Friedman - Buxom Boost  [traced]
bugg
Has thanked: 51 times
Been thanked: 336 times
Post by bugg »
Lithium_Grim
Has thanked: 39 times
Been thanked: 72 times
Post by Lithium_Grim »
That is a complex powersection. Why so complex, normally a -9v requires a lot less components? Can anyone give some insight?
I only give negativ feedback and y'all love it!
PCB shop
toneman
my favorite amplifier: anything that works
Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
Has thanked: 183 times
Been thanked: 45 times
Post by toneman »
Q1 and VR1 form a preregulator for the LT1054 which is sensitive to overvoltage.
Too much input and POOF!
U could do this with 2 9V batteries but what's the fun in that?
8)
Tone-to-the-Bone
LeroyP
Post by LeroyP »
The first to op amps have gains of only 1.47 each?? Is that right?? With the gain control turned up full the total numerical gain for the three stages combined is only around 20 (26db).
This could be achieved by having one stage and a 200k pot instead of the three stages plus the 100k pot.
Am i missing something??
Leroy
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
LeroyP wrote:The first to op amps have gains of only 1.47 each?? Is that right?? With the gain control turned up full the total numerical gain for the three stages combined is only around 20 (26db).
Leroy
26 dB is plenty of gain for any application,as a clean boost,the use of more stages is because of the tight filter to work independently of the volume boost and be separated from the guitar input.
Even if you could kill 3 birds with one stone,why not throwing a couple more for fun if it doesn't cost much more,i mean 2 or 3 TL072s cost very low money,they are machine mounted in big quantities and the pedal sold to more than 200.
screamingdemon
Post by screamingdemon »
Question i orderd the pcb but what type of caps should i use.Panasonics stacked metal film or polyfilm.
plush
Has thanked: 36 times
Been thanked: 171 times
Post by plush »
screamingdemon wrote:Question i orderd the pcb but what type of caps should i use.Panasonics stacked metal film or polyfilm.
Just by it looks, the pcb is designed to use boxed capacitors (epcos, wima, arcotronics and others) with 5mm lead spacing (63-100v), but you can use any other type that fits - polyfilm, metal film, ceramics etc with no tonal difference. Just avoid using cheap unbranded caps.
