Vertex - Steel String Singer  [traced]
jonnyxjuturna
Post by jonnyxjuturna »
Just curious if Mason is still up to his old chicanery. Or is he really building stuff these days?
Bill_Mountain
Has thanked: 44 times
Post by Bill_Mountain »
I read an article where he apologizes and then stated that all his pedals are made in an assembly house in batches. Not sure if they are clones or not though.
bugg
Has thanked: 51 times
Been thanked: 336 times
Post by bugg »
jrfox92
Completed builds: Death by Audio Fuzz War
Electro-Harmonix Big Muff Pi V5
Skreddy Lunar Module
Colorsound Overdriver
Electro-Harmonix Big Muff Pi Multi-Diode and Feedback Mod
Electro-Harmonix Holy Grail Room Reverb and Reverb Length Mod
Boss DS-1 Synth Circuit Bend
Been thanked: 54 times
Post by jrfox92 »
Yeesh.
$200 for a couple of Mu-Amps into a Big Muff tone control.
Frank_NH
Has thanked: 114 times
Been thanked: 154 times
Post by Frank_NH »
jrfox92 wrote:Yeesh.
For reference purposes...
1oldsidewinder
Has thanked: 18 times
Post by 1oldsidewinder »
Interesting. i wonder if the new Ultra Phonix OD is a variation of the same basic design. It's also being marketed as a Dumble sim.
Nocentelli
Has thanked: 1154 times
Been thanked: 954 times
Post by Nocentelli »
1oldsidewinder wrote:Dumble sim.
:slap:
Frank_NH
Post by Frank_NH »
I went to the Vertex website to read more about the Steel String Clean Drive. Lots of comparisons to "D" style tones, but no mention of either Jack Orman or Aron Nelson.
J0K3RX
Has thanked: 316 times
Been thanked: 556 times
Post by J0K3RX »
No need to open this one up since they already did it for you... All I have to say is, Really? :scratch:
https://www.vertexeffects.com/battery-power-supply
I think a schematic is in order.. :lol:
Not to be confused with Vytex Condoms.. :twisted:
http://www.vystarcorp.com/resources/con ... ation.html
Frank_NH
Post by Frank_NH »
Is that four battery "power supply" for real??? :slap:
Bill_Mountain
Frank_NH wrote:Is that four battery "power supply" for real??? :slap:
Seems like a good idea from a marketing standpoint.
jonnyxjuturna
I figured he was ripping someone's circuit. At least this time (maybe) he isn't slapping his sticker on someone else's pedal?
To be frank, I have zero interest in buying his stuff. I'm just curious, because it seems the boutique world has so quickly forgotten his old tricks, and he seems to be getting recognition again.
theehman
Has thanked: 98 times
Been thanked: 105 times
Post by theehman »
jonnyxjuturna wrote:I figured he was ripping someone's circuit. At least this time (maybe) he isn't slapping his sticker on someone else's pedal?
True of others. Freekish Blues, for example.
Ron Neely II
fx schematics and repairs
jonnyxjuturna
theehman wrote: True of others. Freekish Blues, for example.
Did Ken come back?? :shock:
alexradium
Has thanked: 64 times
Been thanked: 68 times
Post by alexradium »
the guy is just a marketing freak,he brainwashes the "artists" with PNL and a good check,that's all,this battery box was already in other pedalboards of these guys made by Bradshaw and Dave Phillips i guess.
His boost is just a standard boost,nothing special.
As far as D sounds,make it play to any good aforementioned pro and he's gonna make it sound like you want it to sound,its like that,since almost nobody has ever played a real SSS in reality.
okgb
Has thanked: 226 times
Been thanked: 38 times
Post by okgb »
he has a funny youtube video where three guys are doing a blind listening test between the
Vertex Ultraphonix OD and a dumble amp with no parameters or methods explained or identified
they're supposed to say if they thinks it's the pedal when they hear " ramdomly " live played examples
of course nobody gets them all correct, and you're supposed to say " well if it's that close , for 200 ! "
actually I saw a couple versions of it , promising to giveaway a pedal , so people post their guesses furthering
the " confusion " about which is which ] or as I believe he wants you to say which you think is better , the two examples
do not sound well matched so you can ascribe qualities to each because they [ purposefully ? ] sound different
ppluis0
Has thanked: 127 times
Been thanked: 299 times
Post by ppluis0 »
Hi folks,
Forgive me for resurrecting an old post.
I would like to know if the values ​​of the tone stack that appear in the pedalpcb diagram are correct.
Did someone put together this circuit with those values?
I did a simulation and the response curve seems strange to me.
Awaiting your comments.
José
alexradium
you should ask to Vertex guy,now he is the "Rig Doctor" on YT,and solves all the problems of the world by cutting and snipping,please check out the shitstorm on TGP.
ppluis0
Post by ppluis0 »
Thank you Alex to point me to the discussion in "the other forum".
I find another tale about this matter here at the forum: viewtopic.php?f=20&t=24898
So what would be the appropriate values ​​for a tone control stage with Big Muff topology ?
What is the best response suggested to the kind of booster exposed in this thread ? (flat, mid hump, mid scoop ?)
alexradium
ppluis0 wrote:Thank you Alex to point me to the discussion in "the other forum".
there is no real answer to this,you have to find out yourself what sounds good to your ears,i recommend to use the tonestack calculator program,to check out what to change.
You could start with something similar to the Wampler Pinnacle,and tweak from there.
