Ideas, layouts, schematics CABINET SWITCHER?
Postby tedsorvino » 03 Nov 2017, 00:15
I would like to know if there is a safe way to switch between 2 guitar cabinets?
I'm using a 60W tube (fender style amp) and I would like to build an A/B (or even A+B) (foot)switcher box to chose between 2 cabinets (Both 8 ohm).
I know the Radial box but it's way too expensive for me.
I've heard of a switcher that uses relays, but I haven't got any clear information.
I've also read about a passive box with resistors and a switch but it's not exactly what I was thinking since it's working only with the amp bypassed.
Any ideas, info or layouts (or schematic) on how to build such a box would be much appreciated.
tedsorvino
Has thanked: 20 times
Have thanks: 5 times
Re: Ideas, layouts, schematics CABINET SWITCHER?
Postby strato56 » 15 Nov 2017, 19:49
Any relay that can handle the current ( 60W in 8 Ohm gives 2.7A , so go for 5A ) will do the job. Be sure not to hit the strings when switching, the amp must have no output when switching, because for a fraction of time, your tube-amp will see no load.
strato56
Postby BlueMeany » 15 Nov 2017, 20:12
Just go for it using some decent (well over spec!) relays.
I've used a system like this for years without it ever causing any issues on any valve amp I've been tinkering with. The split second no load thing has never been an issue - and I've had 400W bass amps running through it.
BlueMeany
Postby bmxguitarsbmx » 15 Nov 2017, 20:21
BlueMeany wrote:Just go for it using some decent (well over spec!) relays.
Technically that is quite dangerous. Some years ago someone did a "spark gap" test with a similar setup.
You could easily use a SPDT relay to alternately short out a cabinet and have a "split second Series load" situation. Using a "make-before-break" switch, where the output is shorted, would also be safer.
bmxguitarsbmx
Has thanked: 263 times
Have thanks: 76 times
Postby tedsorvino » 22 Nov 2017, 18:40
Thank you both bmxguitarsbmx and BlueMeany for your replies.
1)Could you please share a layout or schematic and specs for the relays?
2)Why relays and not heavy duty switches (like car dimmer switches) ?
3) Is it possible to make it A, B, Y with two relays?
4)What about the MBB switch? Where in the circuit? What specs?
tedsorvino
Postby Aharon » 02 Dec 2017, 02:55
Aiken had a page on his site way back with a cab switcher,send him an email or visit the site might still be there.
Aharon
Aharon
Has thanked: 24 times
Have thanks: 8 times
Postby BlueMeany » 02 Dec 2017, 18:23
I've used it on probably hundreds of amps, switching them thousands of times between cabs. Never had any problems. It's tried and tested 100%.
BlueMeany
Return to Amplifiers
Users browsing this forum: YU-SUKE and 3 guests
