JHS - AT (Andy Timmons) Signature Drive [traced]
- roseblood11
Hast du in deiner Finanzplanung ein Plug In für Drums mit drin? Hilft einem sehr beim Ideen sammeln... Ich nutze zB EZdrummer, weil man da schnell im Plug-In eine Songstruktur bauen kann und dann mit einem Click in die DAW übernehmen.
- bugg
I do believe that is correct. This should correspond to the 100W mode, described as "cleaner, loud".roseblood11 wrote:The toggle is a on/off/on, so no clipping diodes in middle position?
PedalPCB.com - http://www.pedalpcb.com/
- Scruffie
- Opamp Operator
Mein Deutsch ist schlecht aber das ist nicht verwandt?roseblood11 wrote:Hast du in deiner Finanzplanung ein Plug In für Drums mit drin? Hilft einem sehr beim Ideen sammeln... Ich nutze zB EZdrummer, weil man da schnell im Plug-In eine Songstruktur bauen kann und dann mit einem Click in die DAW übernehmen.
- Groovenut
I was under the impression that the louder setting were the LEDs , the lowest setting were the Schotky's and the middle setting were mosfets.bugg wrote:I do believe that is correct. This should correspond to the 100W mode, described as "cleaner, loud".roseblood11 wrote:The toggle is a on/off/on, so no clipping diodes in middle position?
- bugg
There are no mosfets in the thing. I know the Madbean Turnabout has them, but the AT doesn't.Groovenut wrote:I was under the impression that the louder setting were the LEDs , the lowest setting were the Schotky's and the middle setting were mosfets.bugg wrote:I do believe that is correct. This should correspond to the 100W mode, described as "cleaner, loud".roseblood11 wrote:The toggle is a on/off/on, so no clipping diodes in middle position?
- Groovenut
Ah I see. Very interesting. Thanks for the info!bugg wrote:There are no mosfets in the thing. I know the Madbean Turnabout has them, but the AT doesn't.Groovenut wrote:I was under the impression that the louder setting were the LEDs , the lowest setting were the Schotky's and the middle setting were mosfets.bugg wrote:I do believe that is correct. This should correspond to the 100W mode, described as "cleaner, loud".roseblood11 wrote:The toggle is a on/off/on, so no clipping diodes in middle position?
There's an assembled board on ebay that claims to be JHS @ that seems to bear this out in the pics.
- alexradium
OMG its amazing,what a genius!
- bugg
I don't have the original in-hand anymore but this is a fairly good pic of the PCB.
The two components at the bottom (D201 and Q200) are part of the LED switching. There are no components on the other side of the board.
- Manfred
- Has thanked: 1675 times
- Been thanked: 1360 times
Miss the point, I guess text insert by mistake.Scruffie wrote:Mein Deutsch ist schlecht aber das ist nicht verwandt?roseblood11 wrote:Hast du in deiner Finanzplanung ein Plug In für Drums mit drin? Hilft einem sehr beim Ideen sammeln... Ich nutze zB EZdrummer, weil man da schnell im Plug-In eine Songstruktur bauen kann und dann mit einem Click in die DAW übernehmen.
The EQ is a linear (B) pot like the Air pot. I am sure because after endless researches I found a picture of the top side of a AT pedal circuit board, showing the B10k pot.
Have a nice day!
Giulio
Have a nice day!
Giulio
- Ichabod_Crane
Comparing the schematic of the Madbean Turnabout and the Pedal PCB version of the JHS - AT the differences are minimal. In the Pedal PCB the coupling cap after the second opamp stage is 2.2uF and not 1uF, and the Volume pot is log and not linear.
And of course the clipping, the central position is with Mosfet in the Madbean Turnabout (a sort of OCD style, I guess). While in the Pedal PCB is with any diode or anything. I guess the original AT is like the Pedal PCB.
I would like to build a JHS AT, but I have some doubts about the schematic.
About the EQ pot: rev log vs linear. I can't say what original pedal mount.
There's a lot of discussions about the difference between the AT and the Crunch Box, and in some picture we can see in the AT pedal just a third extra 100nF cap, one after the gain pot, one in the power filter as in the Crunch Box. Everybody says that this extra 100nF cap is across the ground and in parallel to the 22nF in the tone section. But Pedal PCB and Madbean Turnabout doens't have it.
I'd like to see this picture, too. Anyway, with my emulator probably a reverse log as EQ should give a more balanced response.shredgd wrote:The EQ is a linear (B) pot like the Air pot. I am sure because after endless researches I found a picture of the top side of a AT pedal circuit board, showing the B10k pot.
Here you have it!Ichabod_Crane wrote: About the EQ pot: rev log vs linear. I can't say what original pedal mount.I'd like to see this picture, too. Anyway, with my emulator probably a reverse log as EQ should give a more balanced response.shredgd wrote:The EQ is a linear (B) pot like the Air pot. I am sure because after endless researches I found a picture of the top side of a AT pedal circuit board, showing the B10k pot.
I've already written in another forum that this "extra 100nf cap" is only a voltage stabilizer for the opamp, placed between V+ and ground, which is a good practice to have very close to the opamp. The cap in the tone section is really only the 22nf.Ichabod_Crane wrote: There's a lot of discussions about the difference between the AT and the Crunch Box, and in some picture we can see in the AT pedal just a third extra 100nF cap, one after the gain pot, one in the power filter as in the Crunch Box. Everybody says that this extra 100nF cap is across the ground and in parallel to the 22nF in the tone section. But Pedal PCB and Madbean Turnabout doens't have it.
Giulio
- Ichabod_Crane
Thank shredgd for the picture. It's really clear that the EQ is a linear pot. I'm curious to try a rev log, too.
Thank you Giulio, I missed your information in this other forum. Then, this 100nF you mean is a bit like the other in the power filter? (C10 in the Pedal PCB schematic posted above).
Exactly. Compare this Angry Charlie guts picture (C9): with this Sweet Tea guts picture (Angry Charlie part of the circuit on the right), where you have an SMD cap in the same place, very close to the opamp. In both layouts that cap is far from the 22nf caps of the tone section.Ichabod_Crane wrote:Then, this 100nF you mean is a bit like the other in the power filter? (C10 in the Pedal PCB schematic posted above).
