewtopic.php?f=7&t=27775&p=264989&hilit=1N5819#p264989
You could try BAV99S.. 1 package with 4 diodes vs. 2 but they are SOT363 so, if you don't like nano sized shit you really won't like this package size...
I find it sort of ironic that allot of people want to make these tiny ass pedals but they cower in fear at the idea of using surface mount components :lol:
For this message the author J0K3RX has received thanks: 2
bmxguitarsbmx (05 Nov 2017, 18:02), Groovenut (05 Nov 2017, 20:22)
J0K3RX
Postby bugg » 05 Nov 2017, 18:46
HamishR wrote:I really don't understand why there are so many different kinds of diodes - and I don't even know what a Schottky diode is, and I suspect a 1N5819 is a Schottky. But I have been to Zagreb a few times. :-) I really like Zagreb.
Schottky diodes are designed for faster switching and have a lower forward voltage drop. In this case that means slightly brighter and earlier signal clipping.
bugg
Postby Manfred » 10 Nov 2017, 18:27
The awaited BAV99 arrived today, so I could made a PN-junction trace.
bugg (11 Nov 2017, 14:33), dv8r601 (12 Nov 2017, 17:18), modman (17 Nov 2017, 08:59)
Has thanked: 843 times
Have thanks: 368 times
Postby Manfred » 11 Nov 2017, 13:49
Here, the comparison between the BAV99 and 1N4148 Curves, the shape of the curves are quite similar.
bugg (11 Nov 2017, 14:34), modman (17 Nov 2017, 08:59), sixthfloor (01 Jan 2018, 17:02)
Postby Branimir » 11 Nov 2017, 14:35
That shows the voltage dependant cut off or?
Can you please explain the plots.
Branimir
Postby Manfred » 11 Nov 2017, 20:28
Branimir wrote:That shows the voltage dependant cut off or?
The traces show the current as a function of the anode-cathode voltage in forward operation,
but if you want, if Vak < 0,48 Volts, the diode is off.
Postby Branimir » 11 Nov 2017, 23:01
I understand, but that's with DC current, what about RF signal ? Can you sweep it with pink noise and voltage dependant 0,5 to 1V?
There must be some measurable difference between the 1N4148 and the Schottky
Exucuse my poor technical English!
Branimir
Next
Users browsing this forum: billhobinson, boby6kiler, m10065, mistermikev and 2 guests
