Jumpering channels to get dirt on your Fender-style amp
Desdog
Has thanked: 62 times
Been thanked: 16 times
Post by Desdog »
I'm almost sure the double inputs were not designed to do this, but it's a great mod. In fact, it's just coupling the inputs, but with some resistors? Is there then 130k between the two channels in a Deluxe?
Screenshot from 2018-03-28 21-43-27.png (21.08 KiB) Viewed 591 times
I'm just trying to squeeze some distortion from this this dual input PA tube amp with 2xEL34:
Screenshot from 2018-03-28 21-52-34.png (64.41 KiB) Viewed 591 times
I would like to wire this up with a switch, maybe even make V1b a dedicated distortion path. I think I tried jumpering the inputs, that didn't do much. But will test again tomorrow...
