Bassman aa864 clone hum
spoontex
Post by spoontex »
Hello,
I've just finished my aa864 clone, Works... but... it have noise... Anybody can help me?
Thanks!!
phatt
Been thanked: 343 times
Post by phatt »
I have not heard that noise from those amp designs,,, hum?? check all the filter caps are connected especially the Screen supply.
Does the amp make clean audio with guitar plugged in?
Phil.
DrNomis
Has thanked: 98 times
Been thanked: 278 times
Post by DrNomis »
If you're using Carbon Composition resistors in your Bassman build then that's most likely what's causing the noise since Carbon Composition resistors tend to be inherently noisy, it could also be a cold solder-joint that's causing the noise too.
Might even be one of the preamp valves that might have gone noisy, try temporarily swapping out the first preamp valve (V1) for another known good one to see if that fixes the noise issue, if not, then try doing the same to the other two preamp valves.
A slightly loose valve socket contact can also cause noise issues too.
Aharon
Has thanked: 24 times
Been thanked: 5 times
Post by Aharon »
That sounds like ground noise ,also check that the heaters are wired correctly and that you didn't swap pins ,meaning all 4/5 go together and all 9 go together ,don't cross wire them or the humbucking effect is gone.Same with the power tubes .Also if you don't have a heater ground create an artificial one with two 100ohm resistors to ground.recheck all grounds ,use star grounding.Also check the vol pot wiring,does the hum go up with the vol?
Check the input jack ground,is it isolated?,Finally read Geofex troubleshooting for tube amps or Paul Ruby's page .
Aharon
lead2203
Been thanked: 20 times
Post by lead2203 »
It's the grounding. Separate the power section from the pre. First filter and second to their own grounding point with associated ground wires. Phase inverter and preamp to their own grounding point. Grounding everything to one point doesn't always work. Doing it that way it picks up noise from the current of the power transformer center taps and first filters grounds. Separate those and it stops the noise from going up stream into the preamp.
