Solo Dallas - SVDS Replica
Postby patricef » 19 Jan 2018, 23:43
Did you make a prototype or just the drawing ?
patricef
Have thanks: 14 times
Postby boby6kiler » 20 Jan 2018, 06:15
just the drawning :D
j attends juste une réponse sur le mail que j e t ai envoyé sur slo mdr pour aller plus loin
ya quelque truc qui me chiffonne niveau alim merci
boby6kiler
Have thanks: 9 times
Postby GeoffroyLux » 21 Jan 2018, 13:38
Nice Boby :thumbsup
Smells good I just received my NE570 and LM380 yesterday!
I will try it soon [smilie=rlp_smilie_242.gif]
Sorry for my English ^_^
GeoffroyLux
Postby patricef » 21 Jan 2018, 17:43
Some update: on my schematic, R14 should be removed. D3 value is 43A48A.
Voltage, 0V taken from input jack ring:
VCC: 12.09V
IC1 pins:
1: 5.81V
2: 5.82V
3: 5.73V
5: 3.64V
6: 0V
7: 3.64V
8: 11.58V
IC2 pins:
1: 0.95V
2.:1.79V
3: 1.79V
5: 1.80V
6: 1.79V
10: 7.24V
11: 7.24V
12: 1.80V
13: 11.58V
14: 1.80V
15: 1.79V
16: 0.78V
IC3 pins:
1,2,3: 0V
6: 5.06V
7: 11.73V
8: 11:87V
For this message the author patricef has received thanks:
boby6kiler (21 Jan 2018, 18:02)
patricef
Postby EddieTavares » 21 Jan 2018, 19:33
patricef great Job!!!
:applause: :applause: :applause:
EddieTavares
Have thanks: 13 times
Postby apollomusicservice » 21 Jan 2018, 20:27
patricef wrote:Some update: on my schematic, R14 should be removed. D3 value is 43A48A.
VCC: 12.09V
IC1 pins:
1: 5.81V
2: 5.82V
3: 5.73V
5: 3.64V
6: 0V
7: 3.64V
8: 11.58V
Values at pin 6 and 7 on IC1 can't be different.
apollomusicservice
Has thanked: 65 times
Have thanks: 769 times
Postby patricef » 21 Jan 2018, 21:03
VCC: 12.09V
IC1 pins:
1: 5.81V
2: 5.82V
3: 5.73V
5: 3.64V
6: 3.64V
7: 3.64V
8: 11.58V
My mistake, I rechecked again pin 6 and 7 are indeed at the same voltage.
patricef
Postby patricef » 27 Jan 2018, 22:49
boby6kiler has been working hard on tracing and verifying the circuit. I'll post an updated version of the schematic soon, stay tuned !
For this message the author patricef has received thanks: 3
bmxguitarsbmx (28 Jan 2018, 22:50), boby6kiler (28 Jan 2018, 05:54), RiGLEY (28 Jan 2018, 20:58)
patricef
Postby boby6kiler » 28 Jan 2018, 05:54
:popcorn: :applause:
thanks patrice for this one
For this message the author boby6kiler has received thanks:
patricef (30 Jan 2018, 13:02)
boby6kiler
Postby patricef » 30 Jan 2018, 13:01
Attached the latest schematic. Enjoy !
boby6kiler (30 Jan 2018, 13:35), chbeer (30 Dec 2018, 15:07), Intripped (30 Jan 2018, 15:04)
patricef
Postby boby6kiler » 30 Jan 2018, 13:15
nice schematic patrice :D
i don't find a good alternative to this :
any idea ?
boby6kiler
Postby EddieTavares » 30 Jan 2018, 14:00
It looks like a diode, propably a 1n4148 smd version.
EddieTavares
Postby boby6kiler » 30 Jan 2018, 14:13
patricef mesure 0.246V with the multimeter in diode mode
boby6kiler
Postby EddieTavares » 30 Jan 2018, 14:29
This is the D5 in the patricief's schematic if I am correct. It looks like a reverse flow protection, I don't believe that it makes any tonal difference...
I believe that the sollo dalas guys tried to reproduce in the pedal every single component present in the original Shaeffer gadget, Why they implement R9, R15 and R17 all 8k2 resistors simply dropping a litle voltage?
EddieTavares
Postby RiGLEY » 01 Feb 2018, 11:03
boby6kiler wrote:nice schematic patrice :D
[ Image ]
any idea ?
Yeah, it looks like a diode by Vishay. Can't find anything specific by searching 43A 48A.
RiGLEY
Postby GeoffroyLux » 01 Feb 2018, 16:09
1N4348 ? Smd SOD-123 size ?
But I didn't find anything
GeoffroyLux
Postby lovetone » 08 Feb 2018, 09:50
Hi, I drew this up a while ago and forgot all about it its very close to the schematic drawn by apollomusicservice with slight differences.
At the time I removed some of the surface mount capacitors to check the values so some on this drawing are low values but thats what I measured at the time.
This may help with some of the missing values.
Sorry for the drawing but I don't have a drawing programme.
For this message the author lovetone has received thanks: 2
boby6kiler (08 Feb 2018, 18:42), foulioud (08 Feb 2018, 10:58)
lovetone
Have thanks: 8 times
Postby boby6kiler » 08 Feb 2018, 18:23
-the 10nf in ic1 pin 2/1 verified with multimeter removed from the board?
-the 1nf in the area of 8,2k/2,2k verified with multimeter removed from the board?
-the 16pf in ic3 pin 3/6 verified with multimeter removed from the board?
thanks
boby6kiler
Postby lovetone » 09 Feb 2018, 09:01
boby6kiler wrote:-the 10nf in ic1 pin 2/1 verified with multimeter removed from the board?
thanks
Yes as far as I can remember if I could not measure the capacitor in the board then I removed it.
lovetone
Postby boby6kiler » 09 Feb 2018, 09:35
thanks i will try this values
boby6kiler
PreviousNext
Users browsing this forum: barnwellmj, Bobbyd67, cooperman, josepmorte and 6 guests
