caspercody wrote:What do you use to attach the voltage regulator to the board? To help heat sink it.
Daza wrote:I set the bass version, and I also have oscillation with high gain (around 12 o'clock) I'll see if it goes down changing the 47p
sego91 wrote:Im gonna try to replace the 7660s with another IC to eliminate the oscilation and squeel, maybe a 1054 im gonna check it out .
temol wrote:I have 7660SCPAZ in my build and no oscillation.
T.
Users browsing this forum: sonsofthunder, storyboardist and 14 guests
